Jacking points? - Hyundai Forums : Hyundai Forum
Old 03-20-2013, 09:12 AM   #1 (permalink)
Black 2013 Elantra GT SE
xmai77 is an unknown quantity at this point
Default Jacking points?
I'm wondering where the jacking points are for our car. I've checked HMA service and the only locations I've found are these:
https://www.hyundaitechinfo.com/data...sgdgi2002e.gif
Where are the jacking points on the underbody?
Edit: I've found one possible location at the front hydraulic garage jacking point!!. What about the rear? Does anyone have pictures of the jacking points they use on their EGT?
xmai77 is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 09:38 AM   #2 (permalink)
orrider's Avatar
2006 Sonata
orrider is an unknown quantity at this point
All very clearly explained in the owner's manual. Get down on your knees and you'll see the reinforced points under the rocker panels.
orrider is offline   Reply With Quote Quick reply to this message
Old 03-20-2013, 09:40 AM   #3 (permalink)
Thanks for your reply. I understand I can jack underneath the rocker panels. I'm looking for jacking points in the center line of the car so I can jack the entire front or rear end up. I don't want to have to jack each of the four spots under the rocker panels.
Old 03-20-2013, 09:48 AM   #4 (permalink)
orrider's Avatar
2006 Sonata
I hear you. In the past I have looked for body cross members. However, with present day unibody design that can be tricky. Look for something that also becomes an anchor point for the suspension which would be strong enough to carry the car. Have not bothered with this method in years and cannot direct you to a fail safe point.
Old 03-20-2013, 09:49 AM   #5 (permalink)
Gotcha. Thanks anyway. It seems like they're really trying to stop us from performing our own standard maintenance!
Old 03-20-2013, 11:52 AM   #6 (permalink)
2007 Hyundai Tucson 2013 Hyundai Elantra GT SE-no tech. Titanium Gray
flyfisherdon
One suggestion would be to put a piece of 4x4 lumber between the places mentioned in the manual for jacking, then you could jack the whole front/rear up.
That is if there is nothing ,like an exhaust pipe in the way??
Don
flyfisherdon is online now   Reply With Quote Quick reply to this message
Old 03-23-2013, 01:50 PM   #7 (permalink)
K.Fraser's Avatar
K.Fraser is an unknown quantity at this point
Be careful, the stock jack points are horrible and will bend if you use the wrong jack.
K.Fraser is offline   Reply With Quote Quick reply to this message
Old 04-17-2013, 04:37 PM   #8 (permalink)
Any more thoughts on possible jacking points besides the ones under the rocker panel? Somebody here must do their own wheel changes :S. I'd rather not have to jack the car 4 times to change 4 wheels.
Old 04-17-2013, 10:07 PM   #9 (permalink)
Drives 2013 Elantra GT SE Tech in Atlantic Blue, 2001 Honda Sabre VT1100, 2007 Suzuki Vstrom DL1000
warpdriv is an unknown quantity at this point
I changed out my wheels a couple weeks ago. I like you wondered and did a little reading here.
For the front, there is a wide flat cross member a ways back at the rear of the engine. But my roller hydraulic jack would not access it and allow the handle to pump up and down to raise the jack... the handle was under the car with limited verticle movement. Now I was told (since) using a heavy screw driver or bar that is shorter would work to raise the jack enough to get the jack stands under.
But I did it a different way, it worked for me and I was surprised by the structural stiffness of the GT when doing it. I used the hydraulic jack on the same cross member... but rolled the jack in behind the drivers front tire under the wheel well as far under as possible to that same cross member. It was not on the centerline of the car... but a more than 1/3 of the way across and could use the jack because the height of the wheel well allowed the handle enough verticle movement. The jack lifted the car w/ both wheels up enough to slide the jack stands under - but the lift was not even.. but close to even (1" difference). I watched that lift very carefully from the front and was pleased with the GT's rigidity to lift off centre. Lowered the car onto both jack stands under that same cross member. Next time I will use a piece of wood between the jack and the car for a tad extra height and to avoid the steel jack on the steel crossmember - concerned about scratching the undercoating.
For the rear... I don't know. I looked and found no suitable Hyundai location.
My car is equipped with a trailer hitch... and I used it on the centerline of the hitch gusset plate for lifting and the hitch cross member to slide the jack stands under. Strong and stable. Easy access because it is at the rear of the car. But because it is also so far behind the axle... the jack (my smallish hydraulic jack) had to be used to max lift to get the jack stands under. Again, next time I will use a wooden shim either under the jack or on the lift plate to gain an extra inch of lift and avoid marking the underside of my hitch.
I used wheel chocks for one tire on opposite end of the car I was lifting.. plus set the handbrake.
Somewhere I read (on the jack stands box) warns against lifting one side of the car front and rear. It should be the rear only, or front only.
That how I raised my GT for tire changeout and placed it onto jackstands.
"Every man dies. Not every man really lives." - William Ross Wallace (Braveheart)
Extra's; window visors, front splash guards, Curt hitch & wiring, 35% Llumar tint, interior LED lights, 6000K HID low beams, Weathertech front and rear floor liners ...
warpdriv is offline   Reply With Quote Quick reply to this message
Old 04-17-2013, 10:30 PM   #10 (permalink)
LeMeez's Avatar
2013 Elantra GT SE Tech package - white
LeMeez is an unknown quantity at this point
I made a ramp out of three layers of 2" x 6" with the ends cut at a 45 degrees then nailed together. I then drive the front wheel up on the ramp then jack the car from the front jacking point. Both the front and rear wheels will come off the ground. This is great for swapping directional tires front to back and vis versa. Also good for painting callipers 2 at a time. I made 2 ramps that are used for changing the oil. Have used these on about 6 cars now and works for all.
LeMeez is offline   Reply With Quote Quick reply to this message
