LinkBack | Thread Tools |
#1 (permalink) |
2012 Hyundia Accent 5 Door Hatchback, Green Apple, - 2005 Toyota Echo, - 2000 Dodge Ram 1500.
Hello: wondering if maybe someone could help, I have a 2012 Accent Hatchback bought May 2012, (13,000 km. had two oil changes) with a problem starting on cold morning (below freezing) , great other times, starts soon as you turn key . When cold it will start but you have to hold the key on longer. Once running everything works fine for the rest of the day ontil the next cold morning. Talked to dealership and was told it had something to do with Immobilizer Indicator and to make sure its not flashing and to try turning key on and waiting until this light went out and to then start car, tried that no better, next option is to drop car at dealership and they would have a look. I am not a car person, very little knowledge, So I'm looking for any info so I am prepared when I go to dealership. Thank You in advance .
| Sponsored Links | |||
Advertisement | |||
#3 (permalink) | |
2012 Hyundai Accent SE
Hyundai-Forums.com's FIRST blue 2012 Accent SE! 2012 Hyundai Accent SE 5 door A/T. Marathon Blue with black interior. Bought new with 7 miles
#4 (permalink) |
Thanks for the info, I normally go to a service station near my home for oil changes since I don't live that close to the dealership, and I am going by the mechanic there, it is doing exactly that taking two or more cranks on cold mornings, I was worried some really cold morning it wouldn't start.
(it can be -10 f. or lower here for days) Think I'll purchase a blockheater, and not bother the dealership right now. |
#5 (permalink) | |
Drives 2012 Accent SE ATX
Drives 2007 Yamaha FZ1
#6 (permalink) |
Oil used is Quater State 5w20
2012 Accent 5 Door Hatchback, Green Apple, bought in May 2012 |
#7 (permalink) |
synthetic? or conventional?
conventional also takes a little longer to circulate versus sythetic so that could make the car start a little slower too i would think because its making the oil sender work overtime causing the electronics to draw more current. I peronally an now using Kendall synthetic blend since down here it never gets that cold
#8 (permalink) |
Doesn't matter whether you use full synthetic or synthetic blend. The lower viscosity the oil, the better it flows during cold starts. If you're situated in NS, would suggest that you use 5w20 or 0w20 for better oil flow. Have your spark plugs checked as well to make sure you're not running on foul ones. Your car is fairly brand new so I wouldn't expect any battery terminal deterioration, however, check the tightness of each terminal to make sure.
Your spark plugs part number is LZKR6b-10e, NGK is the brand. There's a Denso replacement for this but i'm not sure of the part number. Suggest you go to your dealer and purchase one. Last edited by PowerFreak; 12-18-2012 at 10:05 AM. |
#9 (permalink) |
Drives: 2013 Sonata GLS,
2009 Venza AWD V6,
2010 Toyota Corolla,
2008 Pontiac G5,
2010 Mazda 3 G
When you say one or two more cranks, can you say it takes 1 - 2 seconds to fire vs. starting immediately? I noticed the same think on my 2013 Sonata GLS. Definitely takes longer to start when it has been outside at -10 C vs. in the garage at 4 C. I think it is a GDI thing. I am not worried (at this point) We'll see when it hits -25 C.
#10 (permalink) | |
If I was up north, i would definately be using a full easter based oil to maximize protection.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
