Atos damaged crankshaft and cambelt drive gear. - Hyundai Forums : Hyundai Forum
post #1 of 15 (permalink) Old 03-04-2013, 07:18 PM Thread Starter
Drives Hyundai Atos Prime 2006
GeraldV is an unknown quantity at this point
Hi All
I would like to find out if this is a common problem with the Hyundai Atos 1.1 engine.
The cambelt drive gear which is located on the crankshaft does not have a keyway locator. The crankshaft end has "flattened" sides which the drive gear slides onto. (I hope this makes sense)
Over time this gear's inner portion develops play between it and the crank. This results in a wobble of the gear which worsens over time. This wobble causes damage to the gear and the shoulder on the crankshaft. The gear progessively "moves" toward the engine and results in the belt pulleys touching the camblet cover and the cambelt gear touching the crankshaft end cover. Also the crank timing sensor gets damaged by the timing plate which is on the crankshaft and eventually touches the sensor.
I brought this to the attention of a local Hyundai dealership who acknowledges this is a common problem with this engine and recommends the gear be replaced at regular intervals to prevent this failure.
Needless to say they accept no liabilty for the poor design. ..
Anyone else experience this?
GeraldV is offline
post #2 of 15 (permalink) Old 03-15-2013, 08:55 PM
Hyundaiownersclub
Most 1.1Getz owners have in the UK
HYUNDAI TECHNICIAN BASED IN ESSEX UK. ALL HYUNDAI REPAIRS/MODS UNDERTAKEN INCL ENGINE/GEARBOXES Hi Scan and GDS equipment...
Hyundaiownersclub is offline
post #3 of 15 (permalink) Old 06-07-2013, 07:05 AM
joyauto
Seen this problem a couple of times, new crankshaft and all that goes with it.
same engine set-up as in the Kia picanto.
Just replace the gear with every timing belt change.
joyauto is offline
post #4 of 15 (permalink) Old 06-26-2013, 06:05 AM
Ruggero58
How often should the gear and belt be changed?
Ruggero58 is offline
post #5 of 15 (permalink) Old 05-14-2014, 12:20 AM
Andrel
Yes, I also have a worn pulley and amaged crank. Has anyone come up with a cheaper remedy as I've been told the only solution is to replace the crank and pulley.
Andrel is offline
post #6 of 15 (permalink) Old 06-12-2014, 11:58 AM
Andrel
Here in Cape Town I've discovered an engineering firm that re-machines the crack without removing the engine. Works out much cheaper. Andrel.
Andrel is offline
post #7 of 15 (permalink) Old 06-12-2014, 11:36 PM
atos prime
madguy is an unknown quantity at this point
Hi Andre
sorry,I want to ask...because not clear yet
How about this problem solution...welding,changing or.....explaine please
Thx
madguy is offline
post #8 of 15 (permalink) Old 08-03-2014, 12:28 AM
fanie is an unknown quantity at this point
what i have done is to drill a hole tap it and secure gear
fanie is offline
post #9 of 15 (permalink) Old 02-13-2015, 01:48 AM
I drive an Trajet 2.7 petrol Auto. My wife Atoa Prime 1.1
kennethmclennan is an unknown quantity at this point
Thumbs down mr k mclennan
I have 2006 atos prime 1.1. I am on my third cambelt pulley. I was told i need to replace my crank solve the problem. nice hey. Very stupid Design, for all that torque on the two slots.
kennethmclennan is offline
post #10 of 15 (permalink) Old 02-13-2015, 04:20 AM
hi Andrel, Can you please give me the contact details of these guys that may be able to solve my problem. Many thanks. I stay in Rondebosch
