1. I found 4 jugs of 5w-30 Pennzoil Plantinum in the garage.
2. I found all the receipts.
3. With car parked in the garage I can reach the oil drain plug and oil filter. Hyundai in their wisdom made it so nothing needs to be removed.
4. After installing a Fumoto or EZ Drain valve I am confident I can just change the oil reaching under the car. Like easy oil change with little mess.
So help me pick the proper valve. Fumoto is tried and true. I see an F-106 will work.
EZ Drain valve has some nice features like padded lever (the Fumuto lever always cut into my finger). It has extensions you can buy that look easier to use when hooking up a hose for less mess. But, I don't know if EZ Drain is as reliable as Fumoto? I emailed EZ Drain to see what they say.
And yes, I am crazy...Oil crazy. Too many years hanging around BITOG has affected my brain. It is called the oil wasting disease or Mad BITOG Disease.
Actually, I need to clean the garage of extra oil and using the oil is an easy solution.
