Turn signal relay - Hyundai Forums : Hyundai Forum
post #1 of 7 Old 11-09-2012, 11:39 AM Thread Starter
Hoy
Hoy's Avatar
Drives 2012 Santa Fe GL 3.5 AWD
Hoy is an unknown quantity at this point
Turn signal relay
Originally Posted by Hoy View Post
I've changed out all of my external lights for led's, including the turn signals. I had planned on replacing the turn signal relays with led comparable versions but have been unable to find the relays in the fuse boxes. The box that does the actual clicking under the dash seems like it could be it but it looks completely proprietary to this model, and not readily available in the compatible version.
I ended up installing resistors for now but that's caused other problems with my lights. Now when I turn my high beams on all 4 turn signals light up solid and I am unable to use them until I turn the highs off.
So, I would love to know if I do have a relay replacement option for my 2012 Santa Fe
I posted this in the Santa Fe forum but have had no answers so I hope to find one over here
Sent from my iPhone using Autoguide.com App
Hoy is offline
post #2 of 7 Old 11-09-2012, 11:42 AM Thread Starter
Hoy
Hoy's Avatar
Oh it's a 2012 Santa Fe GLS
Hoy is offline
post #3 of 7 Old 11-13-2012, 06:13 PM
pamlarry
Your car should be under warranty. Let them take care of this for you.
pamlarry is offline
post #4 of 7 Old 11-13-2012, 07:42 PM
Accent 2007 GLS
faja is an unknown quantity at this point
Where did you put the resistors? I'm assuming since you're in Canada, you have DRLs which run the high beams in low power mode, correct? Do the signals come on when DRLs are on? Do they also come on if you use the "flash to pass" high beam?
faja is offline
post #5 of 7 Old 11-13-2012, 07:54 PM
Quoted: 248 Post(s)
Warranty does not extend to user modifications,, applies only to materials and workmanship as supplied by Hyundai.
sbr711 is online now
post #6 of 7 Old 11-13-2012, 08:00 PM Thread Starter
Hoy
Hoy's Avatar
I actually don't know if they come on in those instances, I've only been able to check it myself without someone helping, next time I'm down there ill get a helper to push the switch while I watch.
Where I placed them: on the rear signals I installed them between the tail light assembly and the body, spliced using those plastic splice things
The front turn signals took me a while to figure out which wires needed to be bridged with the resistor, I used a bulb with wires on it to find out which wires on the harness were the second live wires to the dual intensity bulbs up front once I found them I stripped some of the tape back from the harness wires and installed the same resistors across those wires. I have a feeling that my problem is up front, I haven't been able to find an actual pin-out diagram for those harnesses so I may have put the resistor across the wrong wires potentially..
Sent from my iPhone using AutoGuide.com App
Hoy is offline
post #7 of 7 Old 12-04-2012, 11:18 PM Thread Starter
Hoy
Hoy's Avatar
Still have not found a diagram for that harness, and have confirmed that the resistors are causing the problem. Both sides. Took the resistor off of each side one at a time while testing the turn signals with the high beams on. Still the same problem. In the morning I'm installing my bling lights fog lights ill try to trouble shoot it some more
Hoy is offline
User Tag List
