LinkBack | Thread Tools |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
2006 Sonota 3.3L Auto
2012 Accent GLS 1.6L Manual
Yes and no. Yes they will fit but the diameter will be 5% larger meaning that when your speedo shows 60mph your actually going 63mph. Most all tire place recamend that you stay within 3% of the stock diameter. A 215/55 16 is 1.5% larger, and a 215/50 16 is 1.5% smaller. I would stick with one of those or the stock size.
"The Mouse" 2012 Accent Century White GLS, Manual Trans Mods OEM fog lights, Oil Catch Can, DIY Soundproofing, Rial Campo Rims, LED Conversion, Horn-ectamy, SE Shift Knob, Heated Mirrors, Heated Seats, Auto "off" Parking/Tail Lights, OEM LED Side Mirrors, OEM Bluetooth & Steering Wheel Controls, Mobis Window Visors, GDi Badge, Stubby Antenna,
CIPA Auto Dimming Mirror with Temp and Compass, Eagle Eyes LED Tail Lights, AEM Cruise Control |
#4 (permalink) |
In a word, NO! Rims must have the correct bolt hole configuration. They must also fall within the correct "offset" parameters. See that itty-bitty hole in the center of the wheel? Any wheel you buy must have a center hole large enough to fit over the center hub of your rotors. Do your research. A little knowledge beforehand sure pays dividends in the end...to say nothing about less headaches.
There's a ton of info in this forum about what you are wanting to do. And the members will help you, as well. My best advice: Research, research, research.
Okie Rich http://m.youtube.com/#/watch?v=JH03c...%3DJH03cMlLuIY 2013 Shimmering White Limited ("Ingrid") Born: 4/12/2012 Last edited by OkieRich; 01-17-2013 at 11:23 AM. |
#5 (permalink) |
Thanks Rich.
I even called the dealer for more information on the rims so that if I'm buying them aftermarket I can get the right ones. All they knew was to get 5 bolt 16'' ones, and buy from the dealer to avoid mismatch issues. They couldn't tell me any other details about the offset. If anyone knows what the other parameters are for the 2013 Elantra rims, please share. Thanks |
#6 (permalink) |
Dealer is stupid. Stay away from buying his wheels. Rediculous markup. Go to Discount Tire, look on Tire Rack, or other websites...
Posted by a fellow forum member (apologies to the author): OEM wheel info: Steel 16x6.5 offset +46 (~23lbs) Aluminum 16x6.5 offset +46 Aluminum 17x6.5 offset +46 (~22lbs) Bolt pattern 5x114.3mm (5x4.5in) Center hub is 67.1mm Wheel calculators: http://www.miata.net/garage/tirecalc.html http://www.1010tires.com/tiresizecalculator.asp http://www.rimsntires.com/rt_specs.jsp http://www.willtheyfit.com/
Okie Rich http://m.youtube.com/#/watch?v=JH03c...%3DJH03cMlLuIY 2013 Shimmering White Limited ("Ingrid") Born: 4/12/2012 Last edited by OkieRich; 01-17-2013 at 12:03 PM. |
#10 (permalink) | |
2011 Elantra GL
Desert Bronze
And OP. try PMC tires, bought my winters on steelies mounted and balanced and shipped for $906.... A local place in Winnipeg will run me between 12-1400 pending where I would have bought from... But also try like tire rack and discount tires like others mentioned |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
