Replacing Infinity Sound System with Aftermarket Radio - Hyundai Forums : Hyundai Forum
 4Likes
post #1 of 17 (permalink) Old 04-13-2013, 10:46 PM Thread Starter
Drives 2008 Entourage Limited
McDanielWE is an unknown quantity at this point
My OEM (Infinity multi-disc changer) needs to be replaced. The disc drive is broken. This Entourage has the Infinity Sound System. I have ordered the Metra 70-1004 harness for the 2006-up Hyundai. I have attempted to install an Alpine INE-S920HD and a Kenwood DDX470 replacement system. I have wired in the power (red {ignition}, orange {battery}, black {ground}). I have also connected the 4 speaker colors that are referenced on the Metra harness (white, green, gray, purple). I connected the antennae as well. The system comes on and displays everything as it should. However, I have no sound out of any of the speakers. This happened on both units. Can anyone tell me what I am doing wrong?
McDanielWE is offline
post #2 of 17 (permalink) Old 04-14-2013, 04:52 PM Thread Starter
I solved the mystery. The Infinity Speakers are powered by an amp that is not in the original radio. I thought it was. Once I connected the Amp Power to the harness it worked. I have definitely lost my edge since my teenage years when I would pop radios, speakers and amps in and out of vehicles in what felt like a matter of minutes.
post #3 of 17 (permalink) Old 04-23-2013, 06:23 AM
Rob22315
Infinity makes the speakers and amp on these vehicles. Hyundai makes the HU. The CD players on these are very unreliable. I use a cassette tape adapter to play my mp3's through the stereo. Sounds great.
The HU on my 2008 went so I replaced it with a 2007 HU which has the tape player and sounds better that the 2008. $50 off eBay vs $700 new.
The CD player on the eBay unit didn't work for more than a week either but at least it didn't discharge my battery like the original unit.
Rob22315 is offline
post #4 of 17 (permalink) Old 04-30-2013, 10:13 PM
gtd2000's Avatar
2007 Hyundai Entourage - USA 20010 Hyundai i20 - UK 1995 Nissan 240SX SE - USA 1983 Suzuki GS450A
Quoted: 22 Post(s)
gtd2000
I was thinking about the same kind of thing but our head unit is still working fine for now...
I'd looked into this replacement head unit here:
Pioneer FH-X700BT CD receiver at Crutchfield.com
This is (supposedly) compatible with the Infinity system and even comes with all the necessary connectors to keep all the functions working apart from the steering wheel controls...
I'd do this method but we also have the factory overhead DVD player - I wouldn't want to lose this feature from the van.
The customer service rep at Crutchfield couldn't confirm if the DVD function would work but didn't think it would be too much trouble to get it working.
Do you have the factory overhead DVD player installed too?
The main reason for us swapping the factory head unit is to have Bluetooth function in the van....
gtd2000 is offline
post #5 of 17 (permalink) Old 12-01-2013, 11:12 AM
hoosierdadi
Guest
Posts: n/a
Quoted: Post(s)
I'm trying to find out the same thing. My wife's van CD changer stopped working 1st, then the battery died and now the aux audio won't work either- need to replace the unit- but we can't lose the ability to have rear DVD audio.
post #6 of 17 (permalink) Old 01-11-2014, 07:38 PM
Azera Santa Fe
Bassman4jesus is an unknown quantity at this point
I just replaced the head unit in my Hyundai Azera because I want to be able to stream music. Anyway, I set up everything correctly, soldered all my connections, used heat shrink, etc. Turned the unit on, it works fine, but there is NO sound just like you posted. The wiring harness from my unit has a "P. Cont" blue wire which is believe is to power the Infinity amp but the Scosche HY08B wiring harness does not have a wire for the amp. How did you determine where to wire it into to get the amp to work???
Bassman4jesus is offline
post #7 of 17 (permalink) Old 05-05-2014, 04:53 PM
2008 Hyundai Entourage
griam01 is an unknown quantity at this point
Did anyone determine if you can replace the factory Unit with an aftermarket and the DVD player is not affected?
griam01 is offline
post #8 of 17 (permalink) Old 10-06-2015, 09:28 PM
Nsquishee is an unknown quantity at this point
Any Luck?
Hi Bassman4jesus...I'm having the same problem with my '06 Azera with Infinity system. Hooked up the HY08B harness using the "power antenna/remote amp" on my Pioneer head unit, but no sound. I figure it has to do with the amp not turning on. Did you resolve your issue? If so, how?
Nsquishee is offline
post #9 of 17 (permalink) Old 11-13-2015, 08:50 PM
MISTERDIEABETIC is an unknown quantity at this point
I just put an Alpine INE-w940 in an 07 Entourage today and the rear dvd audio DID NOT WORK! I am currently trying to find the audio outputs from the DVD player and wire some RCA cables to them so I can hook them up the the inputs on the Headunit.
gtd2000 likes this.
MISTERDIEABETIC is offline
post #10 of 17 (permalink) Old 11-16-2015, 08:23 PM
gtd2000's Avatar
Quoted: 22 Post(s)
gtd2000
I shall be watching your posts with great interest!
So did the DVD still play DVD's but only without sound at the rear (sound coming from the front) or no sound at all?
I'd love to replace with factory unit with something that supports BT and digital media via USB or SD card etc.
I was on a road trip at the weekend and decided to make up some DVD's for my daughter to watch but the unit would not read any of the DVD's that I made...
I tried some (+ahem+ dodgy+ old+) DVD's I bought overseas, that were obviously burned by third parties and they appeared to work without any trouble....
Intermittent No Start / No Crank Solutions:
(<--click me) Starting with a pen!,
(<--click me) IPS Module Bypass Fix
Sliding Door Problems?
(<--click me) Entourage & Kia Sedona/Grand Carnival Power Sliding Door Fix
gtd2000 is offline
