Mixing 2 brands of 5w-20 oil? - Hyundai Forums : Hyundai Forum
Old 11-25-2012, 07:35 AM   #1 (permalink)
2013 Accent GS 6MT & 1996 Miata 5MT
2013AccentGS6MT is an unknown quantity at this point
Default Mixing 2 brands of 5w-20 oil?
I changed the oil at 2,000 miles, and yesterday at 5,000. The first change I used Pennzoil Platinum, and the 2nd I used Castrol Edge because the store was out of the Pennzoil in 5w-20. Both are full synthetic and expensive at about $10 a quart. Now I have 1.5 quarts of each left over. Can I combine them when I do my next change at 10,000 miles or is that a bad idea?
PrecisionLED 6000K interior + license plate bulbs
SE leather/chrome shift knob (came scratched!)
Debadged 'Accent' letters
OEM cargo tray and cargo net
Weathertech Digital Fit front mats
XenonSupply 4300k HID headlights
Injen SP1340BLK CAI + Hydroshield
2013AccentGS6MT is offline   Reply With Quote
Old 11-25-2012, 08:05 AM   #2 (permalink)
Drives: 2013 Sonata GLS, 2009 Venza AWD V6, 2010 Toyota Corolla, 2008 Pontiac G5, 2010 Mazda 3 G
Danno is an unknown quantity at this point
No issues with doing that.
Danno is offline   Reply With Quote
Old 11-25-2012, 09:02 AM   #3 (permalink)
someguy's Avatar
I agree and Im planning to do the same thing. My next oil change will be a mix of Pennzoil Platinum, Pennzoil Ultra, and Quaker State Ultimate Durability. I always use synthetic and buy whatever has a sale or rebate.
someguy is offline   Reply With Quote
Old 11-25-2012, 09:21 AM   #4 (permalink)
rattlecanned's Avatar
'13 genesis coupe
rattlecanned is an unknown quantity at this point
Mixing brands wont make a difference, just never mix weights.
rattlecanned is offline   Reply With Quote
Old 11-25-2012, 10:07 AM   #5 (permalink)
MODERATOR
hoosieraccent's Avatar
Drives: 2013 Chevrolet Sonic LT 1.4 turbo/6AT, Accent MC (gone but not forgotten.)
I've read up a lot about this, varying opinions on the subject it seems. Some say go ahead, others say don't, while a few say stay within the same manufacturers to keep the same add packs in there to avoid "additive clash."
I've done it before - with cheap store brand conventionals even - and the car still runs... Mixing doesn't particularly give me any cause for concern.
Ride Of The Month
Forum Rules
hoosieraccent is offline   Reply With Quote
Old 11-25-2012, 05:00 PM   #6 (permalink)
fsv87's Avatar
Drives 2012 Marathon Blue Accent SE R.I.P 2001 Elantra GLS
fsv87 is an unknown quantity at this point
Shouldn't have a problem as long as it's all 5w20.
If it ain't broke, fix it till it is.
fsv87 is offline   Reply With Quote
Old 11-25-2012, 06:28 PM   #7 (permalink)
Past racer's Avatar
2012 Accent GS Automatic
Past racer is an unknown quantity at this point
I will add something from quite awhile back (don’t remember source, just some details). It was about engine bearing failure being attributed to mixing of oil brands. It pointed out the failure was caused by a chemical reaction between two additives that where in different brands of oil. It indicated that mixing many additives manufactures put in their oil would not cause a problem, but on occasions the mixing takes a toll on lubricating qualities. I remember it saying that mixing different weights or dino and synthetic of same brand was not a problem, because manufactures test to make sure there is no reaction between additives they use in all their oils. In summary it wasn’t the oil bases that were the problem but the additives.
Something like nitro and glycerin are ok by themselves…. But putting them together might get your attention.
Past racer is offline   Reply With Quote
Old 11-26-2012, 11:15 AM   #8 (permalink)
2012AccentSE's Avatar
2012 Hyundai Accent SE
2012AccentSE is an unknown quantity at this point
Should be ok. I have done it in the past with no issues to speak of.
Hyundai-Forums.com's FIRST blue 2012 Accent SE!
2012 Hyundai Accent SE 5 door A/T. Marathon Blue with black interior. Bought new with 7 miles
2012AccentSE is offline   Reply With Quote
Old 11-26-2012, 10:48 PM   #9 (permalink)
isd.jwendell's Avatar
2012 Accent man SE
isd.jwendell is on a distinguished road
Tough call for me... The chemist in me says don't mix, but why not? When you change the oil, completely draining it doesn't really drain all of the old oil. So, switching from one brand to another will cause mixing. Synthetic oil had to be compatible with regular oil for this reason. However, that mixing is not the same as a 50:50 mix. The old oil will eventually get diluted, unless you constantly alternate between the two brands. So, is it worth the potential problems (not saying that you would see any)?
isd.jwendell is offline   Reply With Quote
Old 11-27-2012, 10:13 AM   #10 (permalink)
Drives 2012 Accent GLS (RB)
I have about 1/5 a quart of Quaker State Ultimate Durability and 3 quarts of Castrol Edge, both are same weights. I has the QSUD laying around and didn't want it to go to waste.
mrmr256 is offline   Reply With Quote
