iphone 5 not working with usb port - Hyundai Forums : Hyundai Forum
Old 06-25-2013, 12:44 PM   #1 (permalink)
sactown024's Avatar
2011 Sonata SE 2.0T
sactown024 is an unknown quantity at this point
Default iphone 5 not working with usb port
i have a 2011 sonata and the iphone 5 does not work with it. I tried using the direct plug from the iphone and the adapter, neither work. it connects and disconnects every half second or so and never fully stays on.
I tried with a old iphone and ipod and they both work fine.... anyone else have this issue?
2011 Hyundai Sonenesis 2.0T SE
19" Genesis wheels
5% window tint on all 5
sactown024 is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 01:17 PM   #2 (permalink)
RBD
2012 Sonata Limited 2.0T Loaded
RBD is an unknown quantity at this point
Mine works fine with the Hyundai cable and lightning to 30 pin adapter. Although I have to remove the phone from the case. I usually just stream via bluetooth. (2012 w/ Navi).
RBD is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 02:23 PM   #3 (permalink)
sactown024's Avatar
2011 Sonata SE 2.0T
yeah BT works fine, kills the battery so fast though. Mine does not work with the apple cable, i dont have the hyundai one.
19" Genesis wheels
Old 06-25-2013, 03:31 PM   #4 (permalink)
Dunder33's Avatar
2012 Sonata Turbo Limited
Dunder33 is an unknown quantity at this point
I think the ipod USB cable only works with the 2012 models and up, with no nav system. On the 2011, you'll need the Hyundai ipod cable, and with an iphone 5, you'll probably need the lightning to 30 pin connector too, as RBD mentioned.
Dunder33 is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 06:17 PM   #5 (permalink)
Sonata 2012 SE TURBO 2014 Santa Fe Sport
reus49 is an unknown quantity at this point
I have no problem with my I-5 either. I have the nav and use the Hyunai cable with he adapter.
reus49 is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 08:34 PM   #6 (permalink)
Supporting Vendor
charlesj123's Avatar
Drives Sonata 2010 Sport
charlesj123 is an unknown quantity at this point
Send a message via Skype™ to charlesj123
200% positive, 2011 requires the Hyundai Ipod adapter. No other ways around.
www.compass-nav.com ___ DRIVEN BY PASSION ___ Integrated Navigation systems___ Like us! www.facebook.com
charlesj123 is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 08:40 PM   #7 (permalink)
jsmit86's Avatar
Drives 2013 Azera w/Tech
jsmit86 is an unknown quantity at this point
Make that 300%
Key points:
> All cars with NAV require the Hyundai special cable.
> Any Apple product with lightning connecter will also require the 30 pin to lightning adapter as well.
> 2012 and Newer cars WITHOUT NAV should be able to use the standard Apple lightning to USB cable.
This is probably one of the most misunderstood features of Hyundai cars. Admittedly this is a bit confusing since it depends on NAV/No NAV and the year of the car.
2013 Azera
Smoke Gray
Black Graphite Interior
Tech Package
jsmit86 is offline   Reply With Quote Quick reply to this message
Old 06-25-2013, 09:13 PM   #8 (permalink)
destro is an unknown quantity at this point
There's the problem. I *think* some have had some luck with certain aftermarket ones, but the Hyundai one wins out.
destro is offline   Reply With Quote Quick reply to this message
Old 05-19-2014, 05:38 PM   #9 (permalink)
2012 Sonata
wmstormvet is an unknown quantity at this point
You are lucky... I got the Hyundai adapter from the dealership, had to go buy the lightening adapter and upon plugging it in, all I got was feedback.
wmstormvet is offline   Reply With Quote Quick reply to this message
Old 05-20-2014, 10:07 PM   #10 (permalink)
jnbec4ever's Avatar
2008 Santa Fe SE 2011 Sonata SE 2.0T
jnbec4ever
just plug it in for charging and stream BT.
2011 SE Turbo Sonata Lip spoiler ULTRARACING Strut Bar K&N Drop In removed SONATA added T-GDI badge Tint 35%front 20%rear 32MPG AVG Eibach springs
jnbec4ever is offline   Reply With Quote Quick reply to this message
