The passenger side doors - front and back power windows and front and back power door locks do not work. The open door sensor doesn't show the door open on the display window in between the tach and speedometer - it's as if the door has no power - however the drivers master lock switch will lock all the doors. The drivers master will not open the passenger side windows either. The door lock security horn doesn't work either when using the key fob but all the doors do lock. I assume there is a second power circuit for the master door locks. I checked the fuses...they are fine - is there a relay that controls the power to the passenger door side??? The dealer is scheduled to replace the passenger door window/door switch next week.
In the manual the fuse block mentions a Passenger Door Module - I assume a relay? Would greatly appreciate any insight.
Yes - it seems to have no effect. It works for the drivers side no problem. It's like I mentioned above the passenger side doors don't seem to have any power..
I see them - again - this coming Tuesday AM - they think it's just the actual door/window switch. I am going to ask if I can talk to the actual repair tech and go over each issue. TY!
It may not control the power itself. It may control the signal to / from the on board computers that allow the windows and door locks to operate. That is the case on many models across manufacturers. The days of the simple Dodge Dart are long since gone.....That switch panel may actually be one of the potentially dozens on microprocessors in your vehicle.
410K members
