LinkBack | Thread Tools |
#61 (permalink) |
2006 Sonota 3.3L Auto
2012 Accent GLS 1.6L Manual
Sorry for the long wait but here it is, my fog light indicator DIY
Tools needed 1 - standard screw driver 1 - long #2 screw driver 1 - wire cutter/stripper wire special wire connector (see pic below) electrical tape 1-Start by lowering the steering wheel as low as it goes. 2-Push up on the top of the instrument cluster cover and insert a standard screw driver between the cover and the dash below the "trip" button. ![]() 3-Gently pry with the screw driver and pull on the cover straight toward yourself. 4-Once the cover is loose use the standard screw driver to pop the plug off of the "trip" button. ![]() 5-Now that the button is disconnected gently pull the cover upward till the top steering wheel cover pops loose as they are attached to each other. 5-Remove the four philips screws holding the instrument cluster in place. ![]() ![]() 6-Carefully twist the instrument cluster up and around so that you can get at the plugs on the back right. ![]() 7-Using a female wire connector pictured below, insert the connector and attached wire into the third hole from the left on the bottom (the black wire in pic) ![]() ![]() 8-Connect the other end of the wire to your fog light switch using the splice of your choice so that it is hot when the fog lights are turned on. 9-Test it, and put everything back and your done. Some proof Fogs on ![]() Fogs & headlights on ![]() High beams on, fog switch still on ![]() There you have it! Enjoy!
"The Mouse" 2012 Accent Century White GLS, Manual Trans Mods OEM fog lights, Oil Catch Can, DIY Soundproofing, Rial Campo Rims, LED Conversion, Horn-ectamy, SE Shift Knob, Heated Mirrors, Heated Seats, Auto "off" Parking/Tail Lights, OEM LED Side Mirrors, OEM Bluetooth & Steering Wheel Controls, Mobis Window Visors, GDi Badge, Stubby Antenna,
CIPA Auto Dimming Mirror with Temp and Compass, Eagle Eyes LED Tail Lights, AEM Cruise Control Last edited by northey87; 11-17-2012 at 03:49 PM. |
| Sponsored Links | |||
Advertisement | |||
#62 (permalink) |
2012 Hyundai Accent GLS
2013 Mercedes S550 (Family)
2003 Escalade (Family)
Your the best. I'm going to do this right now!!!
Mods: Infinity 63.9i, 62.9i speakers, Kappa Four 1200W Amp 8000k HIDs headlights, HIDs fog lights, interior LEDs 7000k switchbacks | Viper 3203 w/ Remote Trunk SG UP 20% all around 75% Front Windshield 17x7 Enkei FLC-01 | Falken FK-452 205/40/17 Matte Black Shark Fin Antenna OEM Lip Spoiler | Eagle Eyes LED Taillights Injen SP1340 CAI AudioControl LC6i LOC | UNAVI w/ Back Up Camera |
#63 (permalink) |
2011 Sonata GLS
Pearl white
Too bad i cant do this mod on my Sonata since it doesnt have the fog indicator in the instrument cluster wiring diagram. Unlike yours, it clearly says pin #14. Great job though !
6000k Lows and Fogs, Retrofit Blazer Projector fogs, Led Fog DRL strips, Led everything, clear door lens, inner taillight mod, Luxgen badges, HP Black 05 Tint, Leather seatcover, Mobis mudflaps, Rear diffuser, Rearview mirror backup camera, Rear bumper Led reflectors, led footwell lighting, under-mirror led puddle lights, Paddle shifters, UR Strut Bar, Injen SRI. |
#64 (permalink) |
Accent i25 2012
Hi, i have a problem, im from venezuela, and already buy and install my kit? But the multifunction switch dont have the cables that appear in this guide, i install and take the power from other point, but i want that my foglights can turn on and of by the switch i just have 9 cables in the wiring of the car i want to know if a need make a bridge or some modification to make that, and also stay without turn lights, but the hazzard buttom turn on both sides o my turn lights, i appreciate yor help, thanks a lot
#65 (permalink) |
Accent i25 2012
Hi, i have a problem, im from venezuela, and already buy and install my kit? But the multifunction switch dont have the two wires black/red wire that appear in this guide, i want o know frome where comings this wires inside of the multiswitch, from make it, i install and take the power from other point, but i want that my foglights can turn on and off by the switch, i just have 9 wires in the plug of the car i want to know if a need make a bridge or some modification to make that, and also stay without turn lights, but the hazzard buttom turn on both sides o my turn lights, i appreciate yor help, thanks a lot
#66 (permalink) |
Sounds like you have a standard OEM multifunction switch, the switch from the kit I installed was modified to work with the kit. You can make it work you will have to add the correct connecters to the the plug that attaches to the multifunction switch. I don't know which pins off the top of my head.
CIPA Auto Dimming Mirror with Temp and Compass, Eagle Eyes LED Tail Lights, AEM Cruise Control |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
