For those using the Torque app you may have noticed that when you fully depress the accelerator pedal the throttle % won't pass from 74.5. Also if you remove the intake hose to see the throttle valve you will notice that is not completely open when the gas pedal is floored.
When I read this thread http://www.hyundai-forums.com/233-rb-2012-accent/164583-those-using-torque-app.html someone posted that it may be limited by the gas pedal so my curiosity made me make some tests.
Tools needed:
1. 12mm socket and ratchet
2. A dremmel with a grinding stone like this one https://www.dropbox.com/s/w4b4fdkdbpdg2g4/20130803_141602.jpg (you can use something similar)
First I removed the accelerator pedal using a 12mm socket to remove two nuts that hold the part in place and disconnected the electrical connection. The plug has a red tab that you have to pull out and it disconnects.
You can see that here https://www.dropbox.com/s/0u5y27klnsnj26e/13 - 1.png
I partly disassembled the pedal and it looks like this https://www.dropbox.com/s/2po8hktdzmb1zcj/20130803_110558.jpg
But you don't have to open it and I recommend not doing it. If you mess with that then you will have to calibrate the accelerator pedal, is not difficult to do it but takes some time.
What I did was grind the part of the pedal that limits the travel with the grinding stone. This was how the pedal looked stock https://www.dropbox.com/s/8yi6hk9rnzviic0/20130803_111713.jpg . And after carefully grinding it to make it flat https://www.dropbox.com/s/hdguubydpc39goj/20130803_123315.jpg
I noticed that there is a limit on the opening %, it is 83.9. I grinded more but it wont pass that number. This is the Torque app screenshot https://www.dropbox.com/s/f9l6xpm2holrj51/Screenshot_2013-08-03-12-44-59.png
Installation is reverse as removal. I didn't disconnect the battery cable but is recommended to do every time you work on the electrical stuff of the car.
So for those that had the curiosity of why the throttle wasn't opening more this is one of the reasons.
As for performance I haven't fully tested the car but for now I don't feel any difference other than the pedal going further down. I will do now a semi long trip on the highway and I will let you know if I feel more power. lol :laughing:
Tools needed:
