Headlight Removal - Hyundai Forums : Hyundai Forum
Old 03-20-2011, 09:45 AM   #1 (permalink)
nautica6z9
Has anyone removed the headlights to install brighter low beams? I removed the bolts like the manual said , however I cannot pull out the headlight. I am not sure how much pressure to apply and I am a little hesitant since it is a new car.
nautica6z9 is offline   Reply With Quote Quick reply to this message
Old 03-20-2011, 12:22 PM   #2 (permalink)
flashbang
[attachment=24191:headlight.pdf]
2011 Elantra Limited w/Navigation
Desert bronze w/beige interior
Proud member of the Elantra HPC.
flashbang is offline   Reply With Quote Quick reply to this message
Old 03-20-2011, 01:05 PM   #3 (permalink)
nautica6z9
Have you taken these out yourself? I see there are clips in pdf holding the light in place. I just don't want to damage these.
Old 03-20-2011, 02:22 PM   #4 (permalink)
flashbang
QUOTE (nautica6z9 @ Mar 20 2011, 01:05 PM)
No, I have not, but it seems pretty self explanatory that you have to pull it out of the clips. As the note claims "Take care that holding clip (A) is not to be damaged." is a indicator that it is a tight gripping clip that may break. If they do break the dealer will have to order you the part and I would get spares being that this is an asinine procedure to change a light bulb.
Old 03-20-2011, 07:03 PM   #5 (permalink)
VinceGLS
Why remove it to change the bulb ?
If you put HIDs okay you'll need to remove them but if you just change the bulbs, don't have to.
Just unscrew the dustcap and unplug it. Remove the metal stopper and pull out the bulb.
Each bulb is easy ti reach w/o remove the lights.
I did remove them to install some hid and make some modifications to the wiring. To remove them, unscrew the 3 screws, just pull UP a little, the two pins will 'pop' and you'll be able to take it out compeltely. Be carefull to not scratch the front corner. It's really tight there. Remove it slowly.
VinceGLS is offline   Reply With Quote Quick reply to this message
Old 12-13-2011, 11:40 PM   #6 (permalink)
Drives Elantra MD
turbobunny is an unknown quantity at this point
Sorry for the bump.... but does anyone have the Headlight removal pdf handy that they can upload or send me a link to.... for some reason I can't download/open the one in this thread.
Thanks!
turbobunny is offline   Reply With Quote Quick reply to this message
Old 12-14-2011, 12:09 AM   #7 (permalink)
someguy's Avatar
turbobunny I dont have a pdf handy but the instructions are in your owners manual maintenance section. Also welcome to the forum
Old 12-14-2011, 12:18 AM   #8 (permalink)
Drives 2011 Hyundai Elantra Limited
KrisLW35
Thanks!
I do not have the PDF saved either, but perhaps the beginning of this video can be of some help. It shows exactly how to remove the housing, as well as get access to and remove the bulb
KrisLW35 is offline   Reply With Quote Quick reply to this message
Old 12-14-2011, 12:37 AM   #9 (permalink)
Drives Elantra MD
Thanks for the warm welcome
I did look in the manual but it only talked about removing the three bolts..
I watched:
This gave me a sense of what needs to be done, but I was hoping to see a diagram of the clips or pieces under the headlights so I don't break them
Old 12-14-2011, 01:54 AM   #10 (permalink)
g_arneson's Avatar
Drives 2012 Hyundai Elantra GLS and 1989 Honda Accord LX-i
g_arneson is an unknown quantity at this point
This company sells the best replacement bulbs you can buy. Their website is pretty lame and maybe a little confusing, but it's a reputable company based the United States <B><FONT COLOR =RED> PLUS - EXTRA LIFE</FONT> H1 / H4 / H7 / H11
Also, here's a good article the company wrote about why you shouldn't do what that guy in the previous poster's video did (retrofitting HID bulbs)... HID Kits: What You Need To Know
g_arneson is offline   Reply With Quote Quick reply to this message
