LinkBack | Thread Tools |
#1 (permalink) |
2012 Accent SE Hatchback Automatic
After about 1000 miles on brand new snow tires the wear pattern on the driver side rear wheel makes it pretty clear that the camber is off...no wear at all on the outer half inch of the tire. Tire guy double-checked alignment and it's right on...says there is no adjustment in the rear for camber.
Thoughts? |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
2006 Sonota 3.3L Auto
2012 Accent GLS 1.6L Manual
He is correct, its the tortion bean rear axel. There is no adjustment.
"The Mouse" 2012 Accent Century White GLS, Manual Trans Mods OEM fog lights, Oil Catch Can, DIY Soundproofing, Rial Campo Rims, LED Conversion, Horn-ectamy, SE Shift Knob, Heated Mirrors, Heated Seats, Auto "off" Parking/Tail Lights, OEM LED Side Mirrors, OEM Bluetooth & Steering Wheel Controls, Mobis Window Visors, GDi Badge, Stubby Antenna,
CIPA Auto Dimming Mirror with Temp and Compass, Eagle Eyes LED Tail Lights, AEM Cruise Control |
#3 (permalink) |
12 Veloster
08 Accent GLS(R.I.P.)
08 Bullitt Mustang
04 Yamaha FZ6
82 Dodge D150
83 Iveco Z110
There are shim-kits you can use that fit beneath the spindle.
Unless you have one HELUVA bent axle, it's not the camber that wore the tire out in a thousand miles - it's the toe setting.
Parfois, on fait pas semblant! |
#5 (permalink) |
13 Accent SE (RB) with sunroof
A thread two months ago said early 2012 models had problems with alignment because of the way the car was strapped down for shipping. I think it was said it led to cars having bent rear beams.
If you could uncover more about that, maybe you could push it further under warranty. Did the previous tires wear similar to these new tires? |
#6 (permalink) | |
Drives 2013 Accent GS 6sp manual
thanks. |
#7 (permalink) |
I did not notice this on the Khumo's...they were rotated at 7500 miles and taken off at around 13K...the tire guy said they were in excellent shape.
I can have the dealer take a look at 15k service next week. Thanks for the info. |
#8 (permalink) | |
#9 (permalink) | |
Great, thanks. This was a very helpful link. I will request the dealer to inspect and document the rear axle alignment. I'll post what I learn. |
#10 (permalink) |
Drives 2012 Accent 2012 Elantra
Well, I gotta' tell ya' I drive my '12 SE about 1,000 mile a week. It destroyed the rear tires in 30,000 miles, they were cupping and noisy. Dealer said: "The alignment is off: the right is worn on the inside and the left on the outside. Get new tires and we'll 4-wheel align it."
There was still plenty of tread on' em so I drove to 44,000, till I couldn't stand the noise, it was roaring. Bought 4 new Kumho 4Xs at Firestone at end of December (I bought the car in April) and then asked Dealer for an alignment. Dealer THEN said: "The alignment is perfect, except the right rear camber is -2.6 degrees. But there is no adjustment for it, so we can't help you." Back and forth... back and forth... The manual says "...if the alignment is out of spec replace or repair the affected parts and re-inspect..." Dealer says he doesn't know which parts, called Hyundai, and they said "Oh. It's bad but it's not SO bad, and since he got over 30,000 miles from the tires, we ain't gonna' let you fix it." Dealer won't touch it now. I'm totally screwed. There is not a mention of 30,000 miles in the service manual, btw... no surprise there, only a mention of correct and incorrect specs. I could get 60K+ from the fronts judging by how they look, and should get more from the rears, easily. Look, I drive straight, and I drive easy. I've had tires over 100K miles and still have half the tread left, on much larger cars. Tire store now won't warranty the tires if I have a problem because the alignment is bad. So I'll be buying tires every 30K??? Dealer's alignment printout noted: "This is out of spec and may cause tire wear, and handling and safety problems" Called Hyundai consumer line, ol' Jerry there then spoke to dealer and then repeated the same thing to me.. (I heard it already, you know? Got anything new to add to the discussion???). Basically: Hyundai is simply refusing to warranty the car, and I suppose if I crashed they would say: "Well, many Hyundai owners crash in less then that many miles, so even tho' it was unsafe, it's not THAT bad..." And the dealer is the actual bloke that years ago convinced Hyundai to warranty their cars for 100K. Wonderful, no? My anger is seething. This is SO WRONG.
I purchased a new 2012 Accent... ![]() The Biggest Mistake I ever made. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
