Component Speaker Install - Hyundai Forums : Hyundai Forum
Old 07-16-2011, 08:29 PM   #1 (permalink)
silvergls's Avatar
silvergls is an unknown quantity at this point
Infinity Reference 6030cs
Woofer's comparison
Stock Woofer removal:
Only hand tools were used
Diagonal wire cutter, used to cut and seperate the speaker's brackets
Scissors, to trim the rubber surrounds from the speaker cone (left the rubber surrounds to help cushion the Infinity woofer)
Infinity Woofer installed to stock speaker spacers
Only 4 drilled holes were needed for mounting. Speaker adapters were not used.
Stock vs Infinity tweeters installed
Infinity tweeter and Crossover installed
Input wiring using the factory tweeter connector removed from the tweeter as input to the crossover. Only the tweeters door wiring is used as input, the woofers are disconnected. The factory system does not have a dedicated signal to the woofer and tweeter. Infinity woofers wiring is tied to the center connectors on the crossover.
Space and location for the crossover was perfect.
Woofer installed
2011 HYUNDAI ELANTRA GLS
Radiant Silver
Infinity Speakers, Compact Subwoofer, KYB Shocks, LEDs, CrystalVision Ultra, Tints, Bodyside Molding, Superdrift Spoiler, Rear Diffuser, Reverse Park Assist Sensors, Intake Mod, Interior Vinyls, Leather Wrapped Steering Wheel
1998 DODGE Neon R/T
silvergls is offline   Reply With Quote
Old 07-16-2011, 10:17 PM   #2 (permalink)
lorenambrose
How is the overall sound now? Are the new speakers amped? How is the bass response of the new speakers?
lorenambrose is offline   Reply With Quote
Old 07-16-2011, 10:32 PM   #3 (permalink)
silvergls's Avatar
QUOTE (lambrose @ Jul 16 2011, 04:17 PM)
Sound is really great! The clarity is unmatched and are noticably more efficient drivers. Volume setting at what was once 17+ can be achieved at 12.
No amp work done with exception of the Compact Powered Sub I recently installed. The Sub gave me the bottom end, now the highs, mid and mid bass comes jumping out at you. Doesn't sound at all like a stock audio system.
Radiant Silver
1998 DODGE Neon R/T
Old 07-17-2011, 09:37 AM   #4 (permalink)
fzer00
Nice. Your install looks great. I was looking at replacing my front speakers as well. How easy or hard was it to remove the door panels? Can you provide any tips or tricks?
fzer00 is offline   Reply With Quote
Old 07-17-2011, 03:54 PM   #5 (permalink)
lorenambrose
can I ask where you purchased them from?
Old 07-17-2011, 04:52 PM   #6 (permalink)
Louiceman's Avatar
2011 Elantra limited Matte Blk
Louiceman is an unknown quantity at this point
I bet sound better than look
Louiceman is offline   Reply With Quote
Old 07-17-2011, 07:59 PM   #7 (permalink)
silvergls's Avatar
QUOTE (fzer00 @ Jul 17 2011, 03:37 AM)
Thanks! replacing the front speakers are well worth it.
[b]Front door panel removal:
First roll down the windows
Remove side mirror panel. Pry off, it's held on by snap clips
Remove 2 phillips screws by first popping the covers loose.
Remove the door panel by prying and grabbing at the gap bellow the foward portion of the panel. Start from there and work your way around the entire panel. Panel is held in with push pins.
Carefully raise the panel from the window seal starting from the rear. Hold the panel slightly away from the door and remove the electrical wiring harnesses and door latch clips attached to the panel.
Door latch assembly
[b]Panel removal done.
Take note that reassembly is just as easy if not easier. If you have trouble, don't force it as everything goes together rather quickly.
Test door handle and locks once the panel is in place.
Radiant Silver
1998 DODGE Neon R/T
Old 07-18-2011, 09:39 AM   #8 (permalink)
fzer00
Many, many thanks to you. I'm sure this will be a big help to me and to others too. I'll be installing a subwoofer in this upcoming weekend and probably replacing the front speakers the weekend after. Your help should make everything so much easier now. Thanks again.
Old 07-19-2011, 03:12 AM   #9 (permalink)
silvergls's Avatar
QUOTE (lambrose @ Jul 17 2011, 09:54 AM)
ebay
buy12volt_com
QUOTE (fzer00 @ Jul 18 2011, 03:39 AM)
No problem, glad I could help.
Coming very soon will be my rear door Infinity upgrade. It'll be somewhat similar install but with a slight mod.
Radiant Silver
1998 DODGE Neon R/T
Old 07-23-2011, 06:01 PM   #10 (permalink)
silvergls's Avatar
[b]Rear Door Speaker upgrade
Infinity 6032cf
[b]Speaker comparisons
[b]Speaker Terminals compared
[b]Factory Speaker removal
Cut all speaker brackets fully except one saving the terminals using a diagonal wire cutter
Rubber surrounds removed at where the paper and rubber meets with a scissors
[b]Factory wiring connector splice
Soldered speaker bracket terminals wired to the Infinitys
[b]Installed!
[b]Door Panel removal:
Roll down the windows
Remove door panel cap at the rear
Remove the door panel once again by prying and grabbing at the gap bellow the foward portion of the panel. Start from there and work your way around the entire panel. Panel is held in with push pins.
Carefully remove door panel by pulling upwards over the door seal. Then hold the panel slightly away from the door to remove the electrical wiring and door latch clip.
Radiant Silver
1998 DODGE Neon R/T
