Topic Title |
Replies |
Topic Starter |
Views |
Last Action |
| Announcements |
Announcement: Upgrade Complete! |
AdminAF |
1861 |
Last post by: AdminAF
| Forum Topics |
5
help |
1,549 |
12th December 2004 - 08:22 PM Last post by: Dr. Hundi |
Can anyone help me? Had my 92 excel to numerous mechanics and auto electricians no one knows what the problem is. I've had the distributor cap and leads replaced, injectors and fuel filter cleaned, numerous parts (electrical) replaced sensor on distrib replaced, even to the extent of placing 250 ml of metho into the petrol thinking it was water in the tank!!!!
This problem is only intermintent but has now been going on for 6 days in a row!!
When driving when the car is not excelerating it jumps about as if it is choking. Idle is rough but does not stall.
At my wits end with this one!! Had enough of mechanics saying its this and that costing me a fortune need help desperately.
vern |
1,007 |
12th December 2004 - 08:19 PM Last post by: Dr. Hundi |
im looking around to see if there were any problems
in particular to a 1992 excel as in recalls
or any other problems especially mechanical
it has 200,000km on it now
not burning or leaking at all
9
Eddo |
1,073 |
12th December 2004 - 08:15 PM Last post by: Dr. Hundi |
Hi everybody....just bought a '94 LS auto which runs well apart from a big jolt between gears sometimes. I read that this may be due to a 'missing or defective air exhaust plug' - I have no idea what this means or where to check it. Can anyone help or suggest any other cause please?
BSAMOE |
1,451 |
1st December 2004 - 12:42 PM Last post by: gordo |
I just bought a 1988 Excel which was used Heavily. I am wondering what the Gas Mileage should be I am curently getting 220 to the tank and I fell I should be getting more. I am going to change the spark plugs and clean the carb but... I don't know if that will solve my problem. Please help!!!!!!!!!!!!!!!
0
asdhami |
656 |
28th November 2004 - 07:26 AM Last post by: asdhami |
Dear Friends,
I drive a Hyndai Excel Sprint , 1999 model .Was planning to change the spark plugs but am not able to find the right spanner as the plugs are deep and the spanners available in the market don't go down in the hole. I have bought Champion RN9YC4 plugs. Are they the right ones please?
sparky1958 |
1,094 |
23rd November 2004 - 03:42 AM Last post by: Dr. Hundi |
I have an 1997 hyundai excel with no spark it appears to be ecu because i have only 0.6volt rather thanof 5volts at crank angle sensor and the same at ecu with sensor un plug .Has any one had to replace ecu on one of the models?
Excellerator |
722 |
18th November 2004 - 08:10 AM Last post by: duke |
I've got a couple problems:
1)The gas gauge on my 1993 Excel does not go any higher than the 3/4 mark, even when full. Recently it's been intermittent: sometimes it won't even work, but most of the time it does.
2)The temp gauge, even when the car is warm, does not go much higher than the white mark near the "C". We've replaced the temperature sensor (Dad calls it a "sender") that sends information to the temp gauge. Sometimes it works (but rarely does the needle hit the "middle" of the gauge.)
Any help would be greatly appreciated!
~Scott
excel |
2,034 |
7th November 2004 - 02:27 AM Last post by: 801Excel |
can someone please help me find A new Engine For my 91 Hyundai Excel
11
Bear |
1,935 |
5th November 2004 - 01:46 AM Last post by: Dr. Hundi |
1991 Excel - starts fine when cold but after driving and it warms up it may or may not start, depends on what mood it's in. Have had coil pack replaced, etc. It turns over but just won't start, let it sit and come back after it cools, then it usually starts. Acts like it's not getting any spark. Any help is appreciated!
darrenhendricks |
3,225 |
29th October 2004 - 01:54 PM Last post by: gordo |
I recently bought an 87 Excel POS for $200. The damn thing keeps blowing the Fusable link on the cahrging system. Apparently it did the same for the prevous owner. First, How many amps is it supposed to be rated at? There was a 30 amp in there, I replaced it with a 40 amp. I know that many charging systems are rated at up to 60 amps and the last owner may have put the 30 amp in by mistake. Second, if the 30 amp IS correct, where can I get a wiring schematic so I can trace down the problem? aside from buying one rember that $200.00 Canadian I paid for it.
0
Sexpochamp |
615 |
26th October 2004 - 04:50 AM Last post by: Sexpochamp |
hey how yous going its my first time in here so yeah, all i really wann know is where can i go and get a front leftside guard for my excel.
burrinjuck |
680 |
22nd October 2004 - 03:39 AM Last post by: Dr. Hundi |
[SIZE=7]
Hi all. Very new @ this stuff. Trying to remove heater fan moter from RH drive eXcel and have become stuck & run out of light and come in.
I wish to remove the fan motor as there is a knocking sound when the fan is run @ high speed so I guess some sound deadening material has been draw into the drum housing. Does any body have an efficent way of getting the motor out short of setting fire to the car?
Burrinjuck
0
BSAMOE |
1,034 |
7th October 2004 - 09:15 AM Last post by: BSAMOE |
Don't seem to be getting the gas mileage I think I should be getting. Right now I'm getting around 22 mpg I should be getting better than that for a 4-cyl. What might be the problem???
0
haywire |
613 |
6th October 2004 - 10:55 AM Last post by: haywire |
My 88 hyundai excel needs to have the kick down cable replaced and I`m not sure how to do this , can someone fill me in on this ?
0
help |
1,006 |
10th September 2004 - 09:00 PM Last post by: help |
Have post under excel ls needing help.
