Radio System Problems - Hyundai Forums : Hyundai Forum
Old 12-12-2012, 01:30 AM   #1 (permalink)
Elantra GT
markjenn is an unknown quantity at this point
Default Radio System Problems
Thought I'd document an issue I had today with the radio/multimedia unit on my base (non-tech) 2013 Elantra GT. Basically the head unit crashed and wouldn't go into radio mode at all. Some buttons would work but very few and the screen often contained gibberish.
I cycled the ignition key when I was stopped and this solved the problem for a minute or so, but then it returned. When I got home, I pulled the fuse for the radio unit which caused a hard reset where I had to enter the date/time again. (It remembered my bluetooth pairings though.) That seemed to bring things back to normal. I think there are some bugs in the system.
If your radio needs "rebooting" it's a 15A fuse marked "Multimedia" in the interior fusebox which is accessed behind a plastic panel just above the driver's left knee. Might save you a needless trip to the dealer.
- Mark
markjenn is offline   Reply With Quote Quick reply to this message
Old 12-17-2012, 09:52 PM   #2 (permalink)
Drives Elantra GT
bigdaddio is an unknown quantity at this point
I just wanted to thank you for the info.
When I got into my car tonight I whacked my calf on the side panel (I guess near where the fuse box is). I then started the car and my radio wouldn't turn on at all. I cycled the ignition a few times but nothing. I figured I'd have to call the dealership tomorrow (even though the car is brand new these things happen).
I just read your post and went up and did the same thing and now my radio works.
Now I'm wondering about my build quality if I can accident smack a side panel and have the fuses come loose
bigdaddio is offline   Reply With Quote Quick reply to this message
Old 12-17-2012, 10:50 PM   #3 (permalink)
M3Chef's Avatar
TG Elantra GT
M3Chef is an unknown quantity at this point
The media system in general works about as well as my last smart phone, which is to say not very well. No radio issues per se, but lots of ongoing issues with bluetooth linkage and storage issues (contact info, last called number, etc.).
M3Chef is offline   Reply With Quote Quick reply to this message
Old 12-20-2012, 11:20 AM   #4 (permalink)
Drives Elantra GT
jamina1 is an unknown quantity at this point
Mine has been doing something similar - 2 days after I purchased it I started the car and began to drive and the headunit rebooted. Everything was fine afterwards.
2 days ago while driving home from work, I had just started the car and begun to drive and it did it again. Basically what happens is that it just stops, goes black and reboots as if you just started the car.
I'm not sure what's up but if it keeps doing it I'll bring it up with the dealership.
Previously owned a 2005 Elantra GLS 5-door
jamina1 is offline   Reply With Quote Quick reply to this message
Old 12-20-2012, 01:56 PM   #5 (permalink)
Elantra GT
I've has these reboots a few times too. Do you have a BT phone? I figure these glitches are probably associated with the pairing software.
Since the problem corrects itself and is probably not reproducible, I doubt you'll have much luck convincing the dealer to do anything, but let us know how that goes if you try.
- Mark
Old 06-09-2013, 11:35 AM   #6 (permalink)
Hyundai elantra GT GL 2013
marcogt is an unknown quantity at this point
Today, my radio sopped working totally, nothing to do, it dosnt light up ! will call the dealer tomorrow.
Radio seems to be a problem in our GT's
marcogt is offline   Reply With Quote Quick reply to this message
Old 06-09-2013, 12:35 PM   #7 (permalink)
Drives: 13 Elantra GT. Toy: 89 Shelby CSX-VNT
BorisTheSpider is an unknown quantity at this point
Check your fuse first.
Lynn Travers
BorisTheSpider is offline   Reply With Quote Quick reply to this message
Old 06-09-2013, 05:43 PM   #8 (permalink)
ya the fuse is ok
Old 06-09-2013, 11:56 PM   #9 (permalink)
2013 Elantra GT GLS Auto
Frelo is an unknown quantity at this point
I had similar problems a while ago. Took a video of the problem & showed it to my dealer. They replaced it with no questions asked. No problems since, he says with his fingers crossed. :-!
Frelo is offline   Reply With Quote Quick reply to this message
Old 06-10-2013, 08:02 AM   #10 (permalink)
2013 Elantra GT Tech titanium silver, blue interior
dutch-brew is an unknown quantity at this point
Mine has done the same thing as well..
The first time it was just a blank screen that stayed on.. Couple weeks ago it was as i turned off the car, and the current song info just stayed on.
Called em and they ordered a new radio in, hopefully that will fix it
Mine also at times does the "reset" thing where it will turn off and ccome back on.
Hope a new radio will fix that as well
dutch-brew is offline   Reply With Quote Quick reply to this message
