:00000732:
I asked a similar question a month ago. The replies can be read here:
http://www.hyundai-forums.com/260-dm-2013-santa-fe/149561-differences.html
I followed this car for 4 months before purchasing. The hardest decision for me was: which engine? The first 2 months it was definitely the 2.0T I wanted. The next 6 weeks I was on the fence and couldn't decide. Then the EPA rating scandal broke, and that helped me make my decision for the better gas mileage of the 2.4. I believe the difference is more than just the advertised 1 or 2 mpg. Check out Fuelly for the actual, real world, differences here;
2013 Hyundai Santa Fe MPG Reports | Fuelly.
In addition to MPG, I found the following differences for
USA vehicles:
1. Wheel sizes and appearance. The 2.4 gets 17" wheels that are blackened in appearance. The 2.0T gets 19", which are satin in appearance.
2. Ride. The 2.4 17" tires give a smoother ride. The 2.0T 19"
low profile tires allow you to feel the imperfections in the road more.
3. Radio. The 2.4 has an available upgrade to a Dimension radio with 10 speakers and sub woofer. The 2.0T has an available upgrade to an Infinity with 12 speakers and sub woofer. The standard radio has 6 speakers and no sub woofer.
4. Cost. The 2.4 is about $2000 less in cost.
5. Power. The 2.0T has more HP and torque.
6. Maintenance cost. IMO, the difference is insignificant.
7. Towing. I don't tow so I don't know the exact differences here. But you can tow more weight with the 2.0T.
I find the 190 HP of the 2.4 to be not just adequate, but satisfactory for around town driving in the city and suburbs. It's acceleration from stops or after slowing to go around corners, is quite satisfactory
for me. IMO, it's weakness is when trying to accelerate
quickly from speeds of 40-70 when entering highways or passing. It's very doable with the 2.4, you just have to be aware you'll need a little more time to get up to speed.
How much power do you need vs. cost? Like someone said, "Best advice is to test drive both". Everyone's priorities are different. If cost is a low priority for you, and you don't mind a little less smoother ride, go with the 2.0T. You'll get more power, a little nicer radio, and more towing capacity. If costs are a high priority, you might favor the 2.4. I have no regrets in choosing the 2.4.
I hope this helps you with your decision.
John
