Topic Title |
Replies |
Topic Starter |
Views |
Last Action |
| Announcements |
Announcement: Upgrade Complete! |
AdminAF |
2214 |
Last post by: AdminAF
| Forum Topics |
djpilot976 |
211 |
18th August 2008 - 07:47 PM Last post by: djpilot976 |
my car has now been in the shop 3 times for the same "Check Engine" light indication.i has go to workshop check with computer already .and my ride still can driving and never brakedown!!!!!
Here is the report print out Picture.
anyone get this problem before??anyone can help me on this issue????
lesaroka |
192 |
17th August 2008 - 08:44 PM Last post by: Executive Sonata |
Hello,
My 2000 sonata is getting harder and harder to start when cold or after sitting awhile. After it has been running I can turn it off and hit the key and it will start normally. Does this car have a "fuel pressure regulator?" I had a similar problem with a different car and that was what I had to replace.
Scratinmehed |
179 |
17th August 2008 - 02:21 PM Last post by: Scratinmehed |
Hello. My Sonata 2001 2.0 GLS has suddenly started running unevenly, it starts and ticks over fine but struggles under load. I had the same problem last year when I replaced the plugs and both leads which sorted the problem then.I have replaced the plugs and leads again but uneven running remains. Any ideas please ?
CRS481 |
250 |
17th August 2008 - 01:35 AM Last post by: CRS481 |
I have a 2001 Sonata GLS and I'm having issues with the sunroof. When I press the button to close it it will close but stop about 3 inches or so before it should, also it will not raise up when I press the up button. Can anyone please help me with theis?
omnipotent goku |
212 |
16th August 2008 - 05:54 PM Last post by: omnipotent goku |
Well... im back just as quickly with a new question; How do you get the alternator out of the engine bay. It seems pretty evident where the bolts are, but how do you physically access it to pull it out and replace it ?
Also, how do you relieve the tension on the tensioner pulley?
youfo |
239 |
15th August 2008 - 07:29 PM Last post by: youfo |
While changing the spark plugs on our 2002 Sonata 2.7L V6, I discovered a broken wire on one of the fuel injectors. I'm pretty sure I can fix it if I can get the small wiring harness, which powers 3 injectors, off of the car so I can take to my workbench. However, I haven't been able to get the connectors off of the injectors. I don't want to apply too much force and break them.
Does anybody know the trick to unlocking the fuel injector electrical connectors so they can be unplugged? I couldn't find anything in the online service manual for this model.
Any advice would be appreciated.
0
omnipotent goku |
145 |
14th August 2008 - 06:36 PM Last post by: omnipotent goku |
Well , after getting an estimate from my local heydumgai (hyundai) dealer for $1100 to fix the following, im going to do some of it myself.
Alternator
tension'r pulley
Serpentine Belt
Timing Belt
$1100
That may not be a bad estimate, but I don't have that so I just spent $93 for them to answer a question (worth it in the end).
Anyway, im going to do the alternator, tension pulley and serpentine belt system over the weekend (I'll leave the timing belt to a pro). I can justify $460 for just the alternator alone when i've changed it on my camaro in the past.
Anything I should know in advance going in about either the alt. , belt, or pulley ?
Wish me luck.
haristo |
272 |
14th August 2008 - 01:55 PM Last post by: haristo |
Hi everyone,
I have come to you as my last resort. I purchased a 2000 Sonata gls v6 about a month ago. Since the beginning it has had a hard time starting when the engine is cold. Once it starts the car runs good, except for the random stalling. I'll try to explain exactly what happens.
I turn the key, engine turns for about 10-12 times and then the car starts, very rough idling for about 1 minute and then its fine. I arrive at my destination, turn off the car and for testing purpose i start it again and it starts like a champ. If i leave and come back 10 minutes later, same starting problem again.
So far i've changed the fuel filter, apparently the mechanic told me it was very very rusty, did treatment for injectors (cleaner) and changed spark plugs.
I really need to find a solution to this, i have no background in cars, any help would be greatly appreciated
Harry
99sonata15 |
293 |
14th August 2008 - 01:03 PM Last post by: montego |
i Just bought a cd deck for my sonata and was trying to remove the old radio so that i could put the cd deck in and i cant figure out how
nrvlcman |
185 |
14th August 2008 - 11:46 AM Last post by: Executive Sonata |
you know the light that lights up the gauges? is there a way to change the color to blue? and do you know of a site that would sell what i need?
10
Bru023 |
572 |
11th August 2008 - 08:20 PM Last post by: Executive Sonata |
Hi , Ive did some searching and found out that alot of people have had the same issue with the air bag light being on and it led them to under the driver seat. So i went down there and found a wire with a connector that is not plugged in to anything and i think that is the culprite but the only problem is i cant find where it plugs in to i spent ours upside down trying to find where it goes its not to long of a wire , anyhow has anyone had this problem and found where it plugs in any info would help because i got inspection coming soon and need to have the air bag light off to pass inspection , ive tried unplugging the battery and it comes back on
6
kit352 |
224 |
9th August 2008 - 07:38 PM Last post by: kit352 |
im having a **** of a time getting the vss off. i can get the wires and the hold down screw off but the unit itself wont budge. i havent wacked it with a mallet of anything cause im afraid itll break off. ive tried tugging and twisting it to no avail. ive been driving it but my speedo doesnt work and its getting real annoying. theirs gotta be a trick to it.
7
Executive Sonata |
474 |
8th August 2008 - 08:11 AM Last post by: Executive Sonata |
I tried the search button and didn't get any results. Do you guys think that it would be hard to swap in a manual transmission from a Tiburon into my V6 Sonata. The tiptronic is ok, but it is still an automatic and I'd like a bit more control. Thanks guys.
71mopar383 |
296 |
6th August 2008 - 07:52 PM Last post by: 71mopar383 |
Since Granny is orginal owner and the 10/100000 warr is still good since it only has 64000 miles on it..If the sensors need replacing would they be covered?
6
kit352 |
316 |
6th August 2008 - 03:57 PM Last post by: Hyundai101 |
well my power steering hose has blown. i was thinking of get rid of it anyway since i knew it was going down hill. im also thinking of ditching the a/c system too and just getting rid of that whole side of the motor. anyone tried it? its gonna be a while before i get that hose so im gonna have to do something soon.
0
cace2002 |
249 |
6th August 2008 - 06:15 AM Last post by: cace2002 |
I have a 2000 Sonata GLS V6. My Fan switch needs replacement and the dealer want $185.00 to do it. I was wonder how hard it waould be to acces the switch? It looks as though I only need to remove the center dash paneling (wood grain
plastic) to get to the switch and pull a few connected wires. If anyone can confirm that the paneling is all I need to remove I'd appreciate it. Also I read somwhere in this fourm that the paneling comes off w/ screw driver wedged for leverage to unsnap it from the dash is all that is needed. Is that true? Anyone w/ a shop Manual out there?
Please Advise,
Carl
0
bachmand |
126 |
5th August 2008 - 04:43 AM Last post by: bachmand |
Hi,
When reading out the code from the ECU I get a code 41. The engine is not running smooth, but seems to stagger or hesitate at certain rpm's and varying load.
Any suggestions
Regads Jan B. Jensen
davejrs |
236 |
4th August 2008 - 03:33 PM Last post by: byronguidry3732 |
Replacing my O2 sensors Bank 1 sensor 1 and bank 2 sensor 1 with a generic 4 wire sensor, in the pic is the original one removed from the car 4 wires Yellow, white, gray and black. The other sensors have 2 white and a black and gray can these be matched up color for color or is there something missing here can anyone help thanks
rod911 |
395 |
3rd August 2008 - 03:52 PM Last post by: ssonata78 |
Hi,
i have recently purchased a 2001 sonata - alls well wth the sonata - however
the airbag lights are constantly on! - this is a personal vehicle and the seller (owner before me) had spent 1200 USD repairng the airbags. the car dint have any issues for first 2 days post which airbag light stays on (steady)
the dealer had given 1 year warrenty on airbags to the original owner (but not sure if the warrenty is transferrable) actually not.
i need your help to understand how i can resolve this - cause i dont want to spend another 1200 USD on a 4000 USD Car and keep facing this issue again and again
pls help and advise
Rod
0
kit352 |
181 |
2nd August 2008 - 11:43 PM Last post by: kit352 |
been having some issues with the car for a while now so is about time to invest a bit of time to fix it. basically when i start the car in gear with the clutch pushed in the car will move forward unless i keep my foot on the brake. it is also very hard to get out of first gear the first time. once i break it free i have no more issues until i shut the car off for a bit. also when driving if i push the clutch in the rpms dont always drop, its like im not even pushing it in. other than the start up thing it hasnt caused any issues but i can see that happening. ive replaced and bleed the line a few times trying to see if that would work but it didnt do anything. i have no leaks of anything. any ideas?
snichols1 |
330 |
2nd August 2008 - 09:27 PM Last post by: SuperChris |
I just purchased a used 2002 Hyundai Sonata with 55,000 miles on it. I didn't notice when I bought it that the AM radio is very staticky. The FM radio is tolerable, but still a little static. The cd player sounds fine through the speakers.
I assume it is an antenna problem. I've never changed one before. I hear it is quite expensive just for the power antenna part. Maybe I can find a used one. If I try to change it myself, is it do-able in a couple of hours? I printed off some instructions from someone else who replaced it themselves.
If I switch to a non-power antenna, is there a specific one I need to buy to get it to fit?
0
GSpec |
131 |
1st August 2008 - 02:38 AM Last post by: GSpec |
I have a 96 Sonata with a 4G63 2 ltr engine and a 5speed box (step mount type)
The box requires change over and top up. As i don't have a service manual I am unsure of the recommended amount of fluid, does any know the correct amount?
jujudaboo |
619 |
26th July 2008 - 02:39 PM Last post by: Firefighter_Barbie |
1999 Hyundai Sonata
The windshield wiper motor barely works on low, high and hags in the middle of the intermittent mode. I replaced the motor and now it is doing the same thing plus blowing the wiper fuse? I am at a loss right now! Just scratching my head and thinking I will probably have to bring the car to a mechanic?
dondonf |
302 |
26th July 2008 - 04:00 AM Last post by: jujudaboo |
Plse se attached diagram. Do you now which of these is the fuse for the wiper?
dd716ted |
350 |
24th July 2008 - 11:28 PM Last post by: mostholycerebus |
The car has now been in the shop 3 times for the same "Check Engine" light indication.. The first time was at 20,000 miles.. the dealer I took it to said the code indicated a loose gas cap.. I questioned that, but made an effort to put it on tight.. then at 52,000 miles, it came on again.. I did the 4 key (on/off) sequence and the light would extinguish for about a week then come back on.. then several days later off... then on again and off again...This week at 54,000 miles I took it to the dealer again, and he said it was a faulty gas cap, and replaced it..All should be fine now I was told.. he very next day the light came on again... and is still on.. but I am sure it will reset after several starts.. I guess it is back to the dealer again who is 50 miles away.. any idea what is going on before I make the return trip?
mostholycerebus |
288 |
23rd July 2008 - 04:55 PM Last post by: mostholycerebus |
I just picked up my v6 Sonata from a local shop, having had them replace the drive belt, timing belt and tensioner at 60k miles. As soon as I started it I heard a tapping, and thought this was from it sitting a few days, so I let it idle for a moment then took off. It sounded like the tap died off at this point. After getting home, 3 miles away, and stopping I could clearly hear the tapping again. I lifted the hood and it was very clear. I checked for obstructions, did not find any.
Is this normal in any way? The timing tensioner was straight from Hyundai, the belt from autozone but high quality. The only thing I can think of is the shop screwed the timing, or the tensioner has to wear in? What else could this be?
242 |
23rd July 2008 - 11:27 AM Last post by: byronguidry3732 |
I've been looking around for a 1989 Sonata owner's manual, but can't find one for the life of me. My car didn't come with one, and no stores in my area carry them. If anyone has a link to one over the internet (downloadable would be nice
) or an idea of where I can purchase one, that would be wonderful.
SuperChris |
711 |
21st July 2008 - 05:39 PM Last post by: SuperChris |
After searching Ebay and such, I found an wire harness for the premium sound system to work with the amplified factory unit. If you are installing a new deck for HD radio or an Ipod....the factory harness couldn't be found to work with the amplified system or the H290 radio.
Scosche has one that will work without having to bypass the amplifier system. It is listed for an 2006 Sonata system but has the proper connector and filter to make it work with aftermarket head unit. Part # HY06B
It has been a pain trying to find one to mate with aftermarket head units without having to cut into anything.
Also, if you are looking into a double din install kit they have one too. Part # HY1602B
Hope this helps someone from wasting time surfing....I know I have the past week.
Chris
tremere613 |
444 |
21st July 2008 - 03:41 PM Last post by: byronguidry3732 |
i have a sonata 2004 6cyl
a couple of days ago i heard creaking sound every time i turned the steering wheel...
i opened the hood and noticed power steering fluid was low...
so i replaced it....
2 days later....same thing happened....and their was a small puddle underneath my car...
i took it to my friend over at a oil change/car wash and he told me theirs a small leak
and he couldn't seal it because he doesn't have the tools? or sealant?
anyways
please help I'd love to fix this myself!!
is it possible?
i am somewhat of a grease monkey just tell me exactly what to do and buy and i ll get right down to it
thanks in advance for any input!!
-Dan
ps. do u think putting Prestone + stop leak power steering fluid will fix the problem?
6
paulbro |
265 |
21st July 2008 - 11:57 AM Last post by: paulbro |
Hey all!
I did a search but didn't find results.
Our '05 Sonata (V6 - ~63k miles) has occassionally made a high pitched whistle after driving. It seems to do it on a drive after a hot day and seems to come from the passenger side in the engine compartment. Due to the location of the sound, I'm wondering if it has something to do with the air conditioning system.
It's difficult to describe. It's fairly loud. It can start doing it after the car has been sitting for some time (cooling down) and will continue to do it whether the car is running/off, AC is running/off. The pitch of the noise can vary and the length of time it does it is several minutes (+15mins). There doesn't appear to be any driveability issues, but it's concerning.
We initially thought it was coming from a refridgerator that is close by in the garage. I thought the 'fridge compressor might be bleeding off or leaking, but I found out it was actually coming from the engine compartment of the car.
Any help you can offer is appreciated. Any questions I can answer to start pin-pointing the issue, I am glad to (try to) answer.
Thanks,
Paul
skysharker1 |
217 |
21st July 2008 - 06:43 AM Last post by: Bdiggy |
[attachmentid=8591]Hello. I just slapped some 18" rims on my '04 Sonata and there is quite a gap between the tires and the wheel well. Does anybody have any ideas on how to drop the ride about 1" - 1.5"? I am looking at some Eibach springs that should do the job. Any help will be greatly appreciated.
falesafe |
455 |
20th July 2008 - 01:55 AM Last post by: EF/ELP |
Hello All,
I just purchased a @2004 Sonata loaded....The stereo has a "choose disc" arrow ...I am un able to load a second disc though...By the manual it states that the cd/cdc button should display on the LCD but it does not for some reason..I did see a post that suggested unplugging the battery, then trying to load again...At any rate the stereo is being replaced soon but if anyone has any other suggestions..They would be much appreciated!
0
mally |
179 |
19th July 2008 - 12:37 PM Last post by: mally |
The horn on my 2005 Sonata 2.4DX has stopped working. The fuse is OK, I have checked that the relay is working but there is no voltage to horn connections. Is there another relay somewhere? Help Please.
g07ph0 |
398 |
18th July 2008 - 04:01 PM Last post by: SandSnip3r |
Can somebody show me how to remove the driver's door panel please?
thanks,
8
Bakesalee |
406 |
18th July 2008 - 02:31 PM Last post by: Bakesalee |
I want to change the brake pads because no matter how much water I clean the wheels (inside the holes too) the sqeaking is killing me. I've taken the car to numerous places to check the brakes and I always get "they're fine, just dirty," yet no matter what they do (if anything) I'm squeaking within a day.
Would you spend the big bucks and go to a dealership, or just have somewhere like Firestone, Midas, etc take care of it? If I go to somewhere other than a dealership, what kind of pads should I ask for?
Is it kind of weird to anyone that when I take the car somewhere, they don't try to sell me anything (pads or otherwise) and just tell me they're dirty, yet no one can seem to "clean" them off?
Does anyone know if the 2003 Sonata has disc, or drum brakes, or a combo of both?
xx_ph4nt0m_xx |
283 |
18th July 2008 - 12:02 PM Last post by: xx_ph4nt0m_xx |
So im attempting to put in a head unit from my old vehicle in my sontata. i got the correct wiring harness. i even checked it against the wiring diagram from the hmaservice. i know that the wiring matches up but when i turn the new head unit on i have no sound. i know that sound is coming from the head unit cause i plugged a home stereo speaker up to it which worked fine.. im unsure now why i dont have sound. is there a separate amp system for the speakers? im just dumbfounded as to why its not working with this head unit and it works fine with the stock. i might just go to circuit city and make them do it but i'd rather do it myself if anyone can help.
dutta7sk |
916 |
17th July 2008 - 03:45 PM Last post by: JK43123 |
Hello Experts,
I have a 2002 hyundai sonata driven 85K miles. I have never changed transmission fluid on the car. I had gone for oil change and the mechanic showed that the transmission fluid was black and needed to be changed.
I would really appreciate it if experts can let me know what are the parts that need to be replaced as part of transmission fluid change and what is the average cost. Thanks for your help.
7
rob4 |
1,070 |
17th July 2008 - 03:43 PM Last post by: JK43123 |
Hey! my first post here!
I'm wanting to flush my own trans fluid (03 Sonata 2.7L V6) next weekend. I can get my hands on the spIII fluid, and the filter/gasket, but was wondering if anyone else has flushed their automatic trans. I've done it on my Chrysler Concorde, and it's pretty easy:
Drop the pan,
replace the filter and pan gasket,
refill to spec (about 4 qts),
pull the trans cooler return hose,
point the hose into a bucket,
get about 4 quarts of new fluid open and ready, and a funnel ready in the dipstick,
have someone start the car,
immediately start pouring the trans fluid into into the trans,
after pumping out about 4 quarts into the bucket. or when fluid pumping into
bucket drops pressure, Yell "stop the car!".
refill flud to spec.
do 4 more qts (for a 12 qt system)
That being said...
I haven't been underneath the Sonata yet!. Is the pan removal straghtforward?
which of the two hoses is the trans cooler "return" line (out of the radiator)?
Anyone???
0
dave027 |
159 |
16th July 2008 - 08:53 PM Last post by: dave027 |
Having a charging issue on a 01 2.4 Sonata, alt. charges then quits, battery light and brake warning dash lights come on, no output, had alt. bench tested, checked out OK, reconnect and it works for a short while, have battery voltage at hot stud, and 3 terminals on the plug, all connections are clean, the diagram shows a generator relay, which I can't find, and a Pre exitation resistor which I also can't find. I replaced link at pos term. to alt. Any insight into this would be appreciated. For some reason I can't download schematics from Hyundai website. Thanks
fd4887 |
290 |
16th July 2008 - 11:28 AM Last post by: fd4887 |
It's time to the flush the coolant system on my 2005 but I can't find the drain valve. Can someone give a guy a hint?
CL-Slick |
270 |
16th July 2008 - 01:59 AM Last post by: Firefighter_Barbie |
My friend has a 95 Sonata and the front doors won't open. They will lock and unlock, but won't open. I am guessing the locking mechanism is stuck on the lock position on both doors. Any ideas?
158 |
15th July 2008 - 03:53 PM Last post by: Firefighter_Barbie |
I'm just getting a 1989 Hyundai Sonata and everything with it is perfect, except a few minor things. The background with it is, my boyfriend is a tow truck driver and hauld away this car for scrap. The previous owner wanted it gone just because the exhaust had a hole in it, which is getting repaired. It runs and is great but I'm having issues with the Driver's side Rear Door. It won't open at all. Both the handles from the inside and out move but the door wont open. I can't get ahold of the previous owner to get any history on it, but I can tell that the door has been like that for several months at least.
If anyone has ever expirenced this before and/or has any ideas at all on how to fix this, I would love to hear your answers!!!
