Headlights don't work but High-beams do - Hyundai Forums : Hyundai Forum
post #1 of 14 (permalink) Old 10-05-2012, 10:05 PM Thread Starter
ptw016
The normal lo-beams won't turn on no matter what I do, but the brights still work. The bulbs are good, the fuses are good. I've tested and changed those. They're good.
What's the issue? Is it a relay? Anyone had this problem? '08 Santa Fe
ptw016 is offline
post #2 of 14 (permalink) Old 10-05-2012, 11:22 PM
santa06's Avatar
Quoted: 140 Post(s)
Do you have day time running lights ; they have a separate module that is tied into the head lights.
Were the headlight bulbs tested with a meter for continuity on the filament , visual not good enough IMO.
santa06 is offline
post #3 of 14 (permalink) Old 10-05-2012, 11:42 PM Thread Starter
ptw016
I replaced them with new bulbs. Didn't work.
Pretty sure I don't have running lights. Just the GLS basics
ptw016 is offline
post #4 of 14 (permalink) Old 10-06-2012, 01:35 AM
canderson's Avatar
2008 Limited
Quoted: 557 Post(s)
Try swapping relays between low and high beam. In the box under the hood.
canderson is offline
post #5 of 14 (permalink) Old 10-06-2012, 01:57 PM Thread Starter
ptw016
I swapped out different relay fuses and tried the spare fuse and horn fuse for the lights and got nothing to work. High beam relay fuse(s) are rated at different current levels, but I tried one of those too. It looks like the low beam circuits just aren't getting any power.
I'm guess I'm just worried that if I take it somewhere (particularly the dealer) they'll make me replace some big electrical part instead of truly diagnosis a lose wire here or whatever it is.
ptw016 is offline
post #6 of 14 (permalink) Old 10-06-2012, 08:21 PM
canderson's Avatar
2008 Limited
Quoted: 557 Post(s)
If you're able to deal with a wiring diagram, the one attached applies to your '08 model. This and a meter should make you dangerous enough to locate the problem.
post #7 of 14 (permalink) Old 10-06-2012, 09:01 PM
AlpineRyder's Avatar
Drives 2012 Santa fe 3.5 AWD W/ Nav, 2010 Elantra
AlpineRyder is an unknown quantity at this point
The relays are only good for 10,000-15,000 clicks. A click is counted x2 every time you turn your lights on. One on and one off. Try replacing the relay
AlpineRyder is offline
post #8 of 14 (permalink) Old 10-11-2012, 11:08 PM
santa06's Avatar
Quoted: 140 Post(s)
Two separate relays would have to die simultaneously for both low beams not to work ; doen't seem that likely.
Nice diagram from Canderson , I think you need to look at the output from the BCM module , the brown orange wire.
santa06 is offline
post #9 of 14 (permalink) Old 10-12-2012, 11:43 AM
polarfest's Avatar
2012 Santa Fe 4wd 2.4L,
Quoted: 7 Post(s)
polarfest is an unknown quantity at this point
corrosion at the relay sockets? fried relay? did you measure any voltage at the bulb plugs?
polarfest is offline
post #10 of 14 (permalink) Old 09-11-2014, 10:25 AM
Jonz5000 is an unknown quantity at this point
Thumbs up Electrical issues AKA headlights
Try replacing the Body Control Module located in the Engine Compartment. It controls the electrical parts of the automobile. Much like a regulator so that when you ask a car to do something electrically, it will send the signal to that item, aka the headlights. my car was like that, 2010 Hyundai Elantra Touring SLC and the Hyundai dealer fixed it for me as mine was still under warrantee and at no cost to me
Jonz5000 is offline
