Topic Title |
Replies |
Topic Starter |
Views |
Last Action |
| Important Topics |
24
VALKYRIE YB70 |
13,028 |
9th January 2009 - 01:37 PM Last post by: JohnFinn |
Many people do not realise that Hyundai U.S.A. have provided a free online Workshop Manual for all the Hyundai models that are sold in America.
To use this click :-
http://www.hmaservice.com/webtech/default.aspEnter your car`s details & click the `Shop` tab.
It might be an idea to bookmark this to your favourites........& remember you can print off sections (or the whole manual!) as required.
Cheers,
Nick.
11
VALKYRIE YB70 |
7,006 |
16th April 2008 - 04:34 PM Last post by: Dragonmp5 |
O.K. Guys!......over the months to come there will be lots of info. posted on here about basic tuning; which really boils down to engine breathing improvements : often referred to as I.H.E. (intake, headers & exhaust).
Whilst these performance enhancements are easily (but not always inexpensively!) obtained, it is worth rememberlng that, at the same time, THE UPGRADING OF BRAKES & SUSPENSION IS VITALLY IMPORTANT!......I`m sure these necessary improvments will also be covered at length!.
Anyway; once you have fitted your CAI (cold air induction kit), installed that`killer`cat-back stainless steel straight-through exhaust & bolted-on your new headers, most of you will want MORE.....but probably won`t have the means, or knowledge, to go down the Forced Induction path, (meaning turbocharging or supercharging).
If that is the case & you are staying `normally-aspirated`, then this excellent site will fill you in on some of the Stage 2 upgrades possible on the Tiburon`s/Coupe`s.
I.E.
Underdrive Pulleys
Upgraded Clutches
Aluminium Flywheels.... (yes that`s how it should be spelled Yanks!).
Here`s the link :-
My WebpageCheers for now,
Nick.
VALKYRIE YB70 |
6,795 |
20th July 2005 - 10:51 AM Last post by: legravin |
Sorry, I just realised that I had only shared this info. with S-Coupe owners! :-
Click hereCheers,
Nick.
0
VALKYRIE YB70 |
2,194 |
31st December 2004 - 07:49 AM Last post by: VALKYRIE YB70 |
In order that we can help you with relevant advice, please include AT LEAST your car`s model, year & engine size in your PROFILE!.
Thanks,
Nick.
| Forum Topics |
noobie26 |
19 |
Today, 09:32 AM Last post by: byronguidry3732 |
Hi there,
I barely just bought a 2000 Tiburon love everything about it However just found yesterday after the car stop running ... brought to the shop to get it fix for $215 for Crank position sensor... and the mechanic told me the transmission it bad... a few code pop up
Check engine light ON
P0335 crank position sensor A
P0300 Random misfire
P0727 Engine peed sensor circuit no signal
P0732 Engine Gear 2 ratio incorrect
P1701 manfacurer control transmission
P1703
The mechanic told me the part for transmission it self is $1,100 with no labor cost yet he told me it not worth fixing to sell the car... I got really sad =( i just bought it no more the a 1week old for $2900 with 97,000 mileage... any help or suggestion. I'm from San Jose, CA and going to Losangles and Vegas soon anyone got the skill to fix it for a better price.... thanks all
tibbigirl |
10 |
Yesterday, 09:50 AM Last post by: sYc |
I am trying to find out which cylinder on my tiburon is the number one cylinder. Any tips on how to find this information out? I figured out the hub bearing problem, now my check engine code is saying that I have a cylinder 1 misfire.
0
Jesse James |
22 |
16th March 2010 - 10:33 PM Last post by: Jesse James |
OK heres the problem I am having. 97 Tiburon 1.8 New Motor. New Clutch, Master Cylinder for breaks and Clutch and new slave cylinder and lines. My cluch done well for a couple weeks with just the new slave cylinder giving that I would keep it under 3200rpm's. Anytime over 3200 rpms when I would try to shift I would have the problem of the slave cylinder getting stuck in the (depressed) position. My Pedal would return to its normal position at which point you could push it once and it would hit the floor and then once again locked it at the top of its travel zone. Now I can easily get out of the car, push the slave cylinder push rod back into the slave cylinder socket and it will do fine for a couple shifts. I was told that this was caused by the master cylinder so I have now changed the master cylinder and experiencing the exact same thing. I am LOST. New Clutch, Slave, Lines, and Clutch Master and still having the issue. What could be causing this. PLEASE HELP!!
elliott65 |
97 |
16th March 2010 - 07:54 PM Last post by: elliott65 |
I hit a chunk of metal on highway one night. It busted tranny pan and valve body, caused air bag lite to come on. I fixed tranny and tried to reset ECM by leaving battery off several days. Lite still on and seat belts wont retract or work????
auto_body_man |
35 |
13th March 2010 - 08:48 PM Last post by: auto_body_man |
I have a 2000 Tiburon and it was stuck in park. I tested the solenoid and it works, and there is always on power to one side of the solenoid but no ground. I am assuming that the other wire is supposed to supply a ground when the key is on and the brake is pressed but it does not. also my brake lights do work, so does that mean that the brake switch is good?. I do not know where to start to fix this problem any help would be appreciated.
RobMA |
90 |
13th March 2010 - 01:16 PM Last post by: RobMA |
On my son's 2000 Tiburon, the driver side rear caliper parking brake lever is "frozen"
Hitting repeatedlywith a good size hammer did not free up the mechanism.
Passenger side works fine but driver side is frozen solid.
Any suggestions on how to free this up other than replacing the entire caliper?
Would heat help or will it damage internals
As a result, parking brake does not hold car and he failed his State Safety inspection.
I replaced the brake pads as they were worn and hoped it might help but no luck.
Cables work fine and parking brake handle has been adjusted.
Any suggestions????
Thank you in advance,
Kurt
lockley_j |
61 |
10th March 2010 - 12:21 PM Last post by: tiburon98 |
Was wondering if anyone has any ideas as to why the headlights no longer work. They were working a couple of weeks ago but now nothing. I can get one to work if I remove the other bulb, the second I install that second bulb the lights dim almost to the point of not being lit. Also if I have the one bulb working and turn on the turn signal the headlight flashes with the turn signal. Any ideas?????
Jason
sbu |
56 |
10th March 2010 - 12:18 PM Last post by: tiburon98 |
why is it that the headlight got an elbow beam at 30 degree angle to the left, tried to adjust it but still i got other drivers flashing their headlights at me when i'm driving at night, how can i fix this? i tried all the headlight adjustments from hyundai websites
lockley_j |
84 |
10th March 2010 - 12:16 PM Last post by: tiburon98 |
Need to know where the flasher relays are located in the passenger compartment on a 98 Tiburon.
Jason
Jesse James |
69 |
10th March 2010 - 12:10 PM Last post by: tiburon98 |
Ok, Heres my problem and I really hope some of you can help. I have been searching the forums for the last 6 hours with nothing really helping the problems that I have. First off I purchased a 1997 Tiburon with a blown motor and a new crate engine for 500 bucks. Body and interior in excellent shape. I finally got the motor installed this evening with very little difficulties was actually very surprised at the comparassion of the old 4g63 engines out of the eclipses and talons. Most wiring and everything is exactly the same.
First issue. On the wiring harness on the right side of the block there is a set of three wires. one that goes to the throttle positioning sensor and one that goes to the cam positioning sensor I think, There is one other wire there that is just a single wire with a rubber boot that I can not find where it goes. is this something that would have been just for the 2.0 engine?
Second issue is the fuel pump, The car had been sitting for over 2 years so I figured possibly it was frozen up and would need to be replaced. Took it out hooked it to a battery and it started humming away. I replaced the fuel pump relay still no power is going to the connector. I am getting power on the center top connector but only about 6 volts so I am betting that is to the fuel gauge. If anyone knows anything else to try to do for this i would greatly appreciate any input.
Jay49 |
38 |
10th March 2010 - 12:03 PM Last post by: tiburon98 |
when I finally replaced the switch the code went away for a while(2 days), BUT two ther codes came up within a day (P1624 and P0734). I went to erase them and a little while later the Kick Down Servo Switch code came back! I'm loosing my mind and I'm dong this with high hopes that someone out there can either help me out or give some really good repair advice! jayrod49@yahoo.com is my email address if you want to send an email
6
killercodfilter |
61 |
10th March 2010 - 12:01 PM Last post by: tiburon98 |
ok new here, so i just got fx for the step son. after a few days, when it is put in reverse it takes a long time to go in. after adjusting the cable and trans range senser it worked for a few days then started to long engagement again. adjusted senser again, same thing all over again. so has any one seen this before? i was thinking about putting a new tansrange senser, or like i said is some thing else to look for? the car has 165,000 miles and runs good.
6
havokjay |
91 |
10th March 2010 - 11:58 AM Last post by: tiburon98 |
Yesterday, out of no where, my Tib just started giving me problems starting. It just cranks but won't start. Give it an hour or so, and it just fires right up. So where do i start? an interesting note, however, is that my dash-clock, dome-lights, and sun-roof all are out. could this be related? i have not checked into the fuses yet but i did check the master power (yellow) fuse and it was still down. So here are my thoughts:
1. Fuel pump/ fuel pump fuse
2. Fuel Filter (could explain the occasional behavior)
the fuses is where i am gonna start. Can someone give me some advice? if no ideas, can someone at least tell me if there is a fuel pump fuse and what its number is?
thank you!!!
torresda01 |
68 |
10th March 2010 - 11:54 AM Last post by: tiburon98 |
I've got a 5 speed 2001 Tiburon coupe that has basically lost the will to move. The engine sounds like it's over-revving when I drive it, but it won't top 20 miles per hour. At first I thought it might be either the mass airflow sensor, or even the ECU. However, I'm no grease monkey. If anyone can help me out it'd be greatly appreciated. I've tried going to the dealer to run a diag but they gave me some bs about my o2 sensor causing a funky reading. They wanted $200 to change the o2 sensor I'd already replaced that week for all of $70. So I opted out of that one. Any ideas?
4dtvman |
49 |
10th March 2010 - 11:49 AM Last post by: tiburon98 |
After replacing 1 spark plug wire with an old set. The second one cracked. I went to 3 autoparts stores to buy a new set and it seems that there about 1/2 to 3/4 of an inch to short. The car is a 4 cyclinder and it seems that it share the same engine with other models. The difference that my friend said is that on this car the bracket that holds the coil pack is bigger thus the 3/4 inch diferences. Any one have the same problem and what should I be buying. Don't want to go to the dealer.
shogokuma |
52 |
10th March 2010 - 11:47 AM Last post by: tiburon98 |
i have searched this forum and havent found anything, its a 99 tiburon, i looked on google and some places told me to unhook ball joints that didnt seem right...
i just need to know how to remove it so i can bring it to the repair shop.
thanks in advance.
SweetMadamBlue |
113 |
10th March 2010 - 11:37 AM Last post by: tiburon98 |
Just tried to install a new fuel filter into my 2000 Tiburon. Finally got it in but its leaking quite alot. The leak is at the feed line coming into the filter. We tried tightening but that doesn't do a thing. Any ideas?
yoson |
49 |
10th March 2010 - 11:31 AM Last post by: tiburon98 |
Sorry if I posted this in the wrong place, i'm brand new to this forum.
I was wondering if anyone had a right fender for a 01 Tiburon, preferably the dark blue color (don't have color code). Doesn't really matter tho. Could anyone help out here or would there be a better place for me to look?
ls14life |
33 |
8th March 2010 - 08:47 AM Last post by: jsinton |
Hey everyone, im new to this site and it seems like you guys have a pretty good group here. I drive a 98 z28. Anyways i just signed up because im looking at picking up a 98 tiburon for my girlfriend, she really likes them. It has about 120k on it but its really cheap. I was just wondering if there are any major maintenance issues with these cars and if they generally last much longer than 120k. I don't really know anything about these so any info you guys can provide me i will really appreciate. Thanks
10
regularcat |
109 |
24th February 2010 - 10:10 PM Last post by: regularcat |
when getting the trouble codes, the machine picked up 7 codes.
i received these codes.
po443 - evaporative emission control system - incorrect purge flow
po743 - torque converter clutch circuit electrical
po745 - pressure control solenoid malfunction
po750 - shift solenoid a malfunction
po755 - shift solenoid b malfunction
po760 - shift solenoid c malfunction
po765 - shift solenoid d malfunction
seems to me we clearly have an issue inside the transmission, could it possibly be my transmission is shot ?
or could it just be i have a loose ground wire from the battery ?
im no expert when it comes to this particular vehicle, but im almost sure its a tranny problem.
if not what else could it possibly be.
i await & appreciate any & all responses & i need my car fully functional asap.
thanks in advance guys.
YoungMoneyVII |
50 |
19th February 2010 - 11:15 AM Last post by: Dragonmp5 |
Hi, my names dan nice to meet you guys. I own a 90 Firebird but my cousin owns the 01 tib and hes mechanically retarded so i just thought id try and fix his car problems for him. His steering wheel cover seems like its about to fall off its very lose and when he turns the wheel if falls out of place. Im a little concerned that if this cover part comes off it might eject the airbag but i dont know tibs very well. His steering wheel/column also shakes and vibrates very loudly sometimes not really sure whats going on with that either maybe thats the reason why whatever nuts or bolts where holding the steering wheel cover are loose. His mom takes it to the shop once in a while for other repairs and they fix the steering wheel cause the cars under warranty and a few weeks later he says is starts shaking again. Im not even sure if steering wheel cover is the right word for the part im trying to describe its the part in the middle of the steering wheel. My cousin has just been wedging it in a unaligned position so it stays for now but im not sure how much time he has left till the thing falls off. Any help and information would be greatly appreciated so i could fix this for him as soon as possible.
tiburon_man99 |
96 |
19th February 2010 - 11:06 AM Last post by: Dragonmp5 |
[attachment=16087:PC090147.JPG]
umm. i waz wondering what i can do to my car to get better performance "hp" out of it and dont spend any money. i have 1999 hyundai tiburon. its a 2.0 sohc.
[attachment=16086:PC090151.JPG]
louie cruz |
99 |
19th February 2010 - 11:00 AM Last post by: Dragonmp5 |
what are the best and affordable mods for my car? im looking to get an intake and headers, are the intakes at your local auto parts any good? what about headers off ebay?
17
miller69time |
248 |
17th February 2010 - 03:29 AM Last post by: miller69time |
ok i have a 1997 tib with a 1.8 and auto now i bought it for $450 with a burned up trans so this may be why it went out in the first place?now my friend sonny ownes a trans shop so he rebuilt my trans and got me a dayco reman converter for $600.00 and i know hes good for he has rebuilt many domestic transmissions for me before although is dosnt know much about foreign cars so he rebuilt this trans as a favor for me this being his first foreign trans rebuild.
now that said the trans is installed,now its stuck in 3rd gear saftey mode me and my friend sonny know that much.
So we started looking around at connections etc to see if it could be a simple connection issue and i found nothing wrong.
the only electrical parts my friend sonny replaced was a shift solenoid because when he tested the solenoids one of them was bad so that being said we dont know where to go from here?
if i scan it do you think that may narrow it down for you guys because i did notice when i first test drove the car the check engine light came on after about 3 miles but when i checked the connections over we took out the battery and the light hasn't came on again because i haven't driven it any further than my driveway so i don't do any more further damage to the trans.
any help is much appreciated, thanks
Tiburon_Guy |
99 |
11th February 2010 - 09:15 PM Last post by: killercodfilter |
Hey Guys,
got a 2001 tiburon that sometimes will not shift into drive or reverse from park. (automatic)
Sometimes it works fine, no problems.
It's like you can't push down the button to move the shifter down.
Any ideas?
23
schmider |
1,207 |
8th February 2010 - 04:01 AM Last post by: lovemysantafe |
My 1999 Tiburon had an unfortunate run-in with some roadside structures. The bad news is it will cost more to fix it than it is worth; the good news is that most parts got spared except for the hood, left fender, left headlight, front bumper, left door and radiators. The engine and transmission have 104,000 miles and run great. I have stripped the car completely, so almost every part not listed above is available.
wesley.gsxr |
65 |
6th February 2010 - 08:36 PM Last post by: FlyRyde |
HI guys
im new in this forum i have a tiburon 2.0l fx and my hood blow off after thay tryed to steal my battery
.the hood catch was damaged.
so i was thinking of replacing it with a carbon fiber one.are there any guy ya that have done this? i would like to see what it looks like
thanks wesley
0
SweetMadamBlue |
55 |
3rd February 2010 - 11:40 PM Last post by: SweetMadamBlue |
2000 Hyundai Tiburon 4 cyl
Tonight I drove my standard car about a mile, it hiccuped in the movement ?gas? drove normal for about an eighth of a mile then as I was slowing down, it died. It would not restart. We pushed the car to a close by area, and went back to it over an hour later. It started right away but the engine light remains on. I did put $10 gas in the engine and drove it home.
Background:
The car had previously been sitting for a 2 week period with very little gas, put in $5 and then sat a couple of days before driving it tonight.
Any ideas? I think it may be a dirty fuel filter caused by the settled muck in the gas working its way thru.
0
Max Korn |
42 |
31st January 2010 - 09:47 AM Last post by: Max Korn |
I own a 1999 Hyundai Coupe SX and have seen other cars of very similar models or almost exactly the same but the difference is the others are always an SE or FX. I have never even seen another SX on the road so my question is, what is the difference between an SX and and SE and the others? And why are there so few of them around?
My other question while I'm here is I'm planning to trade it in or sell it for a newer car, maybe one of those new Hyundai Tiburon which look absolutely great. I have had the car since 2004, has done 138,000 km and is in perfect condition as I keep it well maintained and checked regularly, no major problems, even the mechanics have said it's in top shape for a car this old. Has CD/mp3 player with ipod jack which I had installed a few years back, alloy wheels which I also had put in last year and all the other stuff like spoiler etc. Just wondering, ballpark figure, what should I get for it? I'm hoping for at least $5000-$6000 (Australian dollars by the way) considering the condition of the car and the reasonable mileage.
5
bradders01 |
84 |
23rd January 2010 - 09:43 AM Last post by: bradders01 |
Hi all,
I have a Coupe SE '97 which comes with a crap clarion stereo and I need to get it out to upgrade system but I have no idea how to do this as it seems I might have to take fascia/dash off....?
Is this right? And how do I do this?
This model has cup holders and ashtray built in and I have no idea how to get the stereo out !!!!
Please can someone help....
UngerMax_ |
79 |
22nd January 2010 - 05:29 PM Last post by: louie cruz |
I just bought this car today and im just wondering which spark plug brand should i use besides the recommended for better performance?
Thank you
01 Blue Shark |
84 |
21st January 2010 - 12:40 PM Last post by: jsinton |
My 01 Tibby had a little hesitation this morning (after driving 50 miles to work this morning), the car felt a little sluggish after the got to work. The check engine light has come on. I figured it was the plugs, given the way the car was reacting to the acceleration. I've changed the plugs from NGK (old 1 1/2 year old) to Denso U-Groove. The problem was solved, however, the check engine light is still on. Can anyone assist me as to where the check engine light switch is located, or, how would I go about resetting the check engine light.
8
THURSBY2 |
468 |
18th January 2010 - 04:55 PM Last post by: AliDaMan |
hi i just want some help if you guy could.
my i10 is 20 months old and done 20k. The abs light came on the other day so i took it to my dealer. He has told me i need new brake pads. I just want to know if this the correct ware or should they have lasted longer?
sorry for being so naive
13
shawnsdad |
109 |
13th January 2010 - 10:48 PM Last post by: jsinton |
I have a 2000 tibby and got a bone yard trans and it was junk. they have a 98 trans that is good. only68000 miles shifts through all gears and when you hit the overdrive button it does what it should. will it work? is there any diffrence in the trans? mounting, plug in for sencers?
thanks
PlatosRep |
65 |
10th January 2010 - 02:38 PM Last post by: PlatosRep |
Hi my friend tiburon is grinding going 3rd gear and pops out of 5 th even once i grind it in. His shifter seems super hard to move around and I have to manhandle his shifter to get it into 3rd enven when the car is off. i'm a us/euro mechanic so i was was wondering if lubing the linkages or adjusting clutch or shifter linkages would help.
shawnsdad |
72 |
6th January 2010 - 07:43 PM Last post by: MiamiLX |
2000 tiby auto. what fluid is used for change? thanks
Camtacular |
193 |
4th January 2010 - 05:04 PM Last post by: CamronTheGreat |
I own a 1998 Hyundai Tiburon. When I usually sit in an intersection that I need to turn (left turn), the turn signal blinks and then stops working. Then I try it again and it's shut off completely. Any help on this matter please? thanks
Mingo21 |
70 |
1st January 2010 - 04:59 PM Last post by: Mingo21 |
What do you call a device that just above the surge canister? It appears to be a motor since it has electric connector going to it. It has a 1/2 inch small hose to connect to surge tank and also connects to the air intake system.
It seems that everytime that I "smack" it the throttle/idle changes. I hear some hissing sound from it.
I have been trying to trace an apparent vaccum problem which causes the car to stalh.
thanks
7
Mingo21 |
231 |
1st January 2010 - 02:09 AM Last post by: Mingo21 |
bought car with 127K miles, had rough engine problem. replaced Intake Man + cat convert; new plugs, wires, MAF. Cleaned throttle plate. Had tranny checked. shifts ok. BUT.... It stalls when stopped otherwise idles ok. Good power but at times jerks like it looses gas or vaccum.
went to autozone to check engine codes: P0102, p0748, p1128, and p1613
each is decribed as: Mass airflow circuit low input; liners solenoid electric (tranny?); long term fuel trim - low fuel pressure filter plugged or fuel pump; finally MIL request signal circuit - open or short circuit condition.
Based on the fact that I changed the MAF; plugs, wires and intake man in addition to cleaning the throttle I am inclines to see if the Gas Pump or filter (which are located in the gas tank-?) could be the next logical place to go.
Any ideas? Does this seem reasonable.
P.S. I also have an exhaust pipe leak for which I failed inspection. While I am not sure if this would contribute to a vaccum leak/preassure problem I am looking for confirmation from some of you experts to see if this should also be considered.
I am hoping that the solenoid (p0748 code) does not point to that problem since the tranny guy told me that this will cost me @1,000.00 to fix
any help
Running out of cash
thanks
Lee Nguyen |
106 |
31st December 2009 - 06:52 PM Last post by: Lee Nguyen |
0
sycodan99tiburon |
79 |
27th December 2009 - 08:24 PM Last post by: sycodan99tiburon |
hello all,
recently i have had a problem with my tiburon. it dies while running. if you jump it it starts fine, no problems. but it will only run 5 or 10 minutes and then it dies. this is an alternator problem right? just checking if thats what it is. the car runs longer the less electrical stuff i run while its on. thanks...
xekhz |
99 |
24th December 2009 - 08:13 PM Last post by: Dragonmp5 |
Hello,
Today i started the car and the ABS light did not get turn off. Yestarday everything was fine......
Could it be the cold wheather ? or dirty sensor ?
How can i replace then sensor and check the problem....
Im from Portugal
0
sycodan99tiburon |
54 |
22nd December 2009 - 08:44 PM Last post by: sycodan99tiburon |
hello all,
newbie here have had my tiburon for about 8 months and three days ago the rear defrogger stopped working. i checked the fuse and replaced it just to be sure, its fine. Still not working and im not sure where to go from here. Also the same day it stopped working the brake light and the battery light came on. Not sure if they are related or just a coinciedince. Car starts and runs fine even here in buffalo ny where its been 20 degrees for the last week, so i dont think i have a battery issue but not sure... brakes seem fine, just had the front caliper replaced about six weeks ago at a garage, fluid fine not low. Not sure where to go from here any help would be apprciated. thanks...
Jay B |
97 |
22nd December 2009 - 09:47 AM Last post by: Jay B |
Hi all,
I have a 99 Tiburon FX with a clutch slave cylinder in need of replacing. Does anybody know of a good tutorial site for this kind of repair? Or better yet, does anybody have a good link to a factory service manual? I would like to know what it entails and see if it's worth it to do it myself.
Thanks in advance,
Jay
Weed4All |
135 |
14th December 2009 - 05:59 PM Last post by: Weed4All |
Hi all! First i want to know what size are the front door speakers. My car dont have front speakers install and i want to buy 2 speakers but i dont know the sizes. Also if anybody knows the sizes of back door speakers will be usefull.
Secound i want to change dashboard lights but i dont know how many bulbs i need and what tipe of bulbs.. Thanx in advance!
Jethead |
112 |
13th December 2009 - 04:12 PM Last post by: jsinton |
My son is deployed to Iraq and I'm trying to fix his car so that when he comes back it will be running, can anyone tell me where the ground wire hooks up to the motor or frame from the battery pic's would be great
