Correct Tire Pressure - Hyundai Forums : Hyundai Forum
Old 04-27-2011, 02:46 PM   #1 (permalink)
matt71's Avatar
2011 Hyundai Elantra
matt71
Can anyone explain why the user's manual and the tag on the driver's side of the car say to inflate the tires to 32 psi but the tires can go up to I think around 44 psi? Wouldn't higher inflation mean better gas mileage?
matt71 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 02:48 PM   #2 (permalink)
ranjo
Yes, this is what I thought but then your tires will wear in the middle faster due to the higher pressure. The 32 PSI is the manufacturer's recommended for the best "ride". I would sure like to know how much higher you can go before you start
wearing the tires out prematurely.
ranjo is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 02:57 PM   #3 (permalink)
MODERATOR
Xion's Avatar
The pressure on the tire is the maximum the tire can hold but every car has been tuned for a certain tire pressure, always inflate your tires according to the pressure on the driver's side tag for best fuel economy and best handling. Too much pressure will result in a harsh ride and faster wear of the tires.
Xion is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 04:00 PM   #4 (permalink)
imkramer
I've always "cheated" a little and kept mine at about 34-35 psi. I find that gives me a good balance of ride, fuel ecomony, and tire wear.
imkramer is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 04:37 PM   #5 (permalink)
someguy's Avatar
32-33 feels good to me but 34+ seems to lose stability at highway speeds.
Old 04-27-2011, 05:29 PM   #6 (permalink)
chrisvm31's Avatar
Drives 2011 Elantra GLS (Canadian version)
chrisvm31 is an unknown quantity at this point
Send a message via MSN to chrisvm31 Send a message via Yahoo to chrisvm31
QUOTE (someguy @ Apr 27 2011, 04:37 PM)
+1. 33 is perfect for me.
chrisvm31 is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 10:54 AM   #7 (permalink)
Hers: 2011 Elantra Limited Indigo Blue Mine: 2009 Dodge Challenger R/T Classic B5 Blue Shared: 2
BobMAz
QUOTE (Xion Nider @ Apr 27 2011, 11:57 AM)
Additionally, running tires at their maximum pressure can cause them to burst when hitting potholes, pipes, or other objects in the road. It does not allow the tire to flex and absorb the impact of the object.
Bob
BobMAz is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 08:12 PM   #8 (permalink)
matt71's Avatar
matt71
Thanks for the feedback. I checked my tires which the dealer inflated when I picked up the car almost two weeks ago and they are around 35 psi. I'm going to keep them there for now and let them naturally deflate to 32 psi.
Old 04-28-2011, 08:40 PM   #9 (permalink)
MODERATOR
OkieRich's Avatar
I checked mine after leaving the dealer's lot. The "PDI" report showed "32 psi." Actually, they were 37 psi...thought maybe my gauge was incorrect, so I checked it with an electronic one in the garage which I had calibrated at work some time back. Yep...37 psi. I have since dropped them to 34 and still thinking I might let them drop to 32 on their own.
While we're on the subject of tires, not enough can be said for the importance of rotating those tires for maximum wear. It's gonna be a financial investment when I have to pony up to replace those 17" Continental ContactPro's that came on the car. Cha-ching!!!!!!!!!
Okie Rich
Ride Of The Month
Forum Rules
OkieRich is offline   Reply With Quote Quick reply to this message
Old 04-29-2011, 11:18 AM   #10 (permalink)
imkramer
QUOTE (matt71 @ Apr 28 2011, 08:12 PM)
That's what I've always done...I inflate them to 35, then as they deflate to about 32-33, I bring them back up again. So on average mine are at about 34. I check them periodically along the way to ensure they are deflating evenly.
One simple note of advice to anyone may not already know: Regardless of whether you choose to keep your tires at 32psi or higher, for a true reading, always check the tire pressure when the tires are cold (because the pressure will always be higher when the tires heat up after only a few miles)
