2007 Entourage power sliding door troubleshooting - Hyundai Forums : Hyundai Forum
 1Likes
post #1 of 68 (permalink) Old 12-18-2011, 10:04 AM Thread Starter
Drives 2011 Sonata GLS 2007 Entourage Limited
pmaguy
We love our Entourage...it now has 89,000 trouble free miles with just a few minor issues. Here is one:
the left Power sliding door will not open and close with the remote or interior buttons.
However the door does work perfectly fine when using either the interior or exterior door handles. I see two cables that actuate the latches when the handles are moved, but during key fob or interior button actuation the door starts to move then reverses I do hear a relay clicking the in PSD module in the rear cargo area, so a signal is getting there.
My troubleshooting so far indicates that the hold open latch and close latch are not releasing, and therefore the motor load stalls and reverses.
I suspect that the actuator in the PSD is not working, but there is nothing in the alldataDIY manual that provides and troubleshooting other than hook up a computer box to the system that I do not have.
Any input on this subject would be appreciated. Thanks!
pmaguy is offline
post #2 of 68 (permalink) Old 12-18-2011, 10:17 AM
Quoted: 1426 Post(s)
Door not open with switch, but open with manual handle --
Replace the small electric motor in the door controller (black plastic thing that the cables attach to, has interior door handle on it),, be carefull, had couple where replace the small motor not work,, the gears inside the controller were broken, so you replace the controller
Door opens fine,, then when closing, it gets almost closed,, then open right back up ---
Replace the PSD module for the offending side,, one on each side, behind the rear panel on each side.. may consider doing both, be done with it.
There is rear door latch recall for both power door and manual door, they get new latch.
sbr711 is offline
post #3 of 68 (permalink) Old 12-18-2011, 10:59 AM Thread Starter
pmaguy
Thanks for the advice! When I get back home after the holidays I will let you know how it turned out. It will be easy now that I know how to get the interior door handle off. . Took me forever to find the clip!
pmaguy is offline
post #4 of 68 (permalink) Old 12-24-2011, 05:49 PM
RCOONS's Avatar
Quoted: 5 Post(s)
RCOONS
Please take note of what sbr711 just told you --- ( red font ). There was a recall on these doors and the dealer should fix the issue you describe for free. I had mine done this summer.
RCOONS is offline
post #5 of 68 (permalink) Old 12-24-2011, 06:08 PM
Recall will not do anything for BUM controller or PSD modules.. it is only a straight up latch replacement.
sbr711 is offline
post #6 of 68 (permalink) Old 12-27-2011, 08:42 AM Thread Starter
pmaguy
I have never received a recall notice, nor is there anything on the NTSB website. Do you have a recall number I can reference? I know there was a Service Bulletin on this as well. My experience with dealers has not been very good so I shy away from them doing work. When I have done this fasteners are missing, have to take it back etc. a big hassle and when I do it myself I can do it on my schedule, not theirs. . Last time I had it in the Service person tried to sell me on services I did not need according to the documented maintenance schedule. When I showed her the schedule from the owners manual she said she had never seen it!
pmaguy is offline
post #7 of 68 (permalink) Old 12-29-2011, 01:24 PM
drives entourage
lcrowe1975 is an unknown quantity at this point
hi guys just took my entourage to the dealer with a laundry list of problems:such as a loud whinning noise from the tranny or ps , the rear defrost lines dont work,had to add antifreeze with front passenger floor wet,a puddle of motor oil laying on top of the tranny and the notorious passenger side sliding door will open when it feels like, went to wmart and came out, door is wide open, happened again at red lobster. patience ,im loosing quick, only got 26k on a 2008. hoping for the best
lcrowe1975 is offline
post #8 of 68 (permalink) Old 12-30-2011, 06:03 PM
Drives 2007 Hyundai Entourage
JennT is an unknown quantity at this point
sbr711-- hi we are having both issues that you mentioned on our 2007 Hyundai Entourage driver slide sliding door. The power sliding door works when using the overhead power button, the outside handle, and the FOB button, however when trying to push the close button on the door, our door will not close.
In addition, for the past few days we have had off and on issues of the door closing until about 6 inches and then it backs up and tries again or backs up and stops.
Do we need to replace the small electric motor in the door controller or the PSD module? Is this something that we can "do it yourself"?
JennT is offline
post #9 of 68 (permalink) Old 01-12-2012, 08:53 PM Thread Starter
pmaguy
I replaced the small motor in the sliding door module and the problem is fixed. Took me about one hour and $15 for the motor. Works like new!
pmaguy is offline
post #10 of 68 (permalink) Old 01-12-2012, 09:21 PM
---> Replace the PSD module for the offending side.. in most respects, replace both sides
Replace the PSD module first, the closing to 6" and bounce right open gives this away.. Need to remove the rear lower inside panel to find the module at each side.. get them done, then go from there..
sbr711 is offline
