2007 Santa Fe Front End Vibration - Hyundai Forums : Hyundai Forum
post #1 of 20 (permalink) Old 04-13-2008, 11:46 PM Thread Starter
lrquandt
I have a 2007 Santa Fe and since November of last year it has developed a front end vibration. I have had it back to the dealer five times and they balanced the tires four times before replacing all four tires. On the fifth time, they balanced and rotated again. The vibration is still there. I experience it mainly at 65-70 mph. It is a constant vibration that will numb your hands on a long drive. I am at my wits end on this one. I am wondering if anyone else has had this problem.
lrquandt is offline
post #2 of 20 (permalink) Old 04-14-2008, 01:01 AM
gllund's Avatar
Drives 2007 Hyundai Santa Fe
gllund
Here is a post from another Hyundai Forum. It should help you out.
Gord
http://townhall-talk.edmunds.com/WebX/.f0f...eindex=.f0fbfec
gllund is offline
post #3 of 20 (permalink) Old 04-14-2008, 10:57 AM
pauln
gllund and lrquandt,
I made that post about the Bridgestone tire vibration over at the Edmunds forum. I copied and pasted it below this reply so we don't have to go the Edmunds site to read it. Since lrquandt has had all 4 tires replaced, the problem is in all likelyhood not with the tires. It is possible, however, that there is a problem with one or more of the rims and the RFV test would certainly find that. But it could also be caused by other things - a sharp mechanic should be able to figure it out rather quickly given that there is enough vibration to "numb your hands."
lrquandt, good luck on solving your problem and let us know what you find out.
== Edmunds Post ========================================
[b]2008 SF Tire Vibration - Bridgestone Dueler HT
Just thought I would pass this along (there have been other related posts by others as well):
I have a new 2008 Santa Fe Limited with about 1,000 miles on it. It has always had a vibration between 50 and 60 mph. Not real bad, but enough so you could notice. I took it back to the dealer and they rebalanced all 4 wheels. No dice - the vibration was still there.
Took it back again and this time the did a RFV (Road Force Variance) test on all 4 wheels using a Hunter GSP 9700 balance machine. From what I can gather, this machine runs the tire against a roller under a load comparable to what the tire would have when running on the vehicle. It then measures the variance in pressure as the wheel rotates. This can spot out of round tires, defective rims, or tires with belt problems. A good tire should have a fairly uniform pressure (not air pressure, but the pressure it exerts agains the roller) as it rotates.
They said the variance limit on my tires should be about 19 lbs. They found one tire that had a variance of 47 lbs! They replaced that wheel with one from another vehicle (they tested it before they put it on and its variance was 10 lbs.). This completely solved the problem and it is now vibration free.
However, they apparently did not register or reset the TPMS system for the new wheel and now my TPMS malfunction light stays on. I can stop back up and get that reset, so it is not a big deal. I am just glad the vibration is gone.
If you are having a vibration problem that a standard wheel balance does not solve, I would suggest you push the dealer for a road force variance test. Now that I had it done on my SF, I can see why dealers don't use it more often - it took around 30 minutes a wheel to run them on the Hunter machine. They will want to do regular wheel balance and send you on your way - which may or may not solve your problem. If it doesn't, the RFV test is the way to go.
Paul from Ohio
pauln is offline
post #4 of 20 (permalink) Old 04-14-2008, 12:00 PM Thread Starter
lrquandt
I have filed a case with Hyundai and they are getting invoved. I will keep you posted on the issue.
lrquandt is offline
post #5 of 20 (permalink) Old 04-16-2008, 03:25 PM Thread Starter
lrquandt
I filed the case with Hyundai Customer Service and it was a very pleasant experience, with good follow-up. The Regional Rep in Chicago that has been assigned my case is a complete idiot. He is worthless and I am now back to dealing with the dealership. So much for Hyundai helping me out. This has been a complete waste of my time.
lrquandt is offline
post #6 of 20 (permalink) Old 04-18-2008, 10:43 AM
sfillion
Same problem here. I bought my SF in January 2008 with snow tires. I installed the summer tires last week and had vibration. Just came back from the dealer this morning and they will change the 4 tires...
sfillion is offline
post #7 of 20 (permalink) Old 06-03-2008, 11:23 PM
TT3
TT3
Yes... I have an '07 with the same issue. After 5 trys I still have a slight vibration at 70+ mph. They changed the tires, wheels (18"), did a road-force balanace and put in nitrogen. A Serv. Mgr. told me off-the-record that the '08s had the same prob!
Where do we go from here?
TT3 is offline
post #8 of 20 (permalink) Old 06-04-2008, 07:57 PM
2014 Hyundai SFS 2.0T 2014 Hyundai SFS 2.4
Quoted: 88 Post(s)
MButkus
I had a 1999 Chrysler 300M, $30K. From the day off the lot the steering wheel would shake. All Chryslers that year with the NEW 16" tires had that problem. After many attempts, and a new set of tires from Goodyear, no solution. After some 3K the vibration would come back. Finally, 2 years later Goodyear sent me a check for $900 and stated "Goodyear tires, for some reason, do not work on your Chrysler". Please purchase tires from another company.
Drove it another year and got an Audi.
No problem with mine at 12K. I had a Jeep that had a vibrations. After getting all the tires balanced. That fixed it.
I would also suspect the drive shaft.
The 1999 Chrysler 300m, all the cars had the problem. This is the first post I have seen on that problem. I would suspect an out of round rim or drive shaft.
Is the steering wheel vibrating or the car ?
MButkus is offline
post #9 of 20 (permalink) Old 06-11-2008, 04:16 PM Thread Starter
lrquandt
I test drove a brand new 2008 Santa Fe and the vibration is worse than my 2007. I now have developed a loud clunk noise coming from the left front end when I take a sharp turn. If this was any other brand than a Hyundai, I would take it in to the dealer. After having this vehicle back to the dealer six times, they have assured me nothing is wrong with it.
My experience with Hyundai and associated dealerships has been a nightmare I relive everytime I drive my Santa Fe. the only saving grace is I leased this vehicle. In less than a year this nightmare will be over and I can get a real car.
Anyone for a class action lawsuit? Count me in!!!!!
lrquandt is offline
post #10 of 20 (permalink) Old 07-12-2008, 09:23 AM
saraph
Yeah, I've noticed this on mine as well since I've been doing more time on the highway recently. Starts just before 75 mph and seems to be intermittent. Sometimes it's smooth as glass, sometimes the steering wheel vibrates so bad you can watch your hand and arm shaking. The rest of the car is smooth and steady - it's 100% in the steering wheel. I've had the tires balanced and rotated multiple times and it's always the same. It's going into the dealership next Friday but I have zero confidence that they'll be able to find and address the issue. I'm thinking it has nothing to do with the tires/wheels and might be something in the steering/suspension...
Anybody found any resolution to this yet?
2007 Santa Fe 3.3L Limited AWD, Slate Blue
saraph is offline
