LinkBack | Thread Tools |
#1 (permalink) |
Drives Elantra GT
Hi guys,
I'm considering an Elantra GT as we speak, but I had a quick question. I currently own an '05 Elantra Hatchback and it has 2 power plugs up front much like the new GT. However, one of my BIGGEST COMPLAINTS about the '05 is that when the ignition is off, both plugs are also disabled, so you can't charge your phone unless the car is on. Is this also the case with the new GT? Is the one in the cargo compartment always hot? Thanks for any information! I love the way the new GT works and I'm excited about buying one, but I'd like to know about the little things first. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) | |
Elantra GT
- Mark |
#4 (permalink) |
Elantra GT
Haven't checked, but I'd be flabbergasted if it was powered with with ignition off. This would require a separate USB power supply circuitry apart from the radio system (which is obviously switched).
Pretty uncommon these days to see an "always hot" socket on a new car. You may be forced into rigging an extra socket with a separate run to the fuse box. - Mark |
#5 (permalink) |
2013 Elantra GT SE tech
The Elantra Touring's rear outlet was always on. I have not checked but assumed this was the case with the GT.
I checked the manual and there is no mention so there is a decent chance my assumption was wrong. I'll have to check the next time I have the car. |
#6 (permalink) | |
Elantra GT
- Mark |
#7 (permalink) |
Drives Elantra GT GL 2013
A quick mod would be to cut the rear power outlet wire at the junction box and splice it to the memory output which is a fused 15 amps (you would get a bit less power but still).
https://www.hyundaitechinfo.com/data...dsd13945an.svg |
#10 (permalink) |
Black 2013 Elantra GT
If you need to charge your phone with the car off, then it's time for a new phone. Why don't you get an iPhone and kill two birds with one stone? Charge and listen to your music library at the same time. Voila!
www.stagefourmotorsports.com Need Accent strut bar or lowering springs? http://www.hyundai-forums.com/143-cl...ket-parts.html |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
