Winter tire downsizing? - Hyundai Forums : Hyundai Forum
Old 11-11-2012, 10:02 AM   #1 (permalink)
Londonguy
Default Winter tire downsizing?
I know there have been other threads on this somewhere but I have stock Contintental 205/55/16 and want to get a new set of winter tires. Question is can I downsize this safely to 195/65/15? Will the tire shop know the exact 15" rims I should get as well, paying attention to offset etc. Has anyone done this with their 16s down to 15's for winter? Thanks.
Londonguy is offline   Reply With Quote
Old 11-11-2012, 10:24 AM   #2 (permalink)
Aaron.H's Avatar
2011 Elantra GL Desert Bronze
Aaron.H
Send a message via MSN to Aaron.H
Doing so right now. I have the 16" steelies that came with the elantra but neede winters and trying to reduce bit of cost to downgrade to 15" tires for winter. The base model comes with 15x6 steelies. Also keep in mind center bore size when ordering steelies or aftermarket rims if not oem as may not be the elantras 67.1mm otherwise you'll likely need hub centric rings. Luckily for me the steelies were that size. I bought set of continental extreme winter contacts(195/65/r15) on 15x6(67.1 center bore)
Aaron.H is offline   Reply With Quote
Old 11-11-2012, 10:51 AM   #3 (permalink)
Londonguy
Thanks. Did you go with OEM rims?
Old 11-11-2012, 11:13 AM   #4 (permalink)
TurboLed's Avatar
Drives Elantra GT GL 2013
You save about 100$ or more going 15" instead of 16", way enough to save on the price of the rims. That's a smart move I think.
TurboLed is offline   Reply With Quote
Old 11-11-2012, 03:00 PM   #5 (permalink)
drives Elantra GLS
HamRadio is an unknown quantity at this point
I just placed my order with the dealer. He recommended that I downsize with the 195/65/15 winter tires. The Elantra GLS came with the Continental tire as described by you. I bought Yokohama winter tires. Dealer matched the cost from a Tire shop in town.
Installation will be on the 21st. I bought his steel rims although they were more expensive. In the long run it evens irself out. At least I am sure of the quality with the Hyundai rim.
HamRadio is offline   Reply With Quote
Old 11-11-2012, 11:06 PM   #6 (permalink)
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
I have the 17" Limited wheels and tires and for the snow tires I downsized to the 16" size from the GLS for...you guessed it...cost.
- Andrew
Titanium Gray / Gray Leather
KDM headlights w/NightBreaker high beam bulbs, 30% tint all around, front plate delete with BumperPlugs, 37W fog lamp bulbs, Honda Fit wipers
KYB rear shocks, 5K white license plate and trunk LEDs
, V3 Triton rear turn signal LEDs, custom leather steering wheel wrap w/contrasted stitching, KDM aluminum pedal set.
lovemysantafe is offline   Reply With Quote
Old 11-12-2012, 07:56 AM   #7 (permalink)
Xion's Avatar
Drives 2011 Elantra GLS M6
15'' is better in winter, more rubber = smooth ride over pothholes. I negotiated mine with stellies when I bought the car. I got them for free.
Venetian Red 2011 Hyundai Elantra GLS M6
Xion is online now   Reply With Quote
Old 11-12-2012, 09:24 AM   #8 (permalink)
Krzysiek2011's Avatar
2011 Elantra GLS
Krzysiek2011
Same here, I have 15" for winter and 16" for summer.
Krzysiek2011 is offline   Reply With Quote
Old 11-12-2012, 05:49 PM   #9 (permalink)
Don67's Avatar
I downsized to 195/65R15... piece of cake. It's the standard size for base model Elantras here in Canada.
Skinny and high profile is definitely the way to go in winter.
Old 11-12-2012, 06:46 PM   #10 (permalink)
Aaron.H's Avatar
Aaron.H
no still aftermarket multi miles or something they are called but the center bore was still 67.1. i could have got the Hyundai steelies but that was $5 more each
