HID's installed - Hyundai Forums : Hyundai Forum
Old 11-18-2012, 10:30 PM   #1 (permalink)
LeMeez's Avatar
2013 Elantra GT SE Tech package - white
LeMeez is an unknown quantity at this point
Default HID's installed
I installed these a couple of weeks ago. I used Xenon 5000k bulbs. At first, I just did the simple kit install, took about 20 minutes all together. But I soon found out they they didn't always come on, especially with the auto lights feature. So I added in the capacitor kit to each side and that solved all the issues. They now work flawlessly, no flickering whatsoever. The capacitors are a very simple 1 minute per side install, just plug and play into the ballast. The trickiest part of the original installation was running the harness through the dust cap. I ended up breaking off one of the vanes with a wire cutter then drilling a 1" diameter hole in it. The wire harness has a rubber grommet that fit perfectly, keeping the headlights sealed.
The cut off has not changed, the only real change is a brighter, whiter, crisper light output. It hard to see in these photos but you can get the idea. All in all, I'm very happy with them, would never go back to halogens. I had them on my last car for 6 years without any issues.
Wire harness on left side with ballast stuck between the battery and fuse box, capacitor between battery and air box:
Dust over with rubber grommet:
Right side with ballast and capacitor wire tied under the hood support rod base:
During daylight, but you see the difference in colour:
A little darker outside:
LeMeez is offline   Reply With Quote Quick reply to this message
Old 11-18-2012, 11:20 PM   #2 (permalink)
Drives 2013 Elantra GT SE Tech in Atlantic Blue, 2001 Honda Sabre VT1100, 2007 Suzuki Vstrom DL1000
warpdriv is an unknown quantity at this point
Thumbs up which kit did you use?
hmm... I'm new to this forum, so I apologize if the info on the HID kit is posted elsewhere. Do you mind letting me know what kit you bought and from where? How did you decide which brand of kit to purchase?
I am in Ontario as well. I am just over 2000 km on my 3 week old GT, but the first item I want to improve is the night lighting.
My previous car had factory HID lighting... guess I am spoiled for it.
~Brad
warpdriv is offline   Reply With Quote Quick reply to this message
Old 11-18-2012, 11:54 PM   #3 (permalink)
Drives Elantra GT GLS GD
CanuckElantraGT is an unknown quantity at this point
Looks good sir! I can't wait to get mine done in the spring! I'm very jealous right now lol
CanuckElantraGT is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 12:29 AM   #4 (permalink)
2013 Elantra GT White, Black int. Touch & Go Pkg
SacGT is an unknown quantity at this point
Did you use 35w or 55w HID bulbs?
SacGT is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:40 PM   #5 (permalink)
Bartacus's Avatar
Drives 2013 GT GLS
Bartacus is an unknown quantity at this point
LeMeez: don't we canucks have HIDs standard? Mine seems to (judging by the look of the headlight). I'm kinda confused. Then again I'm stupid, so that happens often!
Bart
Bartacus is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:50 PM   #6 (permalink)
Winkle's Avatar
2013 Elantra GT SE
Winkle is an unknown quantity at this point
No we don't, HIDs are not optional either. We have standard halogens.
HID's give off a bluish tint.
"God's in His heaven. All's right with the world." - Robert Browning (1812-1889)
Winkle is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:57 PM   #7 (permalink)
crownr0yal's Avatar
Drives 2013 Crystal Black Pearl Honda Accord Coupe EX-L
crownr0yal is an unknown quantity at this point
Can you take a picture of them up against a wall? I'd like to see the cutoff.
crownr0yal is offline   Reply With Quote Quick reply to this message
Old 11-19-2012, 03:58 PM   #8 (permalink)
Bartacus's Avatar
Drives 2013 GT GLS
Really? That's awfully weird then, since I'm sure I have projectors. Unless there's somehow a halogen bulb in my projector housing. I've never seen halogen headlamps that look like this. My low beam looks identical to the projector housing on my other car with HIDs.
Bart
Old 11-19-2012, 04:02 PM   #9 (permalink)
crownr0yal's Avatar
There are plenty of cars with projector halogen headlights. Sonata, Dodge Dart, Honda CR-Z....
Old 11-19-2012, 04:04 PM   #10 (permalink)
Winkle's Avatar
2013 Elantra GT SE
Projectors are just a type of reflector, HID's are generally projectors as they focus the light better but you can still have halogens in projectors.
All factory-installed HID's are in projector housings, you can buy 3rd party HID's that are not in projector housings but those are of questionable legality.
Yep, all 2012 and 2013 Mazda3's have projectors and they're all halogens except for the top of the line 2.5 engine trims that has HIDs.
