Oil Filter - Hyundai Forums : Hyundai Forum
post #1 of 17 (permalink) Old 04-24-2011, 06:55 PM Thread Starter
f02262
Is there any other brand of oil filter (other than Hyundai) that does not leak? I have tried Fram, but leaks after first day or 2. I tighten both the same and have never had issue with Hyundai brand leaking. Parts stores is closer than the dealer.
f02262 is offline
post #2 of 17 (permalink) Old 04-24-2011, 07:47 PM
wymi's Avatar
Quoted: 18 Post(s)
I only use Hyundai filters mainly for that reason. Too many stories of aftermarket filter kits leaking. You can buy the Hyundai filters online and on Ebay. That being said Wix also makes a filter, not sure if they will leak or not.
Wix
Part Number: 57061
UPC Number: 765809570610
Principal Application: Various Hyundai, Kia (06-10)
All Applications
Style: Cartridge Lube Metal Free Filter
Service: Lube
Type: Full Flow
Media: Paper
wymi is offline
post #3 of 17 (permalink) Old 04-24-2011, 09:47 PM
Quoted: 1365 Post(s)
Aftermarket filters typically have wrong size o-ring for the cap, so they dont get compressed to canister wall very, then apply some 80psi oil pressure, they going to leak.. Have people go get oil change at a jiffy kinda place, then come to us with "my car leaks oil" thinking it warranty... we know Hyundai kit not leak, so why waste your time..
Go to Hyundai or Kia dealer, and buy a 30ct case of filters.... the case will cover you through approx 100,000 miles.. if you take car to somebody for oil change, have them use your filter, and make sure they change the rings...
Hyundai/Kia xxxxx-3C100 filter kit comes as filter, drain plug gasket, o-ring for cap, and o-ring for bottom of filter stem.. everthing in 1 box...
sbr711 is online now
post #4 of 17 (permalink) Old 06-21-2011, 10:21 AM
Xsolara's Avatar
drives Black 2015 Genesis 3.8L AWD Sig. pkg....2013 Elantra GT
Quoted: 166 Post(s)
Xsolara is an unknown quantity at this point
QUOTE (njdevil @ Apr 24 2011, 05:55 PM)
I have used several different brands including Fram and never had a leak problem. Are you pre-oiling the rubber gasket before installing the filter ???
"Act on what you know not what you think"
Xsolara is offline
post #5 of 17 (permalink) Old 06-22-2011, 09:36 PM
2011 Sonata Limited
Brig
I have used a number of differant brand filters and never had one leak. Do some research on the web on the quality of oil filters. There are some real junk filters out there. The Fram is about as bad as they get. Sorry Fram Fans! Purolator Pureone and Wix are very good filters for the money.
Brig is offline
post #6 of 17 (permalink) Old 06-24-2011, 12:50 PM
Harley03joe's Avatar
Harley03joe
QUOTE (Brig @ Jun 22 2011, 09:36 PM)
Look What I Found
Page 1 of 1
Hyundai Technical Service
Bulletin
Subject
Group
Number
Date
Model
CIRCULATE TO: [ ] GENERAL MANAGER
[X] SERVICE ADVISOR [X] SERVICE MANAGER [X] WARRANTY MGR [ ] SALES MANAGER
[X] PARTS MANAGER [X] TECHNICIAN
ENGINE MECHANICAL
05-20-002
JULY, 2005
ALL MODELS
USE OF AFTERMARKET ENGINE OIL FILTERS
CAUSING ENGINE KNOCKING NOISE
DESCRIPTION:
Some vehicles may experience an engine knock noise with the use of an aftermarket oil
filter. Aftermarket oil filters may use different materials, construction and specifications
than genuine Hyundai oil filters, which may lead to pressure variations within the engine,
thus contributing to an engine knocking noise.
VEHICLES AFFECTED:
All Models
REPAIR PROCEDURE:
Perform an oil change on the vehicle and replace the aftermarket oil filter with a genuine
Hyundai oil filter.
WARRANTY INFORMATION:
Normal warranty procedures apply.
This is not a warranty repair.
[b]Just Info For All You Guys And Gals
Harley03joe
96 M-B SL500 White/Beige Gut
05 M-B S 500 Silver/Silver Gut
03 Harley-Davidson 100th Anniversary Black/Silver
05 Harley-Davidson V Nose Trailer Black/ Chrome
07 Hyundai Azera Limited Nice Car
Harley03joe is offline
post #7 of 17 (permalink) Old 07-05-2011, 03:58 PM
Xsolara's Avatar
Quoted: 166 Post(s)
I have used FRAM filter for several oil changes and never had a leak problem (available at Walmart $6.50)
They are made in Korea and look exactly like the OEM. Are you lubing the rubber "O" ring ?? The plastic cap should be right up against the housing. If you see a gap say 3/16"
you did not tighten it enough .
Xsolara is offline
post #8 of 17 (permalink) Old 07-05-2011, 05:12 PM
Harley03joe
QUOTE (Xsolara @ Jul 5 2011, 03:58 PM)
Just Tell Him To Use The HYUNDAI OIL FILTER
End Of Story
Harley03joe
post #9 of 17 (permalink) Old 07-07-2011, 12:48 PM
Problem lies in the o-ring supplied with the aftermarket filters, they is dimensionally incorrect for material diameter, so when the cap and ring enter the canister, there is not enough comression of the ring into the groove and canister wall to effect good seal, thus oil under pressure will pass the ring and leak out all over top of transmission.
post #10 of 17 (permalink) Old 07-29-2011, 12:22 PM
HyundaiBro
I really don't know why the filter would leak, unless you got the wrong size.
HyundaiBro is offline
