Changing Rim Size - Hyundai Forums : Hyundai Forum
Old 04-22-2011, 10:46 AM   #1 (permalink)
aemt307
Do you need to reprogram the car's computer if you change the tire rim size? I am thinking of putting on smaller rims with winter tires on them next winter and I am wondering if the computer needs to be reprogrammed for the smaller size rims. I'm considering this because the smaller tires and rims are cheaper.
Thanks.
aemt307 is offline   Reply With Quote Quick reply to this message
Old 04-22-2011, 11:01 AM   #2 (permalink)
someguy's Avatar
Will the diameter of the tire still be the same? You can use a tire size calculator like this one to find out
Old 04-22-2011, 03:53 PM   #3 (permalink)
aemt307
Post
Actually, using the calculator, the actual tire size/diameter is about the same. So I really don't think I will need to change anything.
Old 04-22-2011, 04:27 PM   #4 (permalink)
someguy's Avatar
No problem I wouldn't even bother changing the computer unless you were 2 or more sizes over stock.
Old 04-22-2011, 07:46 PM   #5 (permalink)
joemidnight's Avatar
joemidnight is an unknown quantity at this point
QUOTE (someguy @ Apr 22 2011, 04:27 PM)
what would even be the largest sized rim you could go with on the Elantra without causing any rubbing issues within the car?
17" with 45 series rubber seems like its already stretching the limits ... I don't 18's with 35 series rubber being a comfortable everyday style of tire ( although I WOULD LOVE to have a set of my own )
joemidnight is offline   Reply With Quote Quick reply to this message
