2001 Sante Fe Diesel Wont Start - Hyundai Forums : Hyundai Forum
Old 01-22-2009, 03:53 PM   #1 (permalink)
hamricheidi
Smile
2001 Santa Fe Diesel wont start in cold. It will turn over but wont fire up. I have replaced or repaired fuel filter, fuel injectors, and heaters but no change. Any advice? Please help this is driving me mad!!!!!!!!!!!!!!!!!
hamricheidi is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 03:56 PM   #2 (permalink)
itza's Avatar
itza
QUOTE (heidi @ Jan 22 2009, 08:53 PM)
This will in all probability be a sensor problem. If you can have someone check your ecm for fault codes it should show up on that .
Hope it helps
Itza
itza is offline   Reply With Quote Quick reply to this message
Old 01-22-2009, 06:50 PM   #3 (permalink)
byronguidry3732's Avatar
Heidi,
How cold is your nightime low in Vares? If you get below -35 Grad, no engine wants to start but especially diesel engines. The sensor problem listed above will give you a Check Engine Light. If you do not have a Check Engine Light, you may just have clouding/gelling in your diesel fuel.
My other post does list starting fluid/petroleum ether as a last resort. HOWEVER to isolate the problem,you might try a 1 second squirt in the air intake while having a helper crank the engine. If the engine fires and runs for a 2 seconds, your problem is clouded/gelled diesel fuel. Now that you have isolated the problem, you can use the solutions for gelled diesel fuel in the other post.
Byron
Where's my bailout?
