Topic Title |
Replies |
Topic Starter |
Views |
Last Action |
Hi all,
When I pulled the glove compartment out of my 1992 Hyundai Excel GLS I discovered
a round plug (somewat like a PS/2 plug on your comp, but with more pins); can anyone
tell me what it is and what it's for (besides hanging around -- see Picture 1)?
Also, on the console there are two buttons for fog lights and rear windshield heating, but
when...
5 |
xwiggen |
614 |
20th June 2005 - 06:03 AM Last post by: xwiggen |
I need some help, the engine lost throttle control and would only idle. till the key was turned off. after that i could crank the engine over but no start. since then i have checked the ecu for codes. no abnormal codes. just the normal ecu code, high/low. i do not have a multiuse tester, so i probed the connector with my analog multimeter. i have since been chasing my tail, mighty fast too, ...
12 |
westernfleetsupply |
1,054 |
19th June 2005 - 02:58 PM Last post by: westernfleetsupply |
Found this info thru a mitsu based forum and it helped me with engine problems
check out this link to see if it helps anyone else
http://avproecm.com/process1.htm
1 |
gjaym |
876 |
18th June 2005 - 01:26 AM Last post by: kolijlumni |
Hey all,
Can someone please help me. I am looking for what the brake band in the 4 speed auto is on a 1994 X3. I have just put a new band in if there is any difference.
Also, if anyone is looking for parts on one of these boxes, let me know as I can source parts quite cheaply.
Thanking you all in advance. ...
1 |
benholland |
419 |
13th June 2005 - 06:16 AM Last post by: benholland |
Ok, Just bought car like a month ago to later put a 4G63 Engine in it just waiting to build up some more fundage, so in the process i been cleaning it up under the hood and just overall hooking it up here and there.
But today i was sitting idle and when I went into reverse i heard a clanging noise against the ground I look under the car and laying on the ground is the wheel to my water...
3 |
Thelonewolf |
504 |
11th June 2005 - 06:57 AM Last post by: montego |
the side moulding on my car is steel and is rusting out can
I just take it off and replace it or do I have to get that side repainted?
also does any one know how to remove it?? default/57.gif' '57.gif' />
4 |
excelent94 |
549 |
2nd June 2005 - 08:34 PM Last post by: excelent94 |
hey guys how you goin...im jus wonderin does anyone know where i can source some clear tail lights for my xl..been lookin for them for ages but cant seem to find any.thanks
0 |
XXL |
417 |
31st May 2005 - 06:11 AM Last post by: XXL |
sisirawijeweera |
12th May 2005 - 07:59 AM Last post by: hyundai tech |
I know my excel doesn't have an stand alone IAT sensor and that it is built right into the MAF sensor. My question is which wire is the one for the iat signal because my friend gave me a zero gravity module. the module is suppose to distort the signal going to the computer and telling it the air is colder than it actually is (it claims more hp) we will see.
5 |
doc182 |
1,002 |
28th April 2005 - 06:38 PM Last post by: doc182 |
Hi, can someonne tell me how to do self diagnostic code check on my 92 execl. thank you
3 |
lyskenge |
733 |
24th April 2005 - 07:56 PM Last post by: doc182 |
Hi everyone, had a strange experience with my Excel today: after driving it to the shops I came back to the car to find coolant all over the floor under the car. On investigation the coolant bottle was overflowing and the coolant had leaked from the overflow. This is odd because just the other day I filled the reservoir, but only up to the FULL line, so I cannot understand why it overflowed. ...
2 |
Eddo |
679 |
21st April 2005 - 09:44 AM Last post by: doc182 |
MY '94 excel is burning super rich as well all of my sesors are reading something rediculous so iam in desperate need of a replacement ECM the only problem is that i cannot find anything at a resonable cost if anyone can help in this catagory your help will not go unrewarded, my ECM model is 39110 24575. Please help.
ps. also looking for a stock radio for the old beast so any...
12 |
jtmcintyre |
926 |
20th April 2005 - 03:49 PM Last post by: duke |
when should i go for engine oil change(hyundai Excel 93-94)
according to the manual book of car
after 7500 kms for certain cases(travel in mountains, usually drive for short distances, etc)
or after 10000 kms for general case
i change it after 7000 kms. is it ok????
3 |
asad |
558 |
9th April 2005 - 05:45 PM Last post by: skyclone |
My daughter has a 96 excel that at about 1700 revs in every gear it has some sort of vibration type of noise. Below or above 1700 the niose is not evident.IN neutral it does it as well.Was thinking maybe the cat. The car has travelled 196000 klm,s and is in EXCELent condition.Any help would be appreciated.
Thanks in advance Rick
2 |
rickstar56 |
440 |
5th April 2005 - 09:38 AM Last post by: rickstar56 |
Hello, I need to replace my front oil seal on 88Excel. The oil is ''pissin'' out through pulley, belt area at front of engine. Anybody changed one of these seals? Please tell me how much work to be done. Looks like timing belt needs to come off and lots more work. Thank you default/sad.gif' ...
3 |
skyclone |
456 |
3rd April 2005 - 05:10 PM Last post by: skyclone |
hello all,
Can anyone help me find an online schematic so i can change my rear main seal and how easy or difficult would it be
3 |
ajsdad262002 |
540 |
3rd April 2005 - 04:36 AM Last post by: duke |
How easy is it to replace a rear main seal on a 93 excel? i'm losing oil bigtime
4 |
markntami |
698 |
2nd April 2005 - 09:49 AM Last post by: doc182 |
I drive a hyundai excel 1993, 4 speed manual,its stock ,i have just replaced waterpump i had to take timing belt off to get to it.In the prossess of replacing waterpump my bottom timing gear has moved could anyone tell me where abouts the notch on bottom timing gear should be
1 |
bert_beetle |
970 |
2nd April 2005 - 04:54 AM Last post by: duke |
Haai you all,
If got a problem with my hyundai exel 1.3 from 1995 wich is running on liquid petrol gas and on gasoline.But when im driving on lpg and i come to a stand still and i want to drive off again, the engine stalls and i hear a bang. default/ohmy.gif' 'ohmy.gif' />
If been told...
2 |
Mr.Hide |
526 |
28th March 2005 - 08:26 PM Last post by: Mr.Hide |
Hi all,
Firstly, thanks for taking the time to read this.
My Hyundai Excel 1996 runs fine. However, on a semi regular basis the engine will just lose power and then resume as normal. It happens at anytime. I.e. Cold, warm, freeway or backstreets etc. I can have my foot to the floor and the engine does not respond. Before you comment on the throttle position sensor, it's...
5 |
Capt Nemo |
775 |
28th March 2005 - 06:06 AM Last post by: Capt Nemo |
I have a 1992 Hyundai excel that I have taken care of for almost 12 years. I have no major complaints, amazingly. So what I have is when I start the car in the morning it runs just fine, however when I back up out of the driveway the idle lopes or seems to want to almost stall. It does it regardless of whether or not I have lights on or not. I also drive down the road and as soon as I let off the...
8 |
Falconrob |
979 |
19th March 2005 - 07:38 AM Last post by: duke |
The story starts when i get home from basic training. My car wouldn't start but cracked. I completely changed the electrical system including coil and all. Nothing. Then i learned that my ECU was fried. I visited a junkyard and got another ECU only probably was my stock ECU was a Z29 and they gave me a Z31. It worked for awhile, then I started to get a lack of power in the engine. I can...
6 |
Samueru |
1,285 |
18th March 2005 - 12:23 AM Last post by: ramachandran_ips |
would a 1986 Hyundai Excel engine and trans fit in a 1994 Excel? Also would it be difficult to put a manual transmission into it when it was originally an automatic?
thanks
2 |
gijim |
480 |
14th March 2005 - 02:53 PM Last post by: montego |
Hi guys, great forum you have here. I was just wondering if anyone can tell me where i would fine the engine number on a Hyundai Excel manufactured in jun 1997?? It's a car from australia and i can't find what the engine number is. I really hope someone knows this as i need it for registration purposes.
Thanks in advance for any help.
1 |
merchant |
454 |
2nd March 2005 - 11:00 AM Last post by: VALKYRIE YB70 |
Hi there, we bought a 98 Excel twin cam with 130,000km on it not long ago. It has a noise in the engine that I thought was the hydraulic lifters, (HLA's). I am a trained mechanic looking for some helpful advice before I make a decision as to what to do, (whether to pull the engine apart or buy a 2nd hand motor). The noise is like a rattle or a tapping and it gets faster/slower with engine...
15 |
ChrisV |
1,233 |
20th February 2005 - 09:21 AM Last post by: VALKYRIE YB70 |
Anyone out there know if oil pressure switch is a problem with 88 excel?1.5L I opened hood and there is oil all over the alternator, and the drivers side of engine is ''soaked'' with oil. I started driving to work the belt was screaching and alternator started cutting out so I turned around and took my Jeep to work. It is cold out and because engine is so dirty with oil I can't...
7 |
skyclone |
685 |
18th February 2005 - 04:31 PM Last post by: skyclone |
hi,
i have HYUNDAI Pony Excel 93.
i want to know about smoke which only comes out in winter (Especially when raining) WHY?
is there any problem with the engine?
i bought that car Zero meter.
reply
6 |
asad |
609 |
18th February 2005 - 09:13 AM Last post by: duke |
Hey all, I am the proud owner of a 1993 Hyundai Excel ( 2 door hatchback ).
I have a few problems that came with the car from the previous owner.
1. Front right turn signal does not work. Fuses are okay, wire is intact, and bulbs were replaced.
2. Body damage to front right signal area.. No idea of how to get fixed, replaced, etc.
3. Gas gage does not...
1 |
RabidLockerGnome |
835 |
17th February 2005 - 09:32 PM Last post by: RabidLockerGnome |
I have a 91 Excel 1.5 multi port that is running very rich at idle. Have replaced injectors, air flow sensor,temp sesor and throttle position sensor. It has 133000km on the engine. What am i missing?
91 Excel
91 excel running rich,real rich
4 |
helpmyhyundia |
874 |
17th February 2005 - 03:38 PM Last post by: helpmyhyundia |
I have a 93 GS sprint, and something seems to b wrong with the electrics. The car had problems with surging but it was an exhast censor. The headlights appear to be dim now, and i've even taken the headlight covers off. The battery has been changed to a sealed lead battery and it always works. The aftermarket sound system (not my work) has been slowly cutting out so i have 1 raspy speaker in...
0 |
lx003 |
529 |
15th February 2005 - 11:19 PM Last post by: lx003 |
I have a 99 Twin Cam Excel and wanting to do a bit of work to it, any suggestions on where i can have a look at web sites for body kits and also would like iinfo on what other people have done to their excels.
Cheers default/thumbsup.gif' 'thumbsup.gif'...
2 |
Ms Funky |
687 |
9th February 2005 - 09:55 PM Last post by: VALKYRIE YB70 |
I have a 1994 Excel. My check engine light keeps coming on. I did a diagnostic check and the code for the barometric pressure sensor came up. I can't seem to find it in my Haynes manual anywhere. Is there another name for it or can anybody tell me where to find this sensor on my vehicle?
2 |
94excel |
544 |
2nd February 2005 - 03:49 PM Last post by: 94excel |
Does anyone know what is required to upgrade my standard '93 excel 1.5Ltr 4g15 mitsibishi engine with a 1.6 Efi or 1.8 efi mitsubishi engine of the same vintage? From what I can see it should be a straight drop in but if anyone knows what is invloved, please let me know.
Thanks, Ben
1 |
benjamin |
559 |
31st January 2005 - 07:41 AM Last post by: VALKYRIE YB70 |
I have just recently bought a 97 GX Excel and i find that even when i am in forth at 3000 revs it labours really bad. So much so it is causing people to look at me which is so embarrasing.
At first i thought it was because i am used to older cars but i have had it about a month now and it still seems to do it, especially when the fuel tank is under half. A friend told me that u just...
1 |
Kellmo11 |
492 |
30th January 2005 - 06:56 AM Last post by: duke |
Hi everyone. My wife's 1994 Excel occasionally blows out some blue/black smoke when it's started from cold. It does not smoke apart from that and does not do it every time. I don't think it is worn rings as it is intermittent. It seems to run ok ...any ideas?
8 |
Eddo |
1,066 |
25th January 2005 - 10:56 AM Last post by: duke |
I have a mate who has in his possession an 96 model excel.
He wants to increase its performance as much as is humanly possible for the as cheap as possible.
he alread y has a k and n panel filter and a sports exhaust with out extractors but is lookin to get them in the near future.
is there anything else he can do ...
2 |
VLACS |
641 |
24th January 2005 - 09:43 PM Last post by: VALKYRIE YB70 |
anybody know where i could get custom seat covers with the hyundai logo on it? or custom floor mats... or just anything in general that has the hyundai logo on it?
0 |
hyundai_excel |
627 |
20th January 2005 - 09:10 PM Last post by: hyundai_excel |
I recently had my (up until now) very reliable 91 hyundai excel die on me. I took it to a shop and they took a week to fix it-- and end result was it just needed a tuneup. The original problem was that it would start up, but then die out when i gave it any gas. They fixed that fine-- that was a week ago.
I tried to start it up this morning and the engine just turned about 10 times. ...
6 |
Aeurix |
1,349 |
17th January 2005 - 02:16 AM Last post by: Dr. Hundi |
laorar7 |
22nd December 2004 - 08:58 PM Last post by: laorar7 |
please if any one know any site to dowenload the owner's manual of the excel gls 1994 please tel me it
a_ragab _itp@hotmail.com
3 |
a_ragab_itp |
1,312 |
20th December 2004 - 04:46 AM Last post by: a_ragab_itp |
Started the car yesterday ...it ran fine idoled fine at around 950...stopped at a store on my way to work and went to start the car..it fires up right away but as soon as i take my foot of the gas it dies right away. I had to two foot it home. Car is a 89 excel auto carburated. I though maybe a vaccum line fell of somewhere i checked them all took of the air filter but cant find one thats not...
9 |
trikerjr |
930 |
15th December 2004 - 04:01 AM Last post by: Dr. Hundi |
Hello folks and may I say this is my first post. I just bought an 88 Excel with only 68000 mlies on it. It is in very good shape starts easy but lacks power. The local garage says the ''front'' cat converter is clogged, and I noticed the rear is no longer there. My ? is'' has anybody here tried to hollow out the front converter on these 1.5 litre motors. It looks like a...
7 |
skyclone |
1,061 |
13th December 2004 - 10:09 AM Last post by: skyclone |
default/unsure.gif' 'unsure.gif' /> Can anyone help me? Had my 92 excel to numerous mechanics and auto electricians no one knows what the problem is. I've had the distributor cap and leads replaced, injectors and fuel filter cleaned, numerous parts (electrical) replaced sensor on...
5 |
help |
1,537 |
12th December 2004 - 08:22 PM Last post by: Dr. Hundi |
default/rolleyes.gif' 'rolleyes.gif' /> im looking around to see if there were any problems
in particular to a 1992 excel as in recalls
or any other problems especially mechanical
it has 200,000km on it now
not burning or leaking at all
2 |
vern |
983 |
12th December 2004 - 08:19 PM Last post by: Dr. Hundi |
Hi everybody....just bought a '94 LS auto which runs well apart from a big jolt between gears sometimes. I read that this may be due to a 'missing or defective air exhaust plug' - I have no idea what this means or where to check it. Can anyone help or suggest any other cause please?
9 |
Eddo |
1,056 |
12th December 2004 - 08:15 PM Last post by: Dr. Hundi |
I just bought a 1988 Excel which was used Heavily. I am wondering what the Gas Mileage should be I am curently getting 220 to the tank and I fell I should be getting more. I am going to change the spark plugs and clean the carb but... I don't know if that will solve my problem. Please help!!!!!!!!!!!!!!!
4 |
BSAMOE |
1,347 |
1st December 2004 - 12:42 PM Last post by: gordo |
Dear Friends,
I drive a Hyndai Excel Sprint , 1999 model .Was planning to change the spark plugs but am not able to find the right spanner as the plugs are deep and the spanners available in the market don't go down in the hole. I have bought Champion RN9YC4 plugs. Are they the right ones please?
0 |
asdhami |
637 |
28th November 2004 - 07:26 AM Last post by: asdhami |
I have an 1997 hyundai excel with no spark it appears to be ecu because i have only 0.6volt rather thanof 5volts at crank angle sensor and the same at ecu with sensor un plug .Has any one had to replace ecu on one of the models?
2 |
sparky1958 |
1,069 |
23rd November 2004 - 03:42 AM Last post by: Dr. Hundi |
I've got a couple problems:
1)The gas gauge on my 1993 Excel does not go any higher than the 3/4 mark, even when full. Recently it's been intermittent: sometimes it won't even work, but most of the time it does.
2)The temp gauge, even when the car is warm, does not go much higher than the white mark near the "C". We've replaced the temperature...
1 |
Excellerator |
706 |
18th November 2004 - 08:10 AM Last post by: duke |
default/mellow.gif' 'mellow.gif' /> can someone please help me find A new Engine For my 91 Hyundai Excel
1 |
excel |
1,945 |
7th November 2004 - 02:27 AM Last post by: 801Excel |
