Tire pressure in the fall/winter - Hyundai Forums : Hyundai Forum
Old 11-04-2012, 11:01 PM   #1 (permalink)
2012 Black Elantra Limited
blackelantra is an unknown quantity at this point
Default Tire pressure in the fall/winter
Hey guys,
It officially hit cold weather here in MD and my TMPS came on tonight as the temperature hit in the 30s tonight. I believe they were all underinflated due to the temperature drop. It was at 26 psi so I went to the station and got em inflated to 33 psi. I drove it around for a few minutes and the light went away. What are your recommended psi values during the colder temperatures? Appreciate your help.
-P
blackelantra is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 11:06 PM   #2 (permalink)
MODERATOR
OkieRich's Avatar
Same as summer: 32-34 psi. I would recommend you buy a good tire gauge and check your pressures, weekly! Don't wait for the TMPS sensors to do what you should have been doing. YOU, the owner, are the first line defense against low tire pressures. TMPS's are your back-up!
Okie Rich
Ride Of The Month
Forum Rules
OkieRich is offline   Reply With Quote Quick reply to this message
Old 11-04-2012, 11:18 PM   #3 (permalink)
Agreed! I think I'll make sure to add that on my Saturday morning check list. I have a digital pressure reader and I believe its accurate. Thank you!
Old 11-04-2012, 11:25 PM   #4 (permalink)
someguy's Avatar
As long as you use the same gauge regularly your readings will always be consistent. I have one that goes inline and reads as tires fill with air. Very handy tool.
someguy is online now   Reply With Quote Quick reply to this message
Old 11-05-2012, 07:07 PM   #5 (permalink)
Don67's Avatar
TPMS was the bane of my existence on my last Nissan... always sounding the alarm on cold mornings. Thankfully Canadian Hyundais do not include this bit of nanny technology.
As others have said the only solution is to constantly readjust your tire pressure when the weather changes. But I would err on the soft side in cold weather, because as soon as you drive a few miles the pressure will rise, and the last thing you want on an Elantra is rock-hard tires. High tire pressure on the Elantra causes a harsh and jiggly ride, as well as scary behaviour when cornering on bumpy surfaces.
Old 11-05-2012, 07:14 PM   #6 (permalink)
35-36 should give you a little room to goof.. PDI papers say add 2 for car sitting on lot
Old 11-05-2012, 07:22 PM   #7 (permalink)
Don67's Avatar
Mine was delivered with 38 psi and it was unbearable. Felt like the Flintstonemobile, pureeing my kidneys and hopping sideways around corners.
Old 11-05-2012, 07:46 PM   #8 (permalink)
Drives 2013 Elantra Limited
dwausa is an unknown quantity at this point
Mine were at 40psi when I received the car. The local grocery store gas station has a free tire inflation station with a digital readout of tire pressure. you enter what you want the tires psi at and it adds/subtracts as needed.
dwausa is offline   Reply With Quote Quick reply to this message
Old 11-05-2012, 08:40 PM   #9 (permalink)
FloridaGator's Avatar
Drives First: 2013 Elantra GLS Titanium Grey Metallic Drives Second: 1994 Ford Escort LX Wagon
FloridaGator is an unknown quantity at this point
I have a good quality tire gauge and a little manual foot pump which cost about $6 - $7. I generally check the tires weekly. It takes all of a minute or two to check and another minute or two if I need to add air. I keep the tires at 34-35 psi. The little foot pump has a built-in gauge but I have found that those are not very accurate.
Believe it or not: My tires were at 45 when I picked it up. I knew something was wrong on the way home as the car felt as if it had solid rubber tires. When I got home I checked the pressure with three different gauges to make sure my gauges were right.
So much for the dealer's new car delivery check list.
FloridaGator is offline   Reply With Quote Quick reply to this message
Old 11-05-2012, 08:42 PM   #10 (permalink)
MODERATOR
OkieRich's Avatar
Now that's what I call a really nice feature. Not sure you can remove "idiot" from that "idiot proof" feature but it sounds like a step in the right direction.
Okie Rich
Ride Of The Month
Forum Rules
