Are Toyota 14" steel wheels compatable with the 2013 Accent GLS? - Page 2 - Hyundai Forums : Hyundai Forum
Old 11-19-2012, 11:20 PM   #11 (permalink)
Drives Hyundai Accent
SteveU is an unknown quantity at this point
Originally Posted by oneir View Post
I think that the hub or centerbore measurement for the 2012 Accent and a '93 Corolla are both 54.1mm.
That's according to this data:
Wheel Bolt Pattern Cross Reference Database and Conversion Guide: TOYOTA*COROLLA
Make
Model
Year
Bolt Pattern
OEM Wheel Size
Stud Size
Hub Center Bore
Offset
TOYOTA COROLLA 1988-02 Metric: 4 X 100
Standard: 4 X 3.94
14 X 5.5 12 X 1.5 54.1 H
And regarding the Accent:
2012 Accent stock 16" alloy weight info
Hi,
"I was preparing my car for winter this afternoon and I took the stock 16" alloy off and I have found the below info."
"Bolt pattern: 4x100
Center bore: 54.1mm
Offset: 52
Stock wheel with stock 195/50R16 tire weight 38lbs on my bathroom scale.
As per the tirerack.com, our stock tire weight about 18lbs, that makes the stock 16" alloy weight about 20lbs. The stock rim is HEAVY!"
"Thank you."
The steelies you have for your 1993 Corolla ought to be a match for bolt pattern, stud size, and centerbore. If they are 14" wheels, as you say it's difficult to imagine the width on them, plus the tires you would mount on them, giving any trouble with fender clearance. You didn't mention the offset figure for your wheels but there again it's hard to imagine 14" wheels suitable for a front wheel drive Toyota being so different that they don't clear the brakes, etc. The offset for the stock 14" steel wheels of a 2012+ Accent is 45 I believe, or 46 (according the Konig wheels tire fitment guide) on a width of 5.5".
What Fits
I'm not an expert but I'd guess if your wheels are anywhere even close to that offset figure, like 42, they should fit well.
I just went out & looked at the wheels, the only markings I could find were 54, 05, R, 8. They have 175-65R-14 Blizzaks mounted on them. I have to work tomorrow but plan on putting it up on Wed, trying at least the front ones & raising it up high enough I can check clearances from both the side & from underneath. Will post what I find out
SteveU is offline   Reply With Quote
Old 11-21-2012, 04:42 PM   #12 (permalink)
I had time to put it up this morning & found the 14" steel wheels I bought from tire rack do indeed fit. Both the hub size and lug spacing is correct and they actually have more clearance to the front brake calipers than the stock 16" wheels that came on the car. I did use the open ended lug nuts I bought at the same time as the wheels because I was concerned the steel wheels being thinner I would pop a hole in the end caps of the lugs that came with the car. Popped them on & put the lugs on by hand until snug, spun the wheels both directions then snugged them down & raised it up finding it has plenty of clearance from everything.
