Hey guys im new here. I have a marina blue elantra mt, i have the 15" wheels im upgrading soon to 18"s but i need help with the offset. Can i see some pics with your elantra with 18x7.5 +45. Does it rub?
Hi OP,
Your wheel combo isn't going to rub. it's even going to stick out towards the fender as Petabyte stated. Now unless your suspension is lowered you will not rub. If you do lower the car to get rid of wheel gap you can get the fenders rolled if ever the wheels rub.
Now the tire width though might cause problems. there is a math to upsizing wheels and tires. you should stick to 215/45/18's :
205-55R16 vs 215-45R18 - Tire and Wheel Plus Sizing | Tire Size Calculator
This makes sure you stay within you speedometer acceptable percentage and will drive alot better. Last thing is if you don't lower your car, your gap between the wheel and fender will look larger and seem off.
All things to consider.
@ Nicholas D
