LinkBack | Thread Tools |
#51 (permalink) | |
MODERATOR
as I see this is your first post...
Fashionista. Former driver of 2011 Elantra Limited no tech, and 2010 Genesis Coupe 3.8 Track
| Sponsored Links | |||
Advertisement | |||
#52 (permalink) |
2013 Elantra GT
SE Tech package - white
Your welcome DJ, that looks similar to my capacitors but the writing on it is questionable, never seen them called a decoder but the description, size, wiring looks identical, you'll be all set.
#54 (permalink) |
Drives Elantra GT GLS GD
I've never had that happen with my car... You sure you aren't twisting the light control stalk at the same time? I've only ever had my DRL become high beams when flashing someone during the day with my lights off.
#58 (permalink) |
Drives Elantra GT GL 2013
I looked at the schematics and there is probably a way to avoid this behavior by inserting a diode going to the "head lamp low signal" between the light switch and the BCM. This way, when the passing switch grounds the high beam signal, it will not be grounding the low beams by making the current go back to the head lamp low signal.
![]() The brown wire is still needed to let the high beams work only when the headlamp switch is grounded (blue wire) |
#60 (permalink) | |
2012 Sonata LTD with Navi and Pan Roof
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
