LinkBack | Thread Tools |
#1 (permalink) |
Sante Fe Sport 2T P&T (wife)
Elantra (daughter)
Saab 9-5 (me)
Hi just picked up a Sport with 2.0L turbo - manual says regular us grade, I think 87 octane rating. So I didn't ask the dealer but assume it's ok to use 85 in Colorado as that's what most cars that run on regular grade use here.
I have a couple of Saabs that can run on regular gas but cannot use 85 rated gas here in CO, it must be 87 or higher, the Saabs use a different type of combustion and knock detection and the engine can produce more power with premium fuel. Just a comment on engine performance - I'd agree with a couple of the reviews I read saying that in certain conditions the engine seems to be uneven with respect to smooth power output and throttle response, but overall it's pretty potent for a 2 liter. |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
2013 Santa Fe Sport 2.0T AWD
Hi dtech, Small world. I live in Westminster as well. I have been running 87 due to the turbo. The turbo and its nature sort of makes the altitude a moot point (within reason) as the boost stays relatively constant no matter the altitude and thus the cylinder pressures are relatively constant which is definitely not the case on a NA engine. During the winter I think its probably safer to run lower octane due to the lower intake temp reducing the chance of ping. During the summer I would say 87-89 minimum.
#3 (permalink) |
Drives Santa Fe '13
Drives Camry '02
Drives Excursion '03
Drives Tige '03
I agree its a small world.......I use 87 Octane and have had no problems so far at 3,500 miles. That extra $1.50 in the added cost is well worth it for the octane.
#4 (permalink) |
Drives: 2005 Tiburon SE V6; 2008 Santa Fe Limited AWD
Should be ok with 85. Almost all Hyundais recommend 87 including my Tiburon and Santa Fe, but I've run both on 85 here in Utah with no issues whatsoever.
#5 (permalink) |
Elantra (daughter)
Saab 9-5 (me)
yeah but are your cars turbo charged ? As pointed out the turbo will compensate for less dense air at higher altitudes, different from a na engine so I will feed it 87 as recommended.
#6 (permalink) | |
In any case, it can't hurt to run higher octane and you'll probably see a little more power too, though it may not be enough to notice. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
