Elantra gt gas mileage - Hyundai Forums : Hyundai Forum
Old 11-27-2012, 04:27 PM   #1 (permalink)
Drives elantra gt
Slazman999 is an unknown quantity at this point
Default Elantra gt gas mileage
When I got this car in October my trip meter said 30.9mpg and stayed like that for about a month and it has dropped to 29.5mpg and is staying there. I have not changed my driving style at all. I slowly accelerate and decelerate, use cruise control almost always and drive on roads that are 40-55 mph. Could it be my trip meter or am I just a crappy driver?
Slazman999 is offline   Reply With Quote
Old 11-27-2012, 04:37 PM   #2 (permalink)
Drives Elantra GT
cramam is an unknown quantity at this point
Several possible explanations. You don't say where you live but a change in temp with the season will affect mileage. I just had my low tire pressure light come on with a cold snap and sure enough all 4 tires were down about 4 lbs. Also, regions switch to reformulated winter gas which generally produces lower mileage.
cramam is offline   Reply With Quote
Old 11-27-2012, 04:41 PM   #3 (permalink)
Drives elantra gt
4lbs of air can drop your gas mileage that much?
Old 11-27-2012, 04:56 PM   #4 (permalink)
GT155's Avatar
Drives 2013 Elantra GT SE Atlantic Blue, Beige Interior, Auto, Style & Tech
GT155 is an unknown quantity at this point
Did you try resetting the tripometer back to zero? Hold in the reset button on the right side of the steering wheel for a few seconds and it should reset. I reset mine whenever I get gas.
GT155 is offline   Reply With Quote
Old 11-27-2012, 05:40 PM   #5 (permalink)
Drives Elantra GT
Again, I am suggesting a combo of factors. However, 4 lbs. of air pressure was enough to cause my low pressure light to come on. Also, you are only talking a 4% reduction in mileage. This isn't a particularly large deviation.
Old 11-27-2012, 05:56 PM   #6 (permalink)
2013 Elantra GT A/T - PZEV, Touch & Go, Titanium Gray
talkingrat is an unknown quantity at this point
DOE estimates 0.4% MPG loss per 1 PSI on all four tires, and 3-4% for 10% ethanol winter fuel. Winter tires take their toll on MPG, too. On my old car, winter tires + winter fuel drops MPG by 10% on freeway, less around town.
talkingrat is offline   Reply With Quote
Old 11-27-2012, 08:06 PM   #7 (permalink)
Elantra GT
markjenn is an unknown quantity at this point
Unless you have a lot of steady freeway cruising at moderate speeds (less than 70 mph or so), you'll have great difficulty getting mileage above 30, even if you're very gentle with the throttle.
29.5 is better than a lot (most) of us are doing. It's certainly better than I'm doing. Keep in mind that the EPA ratings for this car are now 27/37, so 30 is not out of line at all.
- Mark
markjenn is offline   Reply With Quote
Old 11-27-2012, 09:21 PM   #8 (permalink)
GT155's Avatar
This is my best so far.
Old 11-27-2012, 09:38 PM   #9 (permalink)
TurboLed's Avatar
Drives Elantra GT GL 2013
Taking a picture while cruising at 60 MPH... No comments :P
TurboLed is offline   Reply With Quote
Old 11-27-2012, 09:49 PM   #10 (permalink)
LeMeez's Avatar
2013 Elantra GT SE Tech package - white
LeMeez is an unknown quantity at this point
That's why it is out of focus and blurry.
LeMeez is offline   Reply With Quote
