53000 km and i hear my brake wear bar, normal? - Page 2 - Hyundai Forums : Hyundai Forum
Old 11-20-2012, 05:29 AM   #11 (permalink)
OkieRich's Avatar
+1 on the brake grease on the rear of the pads. Also, there is some lubricant on the back of the pads. Heavy spray car washes into this area could have washed away that lubricant and be the culprit. If everything else looks normal, this is the area I would focus on!
Okie Rich
2013 Shimmering White Limited ("Ingrid")
Born: 4/12/2012
OkieRich is offline   Reply With Quote
Old 11-20-2012, 02:33 PM   #12 (permalink)
Don67's Avatar
Originally Posted by TunedOut View Post
Also, I was told by a co-worker that they normally replace roters when they replace pads nowadays? this is only true if you wait and let the wear bar or bad brakes scratch up and rub on the rotor right (like Don67 mentioned)? If you get them replaced a little early you can save the rotors?
The rotors should last through 2 sets of pads, assuming minimal abuse and annual pad lubrication. I don't even machine them when swapping out the first set of pads, unless they've become warped or have suffered serious scoring. Why grind away metal and risk warpage if everything's working fine? You're gonna want to replace them next time anyway, when you see how rusty the edges have become.
Old 11-27-2012, 11:17 AM   #13 (permalink)
TunedOut's Avatar
2011 Elantra Limited w/Nav 2002 Elantra VE - Sold
TunedOut
I finally got around to checking on them last weekend. I took some pictures and the brakes look like they have a tonn of life left.
I do get a lot of car washes, so maybe it could have been the oil and grease behind the pads getting washed away. When I saw how much was left on the pads i decided not to take the calipers apart.
TunedOut is offline   Reply With Quote
