How to change Elantra Transmission Fluid - Hyundai Forums : Hyundai Forum
Old 06-08-2012, 11:19 AM   #1 (permalink)
doug_id's Avatar
Drives Elantra GLS 2012
doug_id is an unknown quantity at this point
Default How to change Elantra Transmission Fluid
Here are the official instructions printed out for me by my dealers service dept. You should probably never need to do this. I screwed up and mistakenly drained the fluid in my trans by mistake. The guide says if you have severe use of your vehicle then you should replace ATF every 60k miles.
elntra tranny info by Doug in Idaho, on Flickr
You will need aprox 5 liters of transmission fluid. Use only the type specified in the back of your owners manual. This cost me $20 a liter from my dealer. You will also need a long narrow funnel. The instructions also recommend replacing the gaskets on all 3 plugs when doing this procedure.
Step 1: Remove the transmission drain plug from bottom of transmission case. This will drain aprox 5 liters of fluid. Allow time for all fluid to drain.
Step 2: Re-install drain plug and tourqe to 34.3 - 44.1 NM (3.5 - 4.5 kgf.m, 25.3 - 32.6 lb-ft)
Step 3: Unscrew filler eyebolt (see below...front slightly to the right of the engine). I found that the my socket wrench extension fit perfectly into the square opening in the middle of the eyebolt.
Step 4: Insert your funnel into the opening and start adding fluid very slowly. I found that it liked to back up and overflow if I went to fast. It took about 30 mins for me to get all the fluid in without it backing up and out of the opening. The instructions call for adding 5 liters but the service counter guy recommended going with only 4.5 liters at least until you can check the level.
Now time to check the fluid level. The instructions say this is easier with vehicle on a lift.
Step 1. Start the engine (don't step on brake and accelerator at same time.)
Step 2. Confirm the temperature of the A/T oil temp sensor is 50-60 C (122-140F) with the GDS.
Step 3. Shift the select lever slowly from P to D then D to P and repeat once more at idle. Leave in each position for at least 2 seconds.
Step 4. Lift the vehicle then remove the oil level check plug from the front side of the transmission case (see first diagram above)
Step 5. (note vehicle must be at a level state) If the oil flows out of the overflow (level check) plug in a thin steady stream then the oil level is correct. If excess oil flows out in a thick stream you have an excess fluid level condition. If no oil flows out you have a shortage situation and need to add additional fluid.
Step 6. Once the level is correct tighten the overflow/level check plug and then re-install the eyebolt on the filler opening. Torque to (4.9 - 5.9 NM (0.5 - 0.6 kgfm, 3.6 - 4.3 lb-ft)
Step 7. Clean up any fluid on painted surfaces in the engine bay as fluid is corrosive to paint.
Step 8. Beer!
2012 Elantra GLS
Fuelly Link:
doug_id is offline   Reply With Quote Quick reply to this message
Old 06-08-2012, 11:32 AM   #2 (permalink)
MODERATOR
OkieRich's Avatar
Nice write-up. For now, I'll skip steps 1-7 and proceed straight to #8.
Okie Rich
Forum Rules
Ride Of The Month & ROTM Rules
OkieRich is online now   Reply With Quote Quick reply to this message
Old 06-08-2012, 11:34 AM   #3 (permalink)
doug_id's Avatar
You Sir are a wise man!
2012 Elantra GLS
Fuelly Link:
Old 06-08-2012, 12:03 PM   #4 (permalink)
newtmaker's Avatar
newtmaker is an unknown quantity at this point
Anyone know where the drain and fill plugs are for the manual tranny?
Walt
newtmaker is offline   Reply With Quote Quick reply to this message
Old 06-08-2012, 12:23 PM   #5 (permalink)
someguy's Avatar
Thanks, how the heck did that happen
Old 06-08-2012, 12:41 PM   #6 (permalink)
doug_id's Avatar
I am struck by occasional bouts of stupidity
2012 Elantra GLS
Fuelly Link:
Old 06-08-2012, 01:29 PM   #7 (permalink)
Don67's Avatar
Nice work, doug_id. This is the sort of content that makes hyundai-forums.com such a great resource.
Score one for the do-it-yourselfers
Old 06-08-2012, 02:51 PM   #8 (permalink)
Xion's Avatar
it would be nice to drain the torque converter as it's still loaded with old oil. can you just drain it by starting the engine and idle a short period of time in neutral? this afternoon I'm taking my GF's 2004 Accent to the dealer for a tranny oil change, they told me they would drain also the torque converter and when the car leaves the dealer only new oil is in the tranny. They also remove the pan and change the filter for a total of $158
Xion is offline   Reply With Quote Quick reply to this message
Old 06-08-2012, 09:51 PM   #9 (permalink)
someguy's Avatar
Ha it happens to us all. This is a lot more difficult than my Focus that had trans dipstick. After the last pan drop and filter replacement I decided Im done servicing my own transmission.
Old 09-27-2012, 10:00 PM   #10 (permalink)
Drives 2012 hyundai elantra
efone202 is an unknown quantity at this point
Exclamation
"Step 2. Confirm the temperature of the A/T oil temp sensor is 50-60 C (122-140F) with the GDS."
My bf did the same thing and removed the drain plug for the tranny instead of the engine oil. i was wondering since i dont have a lift, is it still possible to check the level?
how do you test the temp? is this an important thing when filling tranny? what is GDS?
Thank You
efone202 is offline   Reply With Quote Quick reply to this message
