Topic Title |
Replies |
Topic Starter |
Views |
Last Action |
hi all
does anyone know how to fit a tow hook to my 2007 Tucson
0 |
towt |
3 |
Today, 07:07 AM Last post by: towt |
XG 350 - The belt tension pulley bracket is broken. How do I go about replacing the bracket myself at home.
I changed the Alt. and was trying to tighten the belt. The adjustment bolt seemed to be frozen. I tried to use a pry-bar on the pulley to free it, but I broke the braket off. Now The braket that the tension pulley is attached to must be replaced. There are 4 bolts that appear...
0 |
louisjk |
31 |
4th October 2008 - 04:21 PM Last post by: louisjk |
Hi everyone
I have a 2001 xg ,just would like to know when petrol is low, and the trip computer says PETROL EMPTY ,should it beep aswell or is that it.
default/liebe011.gif' 'liebe011.gif' />
4 |
scorpion76 |
120 |
3rd October 2008 - 05:32 AM Last post by: Finny |
Hi All,
My Gradeur XG 3.0 is stalling at the lights. Engine just turns off. Dash lights are still on.
Also, when travelling at e.g 100kph, car tachometer starts to flicker up and down a few thousand revs (engine revs stay the same) and then car turns off at 100kph.
Took it to local Hyundai who had it for three days who cant locate the problem. (no fault codes being recorded)....
0 |
Grandeur_Mars |
31 |
2nd October 2008 - 07:43 PM Last post by: Grandeur_Mars |
Hi all, I bought a new air filter element thinking that fitting it would take about 3 minutes (like in the old days!), but it looks a bit more complicated and I don't want to damage anything.
The air filter is a large box with clips on the front edge and hinges at the back lower edge. Problem is the large intake hose which has at least one electronic sensor in it, is not...
2 |
Essex |
64 |
29th September 2008 - 06:36 PM Last post by: Essex |
Anyone interested in buying an 2000 Hyundai Grandeur 3.0L V6 140,000Km on the clock.
8000 ono.
7 |
grandeur 3.0 |
407 |
25th September 2008 - 08:23 PM Last post by: grandeur 3.0 |
Hi,
I have a 2000 Hyundai Grandeur and for some reason all of my power windows have stopped working. I suspect its a fuse that's blown, but i'm not sure where the fuses are located for the Power Windows and what type they are in order for me to replace.
I heard that if a power windows fuse has blown, that it may be due to one of the power window motors...
3 |
emsah7 |
203 |
23rd September 2008 - 04:07 AM Last post by: Artur |
Hello all,
Just did some cleaning of the throttle body and I wanted to clean the egr but; I am not sure of where it is!
Also, I would like to take my (Intake? on the front) manifold off to clean some of the grime. If I was to take the housing below the manifold off, would I need a new gasket?
Does the manifold need a gasket, or can I just pull that off and put...
4 |
2001GrandeurXG |
170 |
21st September 2008 - 07:27 PM Last post by: 2001GrandeurXG |
hi friends,
I have XG30, year 2000, 3L model. the car is bit wobbly when i speed to 40 - 60Km/h. after 70km/h is ok. what will be wrong? please help
thanks
Godwin.
9 |
chami0075 |
163 |
19th September 2008 - 05:28 PM Last post by: Getovait2005 |
Where is the fuel pump relay located ? I changed my fuel pump over the weekend due to the car stalling on low fuel. Pretty sure it was the fuel pump, so changed it. Both before and now I'm getting no static pressure, so now I suspect it's the fuel pump relay.
However the HMASERVICE website electronic schematics make no mention of a fuel pump relay in the engine bay. Is it...
0 |
Greywolf |
156 |
14th September 2008 - 06:19 PM Last post by: Greywolf |
I have an '01 XG300L, and as you probaby already know it is FULLY loaded. It's got a new motor and has 70k miles. New tires, and recent NC state inspection. Car runs great.
I'm into interesting trades, or $7200 cash. I am negotiable.
Let me know
Matt
3 |
85_305 |
200 |
13th September 2008 - 05:57 PM Last post by: 85_305 |
Ok, a small bit of pressure on the accelerator pedal and it jumps like anything. Is there a way to dumb down the pedal so I don't get a sudden jolt?
0 |
Pilot84 |
94 |
12th September 2008 - 07:30 AM Last post by: Pilot84 |
Hi all
I've got a problem with my 1999 XG, the fuel gauge has stopped working, My mechanic believes its the float and senders in the tank that have failed but he told me Hyundai kept sending him the wrong float (my car has a small float and Hyundai sent two so far that are too big) the cost of the part is extreamly expensive and I was wondering if anyone knows what part number the float...
1 |
billhodge |
141 |
10th September 2008 - 04:12 AM Last post by: Finny |
Hello, Im looking for any sites that have performance or apperance parts for a 2004 XG350L. Currently im looking for a cold air intake, throttle body, after market instrument cluster, spoiler and such. Anyone know of anywhere good to get stuff like this for this XG?
1 |
michieb34 |
155 |
8th September 2008 - 04:45 PM Last post by: Getovait2005 |
Hello all,
Alright ,
My grandeur is lacking power and acceleration. It has had the timing belt replaced recently, plugs, leads, spark plug seals (was leaking oil on top plugs), MAf sensor and Battery (is now the best bosch 68), oil/filter and a tune.
The car starts fine, sounds a little of time but runs ok. In first and second it seems to be fine...it's when...
11 |
2001GrandeurXG |
352 |
6th September 2008 - 08:13 AM Last post by: 2001GrandeurXG |
I've disconnected the power steering pressure hose at the pump and at the gear, and removed the bracket bolts. It should be ready to pull out. However, the hose gets hung up between where the steering gear and rear motor mount. Any tips on removing the hose?
1 |
wmcraftXG |
250 |
29th August 2008 - 05:43 PM Last post by: wmcraftXG |
I've read through the archives and the issue of DIY timing belt changes has come up and the recurring answer is always that the timing belts are a huge PIA and way more troublesome than other makes/models.
What exactly makes that so? Is it that there is so much stuff to remove to get to it, or something else?
I've got a ton of stuff off of my engine right now so that...
5 |
wmcraftXG |
392 |
24th August 2008 - 09:25 AM Last post by: montego |
I'm going to be upgrading the exhaust to .5" bigger than it is right now in the next few months, but I want to maintain the stock quietness is currently has.
Any ideas?
7 |
85_305 |
329 |
16th August 2008 - 09:08 AM Last post by: thafinestxg300 |
So: tranny shudder and hursh gear change.
Firstly find out the symtoms that mach with Your bad riding from hmaservice.com
Big % that it is caused by clogged or low resitance (or both) valve solenoid (attached to valve body). Every solenoid valve has its own function. You dont have to take tranny down to get valve-body unmounted from tranny.
I have had to change few...
0 |
Mihkel |
246 |
16th August 2008 - 04:06 AM Last post by: Mihkel |
My XG wants to lurch foward when stopped at a redlight especially with the ac turned on. The lurch isnt violent but more like being nudged from behind by another car. the tachometer flucuates when this happens. any ideas??? thanx
1 |
betz698 |
186 |
15th August 2008 - 05:33 PM Last post by: 85_305 |
Where can a nice cold air intake setup be found for these XG's. I've done a lot of searching, and I cant really even find one.. except one rather ghetto looking one that I dont care to spend money on to see if it works.
Any ideas or input? Or should i just find larger diameter tubing and clamp an open ended K&N onto the other end?
thanks
Matt
8 |
85_305 |
323 |
15th August 2008 - 05:30 PM Last post by: 85_305 |
So I found that my right side outer CV boot spilled it's guts and it's been clicking on turns. I'm now trying to remove the axle, but the connection at the intermediate bearing bracket won't let lose. I've pried the **** out of it to no avail and managed to mangle the dust shield and bearing bracket shield in the process. I'm about ready to take a small sledge and knock the...
5 |
wmcraftXG |
236 |
12th August 2008 - 02:20 PM Last post by: trev0006 |
hi ! default/57.gif' '57.gif' /> default/57.gif' '57.gif' /> i am new member here! I've got a Hyundai 2001 and i have just had a problem with the transition jumping from 5th to...
7 |
plumber |
873 |
11th August 2008 - 07:47 PM Last post by: pratick |
I have had my XG for about a month now and keep noticing a sound that's driving me crazy. Basically, I can hear it at very slow speeds. Mainly when I accelerate from completely stopped, or when I am slowing down and have almost stopped. I thought it was only when AC was on, but it's not. The best way to describe it is a grinding sound. Almost like a diesel engine or a noisy fan. It...
5 |
etazeta956 |
1,170 |
10th August 2008 - 10:06 PM Last post by: Qman |
Why does my rearview mirror keep angling down after hitting bumps, or bass hits hard and knocks it down? It's REALLY pissing me off!!
Matt
4 |
85_305 |
372 |
5th August 2008 - 11:03 AM Last post by: 85_305 |
Well long story short, since day one of owning this car, it's been constant cels' and things breaking. Not cheap things, either.
I'm the second owner, the previous owner has a 100k 10year factory mile warranty, the a pile of receipts of repairs a mile thick. For one, this car has sludge at 88k miles. It actually just turned like 102k miles.
Well anyways I've had a...
34 |
85_305 |
697 |
4th August 2008 - 08:11 PM Last post by: 85_305 |
What does mean dtc code P1155? My speedometer stops on 140km/h and 3000rph....it looks like max speed...and it pulse...help please....sorry for my English default/' '' />
0 |
Evaldaslt |
219 |
3rd August 2008 - 07:02 AM Last post by: Evaldaslt |
Will a 3.5 bolt directly up in place of my stock 3.0l? The 3.5 has a lot more power so I'm thinking about picking one up.
How is gasmileage on the 3.5 as opposed to the 3.0l?
Thanks for the help
Matt
0 |
85_305 |
226 |
2nd August 2008 - 10:49 PM Last post by: 85_305 |
With your XG's? Just curious. I average a solid 21mpg in the city, and anywhere from 26-32mpg on the highway.. about 70-75 w/ no ac on is about 32mpg.. 80mph w/ the ac on is around 26-28, depending.
What do you guys get?
Matt
6 |
85_305 |
363 |
31st July 2008 - 05:42 PM Last post by: 85_305 |
Hi guys,
Just wondering the if anyone knows the distance between the mounting bolt holes of your XG front brake calipers?
Cheers
0 |
AlexS |
203 |
29th July 2008 - 04:20 AM Last post by: AlexS |
Hi, the check engine light has come on. what should I be looking to replace? where should I start?
2001 XG
11 |
Pilot84 |
594 |
24th July 2008 - 08:23 PM Last post by: Pilot84 |
I've heard that these cars have sludge problems? Why? And what causes it in these cars?
How can you fix it?
7 |
85_305 |
327 |
21st July 2008 - 02:40 PM Last post by: 85_305 |
hello does anyone know about a malfunction indicator light that has come on in my xg30/xg300 I have just bought the car today and the light came on after 30 miles of motorway driving back home. Just hope its not costly and if anyone knows that would be great! i love the car, it looks great and was reasonable so would be upset if it was a big x
3 |
orla |
553 |
17th July 2008 - 12:04 PM Last post by: montego |
How many miles should you change your plugs on the XG's? And which is the best kind to swap them out with?
Are stock suffice? Or is there a better alternative as per aftermarket?
Matt
4 |
85_305 |
417 |
15th July 2008 - 04:11 PM Last post by: 85_305 |
I notice that sometimes upon accelerating from a stop, the car shudders like crazy, then out of nowhere takes off like a bat out of ****.
What is this?
My cel is on btw
13 |
85_305 |
335 |
14th July 2008 - 09:19 AM Last post by: 85_305 |
When I sit in traffic w/ the ac on, the idle will drop a few hundred rpm, then go back up. Just randomly. It's not all the time. Only sometimes. But it's still annoying.
Any ideas?
Matt
2 |
85_305 |
268 |
13th July 2008 - 08:21 PM Last post by: 85_305 |
I've done some browsing on this site in the past, and noticed that someobody who got an exhaust and intake for his XG was getting like 37mpg highway??
My XG is my highway and travelling car. I take it on trips from NC back home in NY, so I'm trying to get every ounce of better gas mileage i can. This car fits my requirements for a travelling car, I just want to squeeze a bit...
0 |
85_305 |
261 |
13th July 2008 - 12:01 PM Last post by: 85_305 |
Hello every one.I have Hundyai XG2001 95000 miles. Last week my check engine light becomes on. When i checked the code it says P0720- O/p speed sensor. I checked with pepboys they says the out put speed sensor is fine,transmission fluidis balck so check with Amaco. i checked with them they says that O/p speed sensor is not able to reconize the speed becuase of some metal paricles in transmission...
5 |
pravin.agarwal2 |
344 |
12th July 2008 - 08:10 AM Last post by: pravin.agarwal2 |
The blower doesnt work, but it works just fine when connected direcltly to the accu.
But in the car the blower gets 10V only when fan speed is 4, but the fan still aint working... with speed 3 , 2 and 1 the voltage is 0V and of corse fan aint working.
Fuses are good.
So is it a relay or switch or what?
6 |
Mihkel |
415 |
12th July 2008 - 07:17 AM Last post by: Mihkel |
I notice that if I have cruise control set, and I come up to even the slightest hill, the car will do a downshift and just cruise at like 3-3.5k rpm's.. even after the hill diminishes and it's flat surface.
The car has decent power.. even in 5th in overdrive (at btw), but why such a hasty downshift??
Matt
2 |
85_305 |
251 |
11th July 2008 - 07:26 PM Last post by: 85_305 |
The inside of the headlamps is staining and looking rather pooey.. how can that be cleaned? I can't seem to open up the headlamps w/out breaking things. And I'd rather not take the whole assembly out and mess up the alignment of the lights.
Any ideas?
Matt
4 |
85_305 |
327 |
11th July 2008 - 03:29 PM Last post by: 85_305 |
Car: 1999 Hyundai Grandeur XG
Problem: Transmission gets stuck in 3rd gear.
Explanation:
I will be driving along in 5th gear when suddenly BAM i get a huge jerk and my car is RPM'n at 4K and im now stuck in 3rd gear. I can use my tip-tronic to get down to 2nd gear but thats it. My only option is to avoid an accident when ever it happens...
6 |
JustWantHelp |
591 |
10th July 2008 - 12:49 AM Last post by: richardpt |
I was wondering how much performance difference would putting 4 new hi-flow cats on the XG make.
I'm thinking it will be a large difference, since the stock ones are always really restrictive, and since there is 4... should be a big improvement right?
Thanks all
Matt
0 |
85_305 |
229 |
9th July 2008 - 06:32 PM Last post by: 85_305 |
I bought a used 2002 XG350 and it came with a single key and no key fob. If I picked up a keyfob online and programmed it or had it programmed, would it be able to work with my car? Thanks,
1 |
wmcraftXG |
268 |
5th July 2008 - 08:24 AM Last post by: montego |
My needs a few items to get it into order. The check engine light came on and threw a DTC code P0350 - "Ignition coil primary/secondary circuit malfunction."
It looks like there are three coils, each driving two cylinders. I do not get DTC codes indicating misfires on any cyls. If I did I suppose I could just swap coils around to ID the bad one.
Any hints on where...
1 |
wmcraftXG |
378 |
5th July 2008 - 08:23 AM Last post by: montego |
Went to start my '04 GX350L after filling the tank up from a day of driving and there was NO power - no lights, no radio, no nothing! I popped the hood to check battery (both cables are tight, very tight) and then the car started up no problem. All the presets went back to factory defaults and the radio had to be reprogamed. I was able to start and drive the car no problem for a couple...
1 |
94xg350l |
277 |
1st July 2008 - 12:01 PM Last post by: montego |
Besides the increased capacity, what differences is there between the two engines ? How many of the parts are interchangeable ?
Thanks all.
2 |
Greywolf |
449 |
28th June 2008 - 03:35 AM Last post by: Greywolf |
Alright so on my way home i blew my amplifier fuse for my subs and now when i stop at a light the engine speed drops than goes up to about 1500 rpm than down than back up and eventually stalls. I can do the left on brakes, right on gas but that sucks.
The weird thing is, when its cold and i start it, it will be fine. Put it into gear without moving, good. Let off the brakes and crawl,...
1 |
mayer486 |
322 |
27th June 2008 - 05:00 PM Last post by: mayer486 |
The XG350 has what looks like a rear tow hook connected to the gas tank?
Does anyone know the purpose for this? I want to tow a small car for a couple miles and was wondering if I could just hook a tow rope to that hook on the rear. Any thoughts?
Thanks,
Mike
4 |
mpmiller37 |
330 |
27th June 2008 - 12:34 PM Last post by: mpmiller37 |
(1) I have an intermittent problem with my remote locking on a 2000 Grandeur XG. The problem is that occaisionally when I press the remote, the doors lock but the lights do not flash and I suspect that the immobiliser does not arm. I have 2 remotes, I have replaced the batteries in both but both will give the same problem.
I suspect that I have a dirty connection or a dry joint somewhere on...
2 |
mikeann |
296 |
25th June 2008 - 06:24 PM Last post by: mikeann |
