How Do I Adjust Headlights.. - Page 2 - Hyundai Forums : Hyundai Forum
post #11 of 43 (permalink) Old 01-18-2008, 07:53 AM
redderneck
Good tip. Thankyou.
redderneck is offline
post #12 of 43 (permalink) Old 01-26-2008, 03:11 AM
maseace's Avatar
maseace
Originally posted by joey3002@Dec 8 2007, 05:43 PM
[b]I really wish I could take this thing off that cuts my lights in half and puts a line about 100 ft in front of me..
[snapback]123334[/snapback]
If you did that you would blind everyone else. That's why there's high beams!
maseace is offline
post #13 of 43 (permalink) Old 04-16-2008, 01:31 AM
ekrunaj is an unknown quantity at this point
Originally posted by UniR@Dec 1 2007, 11:19 PM
[b]There are screwdriver slots along the radiator cowl piece that goes above the headlamp assemblies but it's easier just to reach behind the hadlanp assembly and grab that ratchet-like wheel directly. That is where the screwdriver tip would slowly turn it, but it's quicker and easier to turn it directly with your fingers. I kicked myself when I realized how easy it was. They probably won't budge just with finger power in a few years though...
[snapback]122102[/snapback]
I just adjusted the low beams on my 08 Santa Fe. The ratchet like knob is fairly easy to adjust by hand on the passenger side, but the driver's side was a tight fit, a no-go for my big fingers. The end of the adjusting knob will accept a 12mm wrench which makes the adjustment a breeze. The visual aspect of adjusting the low beams up or down is enhanced by the sharp cut-off of the projector beam.
ekrunaj is offline
post #14 of 43 (permalink) Old 04-16-2008, 10:32 AM
UniR
I'm pretty sure you can just drop a straight slotted screwdriver through the hole directly above and use it to adjust it.
UniR is offline
post #15 of 43 (permalink) Old 07-18-2011, 12:48 AM
blackgoatsonata
QUOTE (UniR @ Dec 1 2007, 10:19 PM)
I just created an account at hyundai forum to say thank you for this.
blackgoatsonata is offline
post #16 of 43 (permalink) Old 07-18-2011, 11:26 AM
dddp's Avatar
Quoted: 2 Post(s)
dddp
QUOTE (maseace @ Jan 26 2008, 03:11 PM)
that's right - headlight adjustment shouldn't be carried out just so that the driver of the vehicle can see more as headlight aiming also affect oncoming drivers vision.
headlights should be adjusted so that the headlights don't affect oncoming drivers - use either a headlight aiming chart or have your headlights adjusted by someone who has a headlight aiming machine so that they are adjusted to consider oncoming drivers
2010 Santa Fe Highlander 2.2l R-Series CRDi Diesel
dddp is offline
post #17 of 43 (permalink) Old 07-23-2011, 08:55 PM
Quoted: 14 Post(s)
cookiedough is an unknown quantity at this point
question: my new 2011 hyunda santa fe SE V6 for adjustment of high and low beams:
Is the low beams adjusted separately than the high beams? Reason being is I drove my new santa fe at night first time this weekend and the low beams are perfect, but the high beams are a smidge too high. The high beams on the front and sides of the vehicle directly in front are completely dark, no light at all unless you are a shorter driver say 5' or so. Is there a separate adjustment for low and high beams?
cookiedough is offline
post #18 of 43 (permalink) Old 07-27-2011, 06:48 PM
jimyboyle
I would also like to know if the high beam can be adjusted on my 2006 model, used it in the dark for the first time at the weekend. The dip beam was a bit too low and when i put on the high beam the lights hit the ground within the pattern of the dip beam rather than almost straight in front.
Wondering if the previous owner found the dips so poor he adjusted the high beams down so he could drive with all 4 on to see where he was going.
I fitted a 4300K HID kit to the dip when I got the car, nice clear light pattern on the road with two yellow high beam spots in the middle of it!
jimyboyle is offline
post #19 of 43 (permalink) Old 01-13-2012, 02:39 PM
2008 Hyundai Sante Fe GLS 2005 Volvo S40
SgtCheeseNOLS is an unknown quantity at this point
"the manual doesn't cover it well."
My manual doesn't cover it AT ALL! Thanks so much for the help. I'm going to go downstairs and adjust my headlights. Thanks again!
SgtCheeseNOLS is offline
post #20 of 43 (permalink) Old 01-17-2012, 04:36 PM
jnick67a
I have an 07 as well. My drivers side adjusted fine but when I did the passenger side the lamp is not moving at all. Any thoughts? Perhaps stripped?
jnick67a is offline
