Topic Title |
Replies |
Topic Starter |
Views |
Last Action |
hey i just got a hyundai excel 94 model 3 door..
and the dash cluster is stuffed so i got a new one but the kms r no were near the old ones. and i want to turn them forward to match my old one. does any one no how to turn them forward by any chance?? all help would be appreciated..
thx pj
0 |
1sykxl |
359 |
17th August 2007 - 10:45 AM Last post by: 1sykxl |
i was wondering if anyone knows of anywhere to get a stiffer(thicker) front sway bar for a '93 x2 excel sprint? if not is there one from any other hyundai's that would fit and stiffen the car up?
10 |
tkjsprint |
519 |
13th August 2007 - 10:30 PM Last post by: wheel_of_steel |
i just installed a new stereo to my 1996 exel. all going well until when i went for a drive tonight the dash lights didnt work. did i short something? did the dash lights connect to the old stereo? any help would be great.
1 |
timtim |
314 |
13th August 2007 - 02:28 AM Last post by: tkjsprint |
ok i'm kinda goign crazy because i only bought this car 3 months ago after having major engine problems with my former car a mistubishi galant and decided to count my losses and get rid of it for a younger car.
The xcel has been great until the last week, when randomly it will loss nearlly all power while driving, almost like it is about to stall and then 3 times now it has done this,...
5 |
Honey_Xcel |
1,032 |
11th August 2007 - 07:30 PM Last post by: Honey_Xcel |
[B]HI I hope someone can help..we installed a new timing belt, and tensioner on a 92 HYUNDAI EXCEL..the previous shop messed up..no bolt was on the RIGHT side of the tensioner..it came loose..it chewed up the flat spot the tensioner bracket sits on(where the tensioner bolt goes thru it)..we took a dremel and ground this spot down as it was gouged up from loose tensioner..had no choice..
The...
1 |
hook |
654 |
11th August 2007 - 04:29 AM Last post by: kurtdaniel |
Can anyone shed some light on my odd little car?
I have been driving an excel 93 hatch for about 3 years now, and it is a great machine.
Lately, however, the horn has been making little honks all by itself, which is starting to become a bit of a problem. (people keep thinking I'm some sort of aggressive driver!)
It seems to happen when I start the car up,...
2 |
eskim0j0 |
490 |
10th August 2007 - 11:16 AM Last post by: raver4lyf |
My 1996 Excel GLS has a cracked dashboard. It seems that many Excels one sees in car parks, etc have the same problem..some more so than others.
Anyone know of a fix or have the same problem?
cheers
zambuk
3 |
zambuk |
567 |
9th August 2007 - 03:09 AM Last post by: tkjsprint |
Hi,
Could someone help with how to remove the window winder handle?
I have tried to find if it is held in with a circlip but can't see one. There is no removable
centre to the handle so it can't be held on by a screw.
I tried to use the Hmaservice site but no luck.
2 |
fx48215 |
420 |
9th August 2007 - 03:02 AM Last post by: tkjsprint |
just wanted to know if n e one know if a 1989excel had a 4x125 or 4x100 spacing pattern or if any one knew how to tell wat spacing they are thanks for your help default/' '' />
0 |
aaron001au |
233 |
28th July 2007 - 05:28 AM Last post by: aaron001au |
front brakes get smokinhot when i dirve over 40 for 10 miles. Any one ever had this problem
Help
94 excel brakes get smokin hot
3 |
c-man94 |
287 |
26th July 2007 - 11:33 AM Last post by: byronguidry3732 |
does any1 no how to take of the middle dash were the cd player and aircon controls are located? in a 2000 twin cam excel.. thanx
1 |
~twent~ |
254 |
26th July 2007 - 02:48 AM Last post by: hyunnychub |
So, I need to chage the gearbox, and I'm stuck with the driveshafts. How to get them out from the tire side?
EDIT: And the car is -91 Pony (Excel)
3 |
Topini |
528 |
18th July 2007 - 01:15 PM Last post by: Pretender |
Ok.... the A/C in my excell stopped working.
When you press the little button on the center dashboard the green light does not come on and nothing happens. I have checked the Relays & fuses and they are ok. If you manually engage the relay (bridge the contacts ) in the fuse box under the bonnet it works, so I know the motor & pump is OK. Also this should mean that the relay is OK too...
4 |
Bongo |
437 |
16th July 2007 - 11:37 PM Last post by: ausGeoff |
Not sure if there is a demand for these cars, but my wifes 94 Excel died. Probable transmission failure. Up until now its been running great. Burns a little oil, but other than than that its in good shape. No body damage of any sort, seats are a bit stained, but interior is decent shape as well.
Its a 94 excel 4dr sedan in the standard green color. Has a new power steering pump...
5 |
94excelRhodeIsland |
1,518 |
16th July 2007 - 06:34 PM Last post by: hook |
Hi,
Helping a friend do this on the weekend.
Can anyone tell me how to:
1. Remove the ignition barrel on a 95 excel?
2. Remove the door lock barrel on the same (2 door) 95 excel?
Thanks,
Damian
0 |
damianf |
597 |
12th July 2007 - 09:42 PM Last post by: damianf |
Hi, I have a Hyundai excel 93. I am having a problem with something in the filter its like a sensor or something like that, when a connect it the car doesn't works good and when I disconnect it it will work better but it will blow a lot of black smoke. The piece worked good until last month. What can i do? What is the name of this piece
1 |
Gerrito225 |
397 |
10th July 2007 - 08:55 PM Last post by: HarvsXL |
Hi... i have a 1989 excel and i would like to know if any one knows how to change the cv joints on them as i have no clue so if any one could help that would b great
2 |
aaron001au |
305 |
10th July 2007 - 04:36 PM Last post by: aaron001au |
1 |
ausGeoff |
424 |
10th July 2007 - 02:24 PM Last post by: byronguidry3732 |
I recently purchased a 1990 Hyundai Excel. I just moved to CA from out of state and although I knew I had to get a valid smog certificate with the vehicle, I didn’t realize that a smog certificate was only valid for 90 days. Apparently, neither did the seller, because he gave me one that he thought was good until September 2007 (it was issued in Sept. of 2006), which is when the vehicle’s...
0 |
balgownian |
537 |
9th July 2007 - 05:54 PM Last post by: balgownian |
Hello All. I purchased the above vehicle for my daughter and we decided to take it on a long trip (1000 kms). About halfway through the trip during hard acceleration, the car lost power until I backed my foot off the gas pedal and then it coasted alright. If I attempted to push the gas pedal down again, it would die until I eased off. At the halfway point of the journey I replaced the fuel filter,...
11 |
alfy12 |
1,626 |
25th June 2007 - 12:16 PM Last post by: pdejongh |
Hi, can somebody please help me, I just received a used Hyundai Excel 94, its a 4 door version with air conditioning, power steering and power windows, it has what they call an electric driven carburator, it is a USA version that was bought used here in Costa Rica, I need to know all the technical info that I can get, calibration for valve clearance, spark plugs, timing and any other tune up and...
3 |
pdejongh |
831 |
25th June 2007 - 11:49 AM Last post by: pdejongh |
I have all of the rear suspension components (drum, shock, brake lines,etc) removed but I can't seperate the two arms because of the rear stabilizer bar is rusted in the bracket.
What is the easy way to remove the left and right arms, is it because of the stabilizer bar or something else I don't see?
Any thoughts.
Jeff
0 |
newfiejeff |
217 |
19th June 2007 - 06:33 PM Last post by: newfiejeff |
[B][COLOR=blue]HELLO
can anyone help???? I am trying to put an ac hose onto flared (female end) of the evaporator..I used a quick disconnect ac tool to seperate them..put on new o-rings and garter spring..the garter spring won't go over the flared end..I cannot get a grip on evaporator end.Is there a special tool for this???? HELP!! Someone said to leave on the little red PLASTIC...
0 |
hook |
189 |
14th June 2007 - 09:09 PM Last post by: hook |
Hi ive got the 94 manual but doesent say the horsepower and kilowatts any body know??? thanks.
7 |
daves94excel |
899 |
14th June 2007 - 06:32 PM Last post by: Scuzzy |
Just installed a turbo in my 1992 excel and was wondering if anyone knew of a way to eliminate the Air Flow meter, What would the wiring be like. Or should i keep it installed, or is there a differnet Flow Meter that would work. Any help would be greatly appreciated.
Will post pic's soon. It's one of a kind, and has a wide body kit installed.
Thanx in advance
9 |
powerline |
1,418 |
14th June 2007 - 09:43 AM Last post by: Scuzzy |
I own a 1992 Hyundai Excel w/ 89.6 cubic inch, 1.5 ltr engine. It has a manual hydraulic 4 speed transmission which has went bad. I have looked at salvage yards for this part and the nearest one is 200 miles away. I have found a 5 speed manual transmission much closer to home. Would a 5 speed transmission work on a car that was previously a 4 speed. Any help would be appreciated.
1 |
chilcoj1 |
362 |
14th June 2007 - 08:53 AM Last post by: Scuzzy |
Hello All,
This is my first post. Imma jump in with my first question. I have a 1993 Hyundai Excel. Came with no AC or power steering. I want to add AC. Is this possible? If so what does it entail? I appreciate ANY help I get.
default/liebe011.gif' 'liebe011.gif' />
0 |
Melanizm |
491 |
31st May 2007 - 08:59 PM Last post by: Melanizm |
hi all i bought a excel 98 twincam,the old owner cooked the engine.
when i got it it would run good but very hard to start,so i rebuilt the engine new rings,bearings and got the head overhauled i also replaced spark plugs ,leads and all filters.now its altogether it wont start at all,it turns over ok,there is fuel(i can smell it) and there is spark,i lined up all the timing marks to where...
0 |
esposito |
394 |
26th May 2007 - 07:16 AM Last post by: esposito |
Hi guys new to hyundais and am having problems trying to change the headunit in the excel we just bought. I cant seem to find a way to get the stereo surround off, by this i mean the entire plastic piece surrounding the stereo including the heat/cool controls.
Any ideas???
Im assuming excels are pretty much the same worldwide here i kno. But they seem to be a pretty...
0 |
gryph |
325 |
25th May 2007 - 10:12 PM Last post by: gryph |
Hi:
I have a 1994 Excel. About two years ago we had the MAF Sensor replaced. I was wondering if anybody would know how exactly to clean it. I've seen cleaner in the auto stores, but was hesitant to just remove the connecting hose form the air filter and spray away! Is there a certain order on how to do this, and, would anybody reccomend it.
Thanks, Arnie
1 |
ArnieB |
431 |
25th May 2007 - 12:03 PM Last post by: Gerrito225 |
Hi i have a Hyundai Excel 1993 and it doesnt mark the gasoline . I need help what to do because I got stuck in the highway like two times without gasoline can anybody tell how to fix it or something?
8 |
Gerrito225 |
445 |
25th May 2007 - 11:16 AM Last post by: Gerrito225 |
Hi folk's, can anyone help me. I have a sporadic electrcal short when the car is running. My flasher fuse blows out when the car is idling or taking off(engin rocks).Ive put a braker fuse but it won't hold. I know there is a wire touching somewhere, can someone tell me of a good strategy to locate the short (beside's puting a bolt in the fuse socket and look for smoke). I don't...
1 |
will |
409 |
23rd May 2007 - 05:46 AM Last post by: will |
does anyone know where the plug is to check engine codes on a twincam excel 1998
2 |
esposito |
413 |
18th May 2007 - 09:33 PM Last post by: hyunnychub |
can i put a 1992 coupe engine into my 1990 excel? also will i need gearbox from the coupe?
4 |
excel_lent |
1,292 |
18th May 2007 - 01:36 AM Last post by: wheel_of_steel |
[B]HI
has anyone tried freeze 12 or MAXIFRIG? let me know ..any input much appreciated thanks
0 |
hook |
447 |
17th May 2007 - 10:57 PM Last post by: hook |
Does anybody know if there is a fuse for the dash lights?
I have checked what I believe are all the fuses inside and out but cant find any faulty ones.
Is the access to the back of the dash where the globes are located easy to get to?
I have had 3 night time speeding fines as a result of no dash light :-(
1 |
stagecoach cowboy |
424 |
14th May 2007 - 07:09 PM Last post by: hook |
I bought this car about a month ago for an easy 100.00 because it didnt run. I finally got it to run yet the problem with it is that it takes almost 10 minutes to start up and messing with the key. After it starts it runs perfectly does not stall or anything and can run it for as long as possible. The only trouble is that it takes forever to start. Does anyone have any ideas as to what could cause...
3 |
Dstock |
645 |
13th May 2007 - 01:36 PM Last post by: will |
hi all
I had a couple runins with nissan pulsar N13s there quite an old car now but they still go pritty good cause ive gotten beaten a couple times and ive kept up with one once but has anyone else here beaten an N13 pulsar and have u got any mods.?
0 |
mitchell |
381 |
13th May 2007 - 01:24 AM Last post by: mitchell |
[B]hello what the heck size quick disconnect do you use on a HYUNDAI EXCEL to remove the A/C lines? I tried a five eights but on the last 2 hoses on the A/c accumulator-drier, it won't work..any help much appreciated.PLEASE HELP ASAP. Maybe I am not using these the right way..ugh! default/innocent.gif' ...
0 |
hook |
215 |
5th May 2007 - 10:03 PM Last post by: hook |
hi new member from australia
i have a excel 1998 x3 sprint twincam ,very hard to start when cold and warm it still alittle hard,I replaced spark plugs,leads,battery,alternator,fuel filter,air filter
it drives great ,idles good just hard to start can anyone help
4 |
esposito |
454 |
4th May 2007 - 03:11 AM Last post by: Black Mamba |
A big hole has just appeared in my intake manifold next to the thermostat housing.
Has anybody else had a similar problem and how much does a new manifold cost?
Thinking of filling it with aluminium putty, but not expecting the best :-(
2 |
stagecoach cowboy |
366 |
3rd May 2007 - 02:38 AM Last post by: stagecoach cowboy |
i have a 1988 Excel GLS Hatchback 5dr Man 5sp 1.5 and lately it has been seriously over reving when at idle but not when in motion. When stationary with the clutch depressed the car over revs and wants to jump forward just like if i was to put my foot on the break and accelerator at the same time and when i release the clutch the reving lowers a bit. After doing a few checks i think i could be the...
5 |
excelsaregreat |
824 |
28th April 2007 - 11:52 PM Last post by: wheel_of_steel |
How do you properly get to and tighten the shifter plate under the stick shift?
2 |
TJ Willi |
795 |
22nd April 2007 - 05:05 AM Last post by: will |
Problem: I stink at cars but can do a lot of basic stuff with the right information. 94 Excel was running fine, came home the other day and accidently left the lights on. Was inside for ten minutes, walked out and noticed headlights not on but parking lights were on. Turned off lights and tried to start car. Car will turn over but will not start. Headlights still do not work.
4 |
jspinhirne |
1,164 |
15th April 2007 - 10:34 PM Last post by: Gerrito225 |
ANyway I have Excel 92... Standard...
Ok when driving i give it some extra gas and the RPM go up but no extra speed. And even loss of speed. To me it seems like i am feathering the clutch??? It seems like the clutch is inguaging, but i am not touching the clutch. And it doesnt do this all the time just sometimes.
Could it be the Clutch cylinder? I dont know i am not a...
1 |
kingslurr |
435 |
10th April 2007 - 11:48 AM Last post by: montego |
Hey there. I was just wondering, could I swap out the old 1.5 for a 4G63T? I have heard from a few people that you can but I need to make sure before I try anything. I have a 1988 Precis LS 5spd manual. My friend has about 3 4G63T motors laying around that he wants to get rid of and I wanted to know how difficult it would be to do the swap (if possible) and what do I have to modify to make it...
0 |
Lepracer |
405 |
6th April 2007 - 02:13 AM Last post by: Lepracer |
I unfortunately mangled the front bumper last week on my 1994 Hyundai Excel ZLS302 (2 Door Hatchback) when I rear ended a GMC Envoy SUV default/crying.gif' 'crying.gif' /> My front bumper cover, bumper liner, and grille were damaged, but fortunately the hood, side fenders, and engine...
0 |
mattonbass |
279 |
25th March 2007 - 10:20 PM Last post by: mattonbass |
i have a 91 excel manual transmisssion car that needs high rpm to get going and to maintain speed, and it wasnt like this a few days ago. any ideas?
1 |
xylsia |
520 |
19th March 2007 - 09:44 PM Last post by: will |
I found some really nice 13" 5 star rims online and supposedly they fit perfectly on a '94 Hyundai Excel. The tire size on a 1994 Hyundai Excel CX is "P 185 / 80 R 13".
Now there is some information on those rims I found and I'm not exactly sure what this information means. Can anybody help me out here?
Backside Spacing (in/mm):...
Rims
1994 Hyundai Excel CX RIMS
10 |
yms1975 |
1,291 |
19th March 2007 - 09:39 PM Last post by: will |
Hi,
I'm new to the forum and have already had great luck searching the posts. I have a quick question that maybe someone can easily answer.
I have a 1987 Excel. I changed the thermostat about a year ago with no problems. Okay - my boyfriend did it but I watched and held stuff. ;-)
Anyway, in the last week the car has occasionally been overheating. It has enough...
6 |
chowderhead |
345 |
16th March 2007 - 12:47 PM Last post by: chowderhead |
