Help Please...noisy Lifters - Hyundai Forums : Hyundai Forum
post #1 of 46 (permalink) Old 11-19-2009, 06:27 PM Thread Starter
2012 tucson gl 2014 santa fe 2.0t SE 2015 challenger sxt
beware
Unhappy
hello,
Aparently I have a posible problem with me engine ( 2,7 L, v6, 9500Km ). If I leave the Santy outside..in the morning my lifters make noise for about 2 minutes..after they go smooth..no noise at all. If I park the Santy in my garage (warmed one)..in the morning I have no noise at all.
I run Castrol Synth since 2000km on the engine.
Is this normal or I have to worry about. What I want to point is that this lifter noise is directly proportional with the outside temp.....if cold ( minus4 centigrade..noise for about 2 minutes..if between 5 - 10 centigrade...noise for about 1 minute....more than 12 centigrade..no noise .
I just want to know the normality of this problem or if is something common with this type of engine.
thanks indeed
Mario
beware is offline
post #2 of 46 (permalink) Old 11-19-2009, 08:20 PM
Alfons is an unknown quantity at this point
QUOTE (beware @ Nov 19 2009, 05:27 PM)
hello,
thanks indeed
Mario
I had a problem with the 3.3 on our SF that I swore was noisy lifters - they got noisier with time. I took it into the dealership (under warranty) and they changed the timing chain idler - no more noise.
Alfons is offline
post #3 of 46 (permalink) Old 11-20-2009, 02:06 AM
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
Quoted: 67 Post(s)
My 2004 2.7 liter does this when it gets chilly. It was about 38F (3C) here a few nights ago and I hadn't run the Santy all day. The lifters were noisy, just as you describe, for about two minutes. Once I drove it and it warmed up, the noise stopped. It should also bear noting that I had changed my oil just a few days before and am running full-synthetic Mobil1 10W30.
Andrew
Titanium Gray / Gray Leather
lovemysantafe is offline
post #4 of 46 (permalink) Old 11-20-2009, 04:40 AM
UniR
synthetic oil and block heaters will help
UniR is offline
post #5 of 46 (permalink) Old 11-20-2009, 06:58 AM
Don67's Avatar
Quoted: 244 Post(s)
When you changed the oil, did you use an aftermarket filter? If so, it might not have an anti-drainback valve. I'd replace it ASAP with one that does, preferably a Hyundai brand. If your engine gets damaged by an aftermarket filter that does not meet Hyundai's spec, you're outta luck with the warranty.
Beyond that, some degree of clattering on cold starts is normal, and not a cause for alarm if it goes away within a minute or two.
Don
Don67 is offline
post #6 of 46 (permalink) Old 11-20-2009, 11:54 AM
PoMansAWD's Avatar
PoMansAWD
Having never purchased an OEM oil filter until recently, I will say I am impressed with the look and feel of the build quality of a Hyundai oil filter. I haven't weighed it, but it feels at least twice as heavy as a comparable off the shelf aftermarket filter. How this makes things better is debatable. That aside; Like Don says, I too have read of the possibilities of oil filter anti drain-back issues (on aftermarket OFs) effecting 2.7's. I'm just not following how the filter could possibly empty on these being mounted closed end down? I've read of the 'siphoning' theory, but don't get that either.
Joel
PoMansAWD is offline
post #7 of 46 (permalink) Old 11-20-2009, 12:20 PM Thread Starter
beware
Thanks a lot to everyone !
yes, I,m using the original oil filter ( the little one) and I heard about those aftermarket filters . I think it is possible that the oil drains through that filter valve ..all the oil <column> in the engine ...or all the above filter oil quantity...can drain out through that valve back to crankcase. I was thinking that maybe I have this problem with my actual filter even if its OEM. Maybe I,ll change just the filter ..just to see the differnce ..if one
Well, thanks again for your time guys...I feel a bit reassured on this
Mario
beware is offline
post #8 of 46 (permalink) Old 11-20-2009, 01:35 PM
NomDeGuerre
I don't believe it is the oil or the oil filter.
In my experience it is the gasoline, especially Shell (with Ethanol).
When I switched to, say Esso, I did not experience the lifter noise any longer, even at startups during cold weather.
NomDeGuerre is offline
post #9 of 46 (permalink) Old 11-20-2009, 04:48 PM
Don67's Avatar
Quoted: 244 Post(s)
Interesting to see that this discussion is a virtual duplicate of one which took place in a BMW forum:
http://www.bobistheoilguy.com/forums/ubbth...;Number=1313406
One theory which might explain NomDeGuerre's observations is that the inferior lubricating properties of ethanol-blend fuel might increase normal fuel injector noise, which is often mistaken for lifter noise. Can't say I've ever noticed this phenomenon, but who knows?
Don
Don67 is offline
post #10 of 46 (permalink) Old 11-20-2009, 08:04 PM
PoMansAWD's Avatar
PoMansAWD
BITOG is an awesome board for anything automotive.
Joel
