oil control valve - Hyundai Forums : Hyundai Forum
post #1 of 12 (permalink) Old 03-25-2012, 04:17 PM Thread Starter
Me 2010 Santa Fe Limited 3.5 v6 wife 2013 Tucson Ltd
wireman
oil control valve
Anyone know the location on 2010 v6?
wireman is offline
post #2 of 12 (permalink) Old 03-25-2012, 04:33 PM
Quoted: 1249 Post(s)
(2) V6 applicable to the 2010...
2.7 or 3.3 ?
sbr711 is offline
post #3 of 12 (permalink) Old 03-25-2012, 06:17 PM Thread Starter
wireman
3.5
wireman is offline
post #4 of 12 (permalink) Old 03-25-2012, 06:33 PM
canderson's Avatar
2008 Limited
Quoted: 488 Post(s)
Are you seeing P0011, P0014, P0018 or P0019 error codes?
canderson is offline
post #5 of 12 (permalink) Old 03-25-2012, 06:58 PM
Your first pic is of the 2.4 (4 cyl)
Second pic is all I come up with too when in the DTC menu, I was staring at pic and then distracted for bit with message, and got in before me..
Pic show wiring for 2 OCV there on Bank 2 there with 1 OCV in the pic.. need to hit the ETM and see what going on..
ETM says (4) oil valve, 2 in, 2 ex....
sbr711 is offline
post #6 of 12 (permalink) Old 03-25-2012, 07:12 PM
canderson's Avatar
2008 Limited
Quoted: 488 Post(s)
Nuts. Thought I'd deleted one when I added the other, hence the edit. Like your pics better anyway!
I'll go back and try to get that first one out of there.
Nope. Too late to edit. Hope the OP sees your note and ignores it.
post #7 of 12 (permalink) Old 03-25-2012, 08:43 PM Thread Starter
wireman
I believe it was po044, my concern was the location since the dealer will be fixing it. It looks like it screws into the block somewhere. Thanks to you guys
wireman is offline
post #8 of 12 (permalink) Old 03-25-2012, 09:01 PM
canderson's Avatar
2008 Limited
Quoted: 488 Post(s)
P0024 I could believe. P0044, not so much...
You could disconnect the valve and check to see if there's about 10ohms resistance across it for starters. If that's OK, pull it and see if it's sticky or contaminated in any way. You can hit it directly with 12V (+12 on pin 2, ground on pin 1) to see what it does under power. It should click each time you power it up.
If the valve behaves properly, your problem is likely going to be a bit deeper. Could be a control issue, or a CVVT issue.
post #9 of 12 (permalink) Old 03-26-2012, 04:48 PM
Quoted: 14 Post(s)
cookiedough is an unknown quantity at this point
what do these oil control valves do and why are you needing those replaced, what happened or what is car doing to cause replacement?
cookiedough is offline
post #10 of 12 (permalink) Old 03-26-2012, 11:50 PM
canderson's Avatar
2008 Limited
Quoted: 488 Post(s)
The CVVT (continuously variable valve timing) uses hydraulic control. For CVVT to work, the valve needs to work. I have no idea what the most common failure modes are.
