Programming Rear View Mirror (homelink: Garage Function) - Hyundai Forums : Hyundai Forum
Old 06-13-2011, 02:52 PM   #1 (permalink)
wnjamaica95
Here is a link to HomeLink that will provide a video instruction on how to program your system.
http://www.homelink.com
Unfortuately, it doesn't list the Elantra as an option...just select the Sonota Sedan...the instructions are the same.
A step not mentioned (becasue they don't mention the integrated rear view mirror option), is the rear view mirror needs to be turned off...the autodimmer feature sometimes interfers with the garage door signal (during programming). This only happens while programming your system...after that, you can turn your rear view mirror back on and all should work well.
If you are still having problems, contact them at 1-800-355-3515. They were extremely helpful and very patient with my non-tech self.
wnjamaica95 is offline   Reply With Quote Quick reply to this message
Old 06-14-2011, 01:46 PM   #2 (permalink)
tyjames
thanks for the tip
-ty
tyjames is offline   Reply With Quote Quick reply to this message
Old 08-05-2011, 11:09 PM   #3 (permalink)
New2Elantra
Thank you for posting Homelink's 800#. I couldn't get Homelink set up on my wife's new 2012 Elantra Ltd until the pleasant Homelink rep helped me out. Thanks again.
New2Elantra is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 02:20 AM   #4 (permalink)
acowabunga's Avatar
acowabunga
New2Elantra, what did the Homelink rep have you do? I just got the mirror installed but the LED will not blink at all when trying to reset the homelink buttons (#1 & #3 pushed simultaneously). In fact it will not blink at all when any of the buttons are pushed. Thanks in advance for your response.
2012 Elantra Ltd - Red Allure||Black
2010 Audi S5 - Meteor Grey||Tuscan Brown
acowabunga is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 02:42 AM   #5 (permalink)
lovemysantafe's Avatar
Drives: 2012 Elantra Limited
QUOTE (Rolyat @ Jun 13 2011, 11:52 AM)
I've programmed mine to all three buttons (both of ours and a friend's garage door) and both times the auto-dimming mirror was on. I had no interference trouble and don't see why it should have any effect at all.
QUOTE (ACowabunga @ Aug 23 2011, 11:20 PM)
When clearing the Homelink, you have to press and hold the two buttons for at least 20 seconds although I think it's probably more.
Slow Blink* - Not programmed
Rapid Blink - Rolling code programmed
No Blink - Non-rolling code programmed
* Less than once per second. If you just briefly press the button, it would appear as though it were going to stay on solid.
- Andrew
Titanium Gray / Gray Leather
Old 08-24-2011, 03:29 AM   #6 (permalink)
acowabunga's Avatar
acowabunga
I'm thinking that the mirror was not installed correctly by the technician. Only the green mirror LED is illuminated and it never blinks, regardless what button is pushed. The LED does extinguish when the power button is pushed and the compass does turn on and off with the press of the corresponding button. I think this will require a trip back to the installing dealer.
Old 08-24-2011, 08:08 PM   #7 (permalink)
sellmeacar
QUOTE (ACowabunga @ Aug 24 2011, 12:29 AM)
What technician? I thought the homelink mirror was a manufacturer's option and not a dealer option.
sellmeacar is offline   Reply With Quote Quick reply to this message
Old 08-24-2011, 09:29 PM   #8 (permalink)
acowabunga's Avatar
acowabunga
QUOTE (sellmeacar @ Aug 24 2011, 05:08 PM)
My 2012 did not come with it so I hadn't local dealership install one. I guess the tech installing it forgot to do/connect something. I'm just happy that the self dimming function works.
Old 12-24-2011, 05:24 PM   #9 (permalink)
2012 Elantra
spacely is an unknown quantity at this point
Default Manual?
Does anyone have a link to the user manual for the Auto-Dimming Homelink mirror with compass? The dealer didn't give me one, and my compass is showing numbers. Want to fix that soon...
Thanks in advance
Dave
spacely is offline   Reply With Quote Quick reply to this message
