LinkBack | Thread Tools |
#1 (permalink) |
2012 Black Elantra Limited
Hi guys,
I parked my car at 9am and didn't start my car again till 11pm. It has been really cold as of late. When I turned the key, it took a few turns of the ignition to start my car and when it did start, my car started rattling and shaking vigorously. I was afraid something was wrong so I turned it off and turned it on again because I could smell fumes come into our car through the vents. It did the same so I tried to warm up the engine by stepping on the accelerator and then the check engine light came on (MIL Malfuction Indicator Light). After a few moment of pause, I turned the car on again and it started fine but the engine light remained on. I am a bit worried now...it's the holiday season and I wanted worry free ...Anyone know whats wrong? |
| Sponsored Links | |||
Advertisement | |||
#2 (permalink) |
The fumes are from the rich fuel mixture on startup when it's cold. That's fairly common. The remainder of your issues might be checked out at a local auto parts store. They can check out your code for you. Usually a free service.
Disconnecting the battery cable for 20-30 minutes can reset the computers. It may just be an isolated incident.
Okie Rich 2013 Shimmering White Limited ("Ingrid") Born: 4/12/2012 |
#3 (permalink) |
So I went into my local shop and the code reader outputted a p0304 error whuch is a cylinder 4 misfire...gotta schedule something at the dealer which should be covered under warranty. Can anyone confirm this?
#5 (permalink) |
Thank you. I was doing some searches on the forum with the code and I ran across this thread:
Wash car, hit 37,000km and check engine light The car hasn't been acting up at all, but I am taking it in on Wednesday morning for a check up. The service person said they just had a few recent elantras coming in with the same problem and he said I will need a software upgrade and maybe some other things after it is checked out. All covered under warranty of course .
#6 (permalink) |
Ah good news, indeed. Sure makes for a Merrier Christmas, yes? Now you can concentrate on the festivities of the season. Thanks for reporting in...
#7 (permalink) |
owns 2007 Elantra-- 2006 Santa Fe 3.5 GLS son has 2005 Elantra hatch
Occasionally the tiny tip of a platinum plug can fall off (and get fired out the exhaust side---not causing any damage); you may need a new plug if the missfire keeps happening ; but more likey just a one off fluke like OP stated.
#8 (permalink) | |
and actually, i just got back from Cuba on Saturday and went to work yesterday so my car sat outdoors for 8 days in the cold(-6C to -30C during that time)and on Sunday when i went to work, it started no problem. hope delaership can fix it |
#9 (permalink) |
Drive's 2013 Elantra Manual, Sparkling Ruby!
Sounds like it just flooded itself when started the first time, then probably that's why the smell inside because as stated earlier the ECM allows more fuel when cold so you'll get a fuel smell in really cold weather at first start up of the day especially! I've noticed here in Ontario, Canada it's maybe -5 at most in the morning and I smell fuel and once I've noticed a little rough idle almost stumbling once and my cars only at 7,000.kms So hopefully not going to be a huge issue have to see in time I guess!
2013 Elantra Sparkling Ruby, Stick, (aka 'Ruby')led driving lights, Chrome 17" Rims, Tinted 15%,Plast-Dipped front grills, plasti dipped rear bumper section, hid 6000k kit, custom stainless tip (changing muffler)? DVC 10" AB Sub w/JL 500.1 amp Chrome CAI w/K&N Cone Filter, blue LEDs as interior accents, SOON TO COME back up camera on its way, tinted tails, hoping to make all tail lights to work as brake lights as well? Add to my stereo system, then who knows! |
#10 (permalink) |
Spent two hours at the dealership this morning and the techs couldn't really figure it out. Apparently they called the hyundai tech line and they just swapped the 1st and 3rd spark plugs and the 2nd and 4th spark plugs. They said if the light comes on again, they said to bring it ASAP and they will replace the coils. If it is further an engine problem, they said they will give me a loaner car while they fix the problem. This will be all covered under warranty of course.
My car hasn't acted weird or any different so I'm just hoping this was a fluke and I won't have to go back because time is money. Just wanted to give you guys an update on the problem. Oh also they said I am up to date with the software so no update was needed. All fuel pressure and internal measures were perfectly normal with only 7% alcohol level. I think I will go out and buy some star tron fuel additives just for pre-cautionary measures. |
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
