Component Speaker Install - Page 29 - Hyundai Forums : Hyundai Forum
Old 11-06-2012, 01:04 AM   #281 (permalink)
silvergls's Avatar
silvergls is an unknown quantity at this point
Originally Posted by JiVe View Post
Hello everyone , thanks for all the help so far. I started installing the Infinity 6030 and was wondering about hooking up the crossover. Would i use the cord going to the tweeter as the power to the crossover and just cut , tape up , and wire nut the cord going to the woofer. I'm just doing the front speakers ,no amp or subs yet.
You could use either one. Only one is needed as the input for the crossover. I choose the tweeters because of the location.
2011 HYUNDAI ELANTRA GLS
Radiant Silver
Infinity Speakers, Compact Subwoofer, KYB Shocks, LEDs, CrystalVision Ultra, Tints, Bodyside Molding, Superdrift Spoiler, Rear Diffuser, Reverse Park Assist Sensors, Intake Mod, Interior Vinyls, Leather Wrapped Steering Wheel
1998 DODGE Neon R/T
silvergls is offline   Reply With Quote
Old 11-07-2012, 07:31 PM   #282 (permalink)
2013 Hyundai Elantra Limited w/ Tech Pkg
MavEnt is an unknown quantity at this point
One quick question:
1. Why go 6030cs in front and 6032cf in rear? Is it not possible to go 6030cs front & rear? I believe they would fit but I'm curious if it is just not practical, or maybe overkill?
I intend on powering them with an amp, as well as placing a sub (likely a 10-12' bazooka tube in the trunk).
Thanks everyone!
MavEnt is offline   Reply With Quote
Old 11-07-2012, 08:27 PM   #283 (permalink)
someguy's Avatar
Hey MavEnt you can certainly do comps in both front and rear but you will have to do some extra modding to mount the rear tweeters.
Forum Rules
Enter your car in Ride of the Month
someguy is offline   Reply With Quote
Old 11-08-2012, 12:51 AM   #284 (permalink)
new2013's Avatar
Drive's 2013 Elantra Manual, Sparkling Ruby!
new2013 is an unknown quantity at this point
Send a message via Skype™ to new2013
Looks great, bet it sounds even better! I just installed a dvc 10" 1200watt sun and now I need to add a 4 ch. amp. and a front component set and a 2 way set for back, is it difficult to cut out factory speaker so you can just put new ones in the housing wire up and and go. Any tips on crossover installation, does it have to stay close to speaker or can it go anywhere as long as the wires reach!
new2013 is offline   Reply With Quote
Old 11-08-2012, 02:16 AM   #285 (permalink)
silvergls's Avatar
Removing the speakers are easy. Just remember you are not saving the speakers from these tips. All I kept from the factory speakers were the magnets, for fun stuff.
As for the wiring, pay attention to the polarity and directions. The crossover is clearly marked. As for the location, anywhere on the door will work fine. Just fine a suitable and stable location. I always try to find a spot nearby for the sake of keeping the wiring short and clean.
Radiant Silver
1998 DODGE Neon R/T
Old 11-09-2012, 12:28 PM   #286 (permalink)
2013 Elantra GL
antemeridiem is an unknown quantity at this point
Thumbs up
Hello silvergls,
I have model GL, does same size speaker fits?
Now I haven't read each user reply, just in case if this is repeated question, I do apologize.
antemeridiem is offline   Reply With Quote
Old 11-10-2012, 02:00 AM   #287 (permalink)
silvergls's Avatar
Originally Posted by antemeridiem View Post
Hello silvergls,
As much as I know they all use the same sized speakers. Do you have the seperate tweeters on the front doors? Only thing I am not aware of for the GL models.
Radiant Silver
1998 DODGE Neon R/T
Old 11-21-2012, 02:59 AM   #288 (permalink)
Drives Elantra
inakto is an unknown quantity at this point
Hello, with the help of this guide and some others I did a complete overhaul, here are some final pictures:
Complete Amp, Speaker, and Wire Install Guide
inakto is offline   Reply With Quote
Old 12-07-2012, 03:34 AM   #289 (permalink)
Drives 2013 Elantra Limited
kaducii is an unknown quantity at this point
Hey everyone, I am a proud new owner of a white Elantra Limited. I'm happy with everything except the sound. I was hoping some of you could give me some pointers on the matter. I don't play my music that loud but I do want my music to be accurate and clear.
I've been browsing through the thread and I had a couple of questions:
1. I was looking at the Polk DB6501 but noticed most people ended up going with the Infinity 6030cs. Do most people choose the Infinity 6030cs because it sounds good and is relatively easy to power even with a stock headunit?
2. I just got this Sony XDP-PK1000 DSP/Amp/Sub package because it was on sale, but there's literally no reviews on the product.
a) In general are Sony amps and subs at least decent? This one is a 300W amp and a 12" closed sub. Or should I be looking elsewhere? Any good recommendations for a good sub and amp for around $250?
b) The DSP unit comes with an amp that's rated at 45WX4 peak and 17WX4 RMS. Someone said the Elantra headunit itself already outputs around 25WX4 RMS so am I actually downgrading? And would 17W be sufficient to drive either the Polk or the Infinity speakers?
Thanks for the help!
kaducii is offline   Reply With Quote
Old 12-08-2012, 02:34 AM   #290 (permalink)
MODERATOR
Em-squared's Avatar
Just saying kaducii.
Fashionista.
Em-squared is online now   Reply With Quote
