horn in engine bay? - Hyundai Forums : Hyundai Forum
Old 09-15-2013, 08:33 PM   #1 (permalink)
2013 Elentra GT
cbzdel is an unknown quantity at this point
Default horn in engine bay?
I see on the passenger side of the engine bay, this is not the standard horn as they are behind the bumper, or the beep from locking the car because that is on the drivers side behind the battery. What is it for? Anyone know?
cbzdel is offline   Reply With Quote Quick reply to this message
Old 09-15-2013, 11:11 PM   #2 (permalink)
Flying Turtle's Avatar
Drives 2013 Elantra GT
Flying Turtle is an unknown quantity at this point
I noticed this the other day, too. I think it must be a security honker. Sometime I'll work up the courage to test it.
Geoff
Flying Turtle is offline   Reply With Quote Quick reply to this message
Old 09-16-2013, 07:50 AM   #3 (permalink)
TurboLed's Avatar
Drives Elantra GT GL 2013
It's probably the low pitch horn ?
1. Horn switch
2. Horn relay (Engine room compartment)
3. Clock spring
4. Horn - Low pitch
5. Horn - High pitch
TurboLed is online now   Reply With Quote Quick reply to this message
Old 09-16-2013, 08:52 AM   #4 (permalink)
'13 Accent GS (Daughter) '13 Elantra GT (Mine) '13 Sonata GLS(Wife's)
AAAAccent is an unknown quantity at this point
The Hi and Low horns can be seen when you pull off the front bumper. However, they can't be seen from the engine bay. The horn that chirps when you lock your car seems to sound different from the Hi Lo horns. Perhaps just uses one of them. I do not have it programmed in my car though. Usually alarm horns are also mounted in the engine compartment, but I find them to be most effective inside the passenger compartment loud and piercing that makes the would be thief want to get out and away from that sound quickly. Where exactly is it located?
AAAAccent is offline   Reply With Quote Quick reply to this message
Old 09-16-2013, 10:48 AM   #5 (permalink)
2013 Elentra GT
hard to get a good pic in the dark, but its right behind the engine mount. You can see the round horn. If you get a better angle from the side you can clearly tell it is a horn.
Again the beep beep from locking/unlocking the doors comes from behind the battery area, so this is not it.
Old 09-16-2013, 12:14 PM   #6 (permalink)
PLP
2007 KIA Rondo, 2.7 V6, 5 A/T 2009 Hyundai Elantra, 2.0 I4, 5 M/T, sedan, GLS, black pearl
PLP is an unknown quantity at this point
did you check which horn is activated when you open locked/armed door?
PLP is offline   Reply With Quote Quick reply to this message
Old 09-16-2013, 12:41 PM   #7 (permalink)
2013 Elentra GT
That I have not done, I dont know if you can activate the alarm if you have the hood open. I should try that though..
Dont see why they would have a separate horn for that though.
OH!! There is also that, walk away from a running car with the smart key in the pocket, that loud beep goes off..
Old 09-16-2013, 05:42 PM   #8 (permalink)
It is for the alarm. How could I have missed that big honking thing right there all this time?
Old 09-16-2013, 05:46 PM   #9 (permalink)
2013 Elentra GT
For the alarm huh, I wonder why they did that rather than using the regular horns?? I see no point in this car having a total of 4 horns haha!!
Old 09-16-2013, 09:35 PM   #10 (permalink)
Here is the proof once and for all.
