Installing Amp In 2011 Elantra Gls With Navigation - Hyundai Forums : Hyundai Forum
Old 04-13-2011, 03:06 PM   #1 (permalink)
votedthe1
i need to know how to get to the rca cables of the factory radio do i need to remove the radio if so how or is there another way to tap into the signal
votedthe1 is offline   Reply With Quote Quick reply to this message
Old 04-13-2011, 03:31 PM   #2 (permalink)
tyjames
Good Question, I was going to leave that to the pros
-ty
tyjames is offline   Reply With Quote Quick reply to this message
Old 04-13-2011, 06:26 PM   #3 (permalink)
crcendo's Avatar
Drives 2011 Elantra Limited w/Nav and 2003 Acura CL Type S w/Nav
crcendo is an unknown quantity at this point
QUOTE (votedthe1 @ Apr 13 2011, 03:06 PM)
For the GLS, you will need to remove the head unit for signal to your line out converter or speaker level inputs into your amp.
crcendo is offline   Reply With Quote Quick reply to this message
Old 04-13-2011, 08:45 PM   #4 (permalink)
quantech's Avatar
quantech
I am not positive, but if you call Crutchfield and tell them that you have a 2011 Elantra and tell them you are interested in upgrading/modifying the factory stereo, they'd probably tell you on the phone what needs to be done (not detailed, step by step directions, but a rough idea) assuming that they have wiring schematics or a diagram of the Elantra with and without the factory navigation system. I plan on putting an under the seat sub in mine in a few months but I'm going to leave that up to a local guy who's been doing custom car audio for years and years. I am sure he has the resources or smarts to figure it all out without any problems and for $75 in labor I'd rather have him do it then sweat and curse for hours trying to do it myself.
I think that someone said in a recent thread on this forum that the Elantra's external amp is located in the trunk on the passenger side underneath the rear deck but I haven't looked myself. If it is there you could probably tap into the signal there or just remove it all together and replace it with another amp. I do know that all the speakers in the car are 2 Ohm though so you have to make sure you match resistance loads unless you plan on also replacing the factory speakers too.
quantech is offline   Reply With Quote Quick reply to this message
Old 04-14-2011, 12:07 AM   #5 (permalink)
jng34c's Avatar
jng34c
QUOTE (Quantech @ Apr 13 2011, 07:45 PM)
I don't know anything really about amps, but I did find where it was located. If you look on the right panel of the interior of the trunk, you'll see a tear away panel with a clip that you can open up and if you look inside, you'll see the panel back there.
"No other success can compensate for failure in the home." - David O. McKay
jng34c is offline   Reply With Quote Quick reply to this message
Old 04-14-2011, 04:40 PM   #6 (permalink)
votedthe1
well i found the amp and which clips were radio and which were nav and rear camera now just need wire diagram for the clips for speakers
Old 04-14-2011, 05:19 PM   #7 (permalink)
crcendo's Avatar
QUOTE (votedthe1 @ Apr 14 2011, 04:40 PM)
Are you saying there is a separate amp in the GLS? Where is it located? I was under the impression there is no amp in the GLS and is powered from the head unit.
Old 04-15-2011, 12:42 AM   #8 (permalink)
votedthe1
i went to the hyundai dealer and they said if it has navigation regardless of trim it has an amp and if no navigation then it is powered from head unit it is in same place as for the limited the right side of trunk behind carpeted side
Old 04-15-2011, 06:31 AM   #9 (permalink)
crcendo's Avatar
QUOTE (votedthe1 @ Apr 15 2011, 12:42 AM)
That's true because it is the same 360w sound system. You never said you had nav. Run power wire from battery, and here are the pinouts for the amp.
