Oil Leak around oil pan and bottom end! - Hyundai Forums : Hyundai Forum
Old 12-10-2012, 12:21 PM   #1 (permalink)
Mrtheplague's Avatar
Sonata 2.0T Limited 2012 Santa Fe 2.0T SE 2013
Mrtheplague is an unknown quantity at this point
Default Oil Leak around oil pan and bottom end!
So I was going to do my own oil change this weekend and I noticed there was oil all around the bottom plastic cover. I thought that the guys from the dealership did not do a good job of cleaning the bottom of the car after they did the last oil change. Hence why I am doing it now. I realize after cleaning everything that there seems to be a small leak around the gasket where the oil pan meets the bottom of the engine on the back side where the drain plug would be. Has anyone else looked to see if they are leaking too? I didnt change the oil and will be taking the car in for repair this week.
Mrtheplague is offline   Reply With Quote
Old 12-22-2012, 08:00 PM   #2 (permalink)
2012 2.0T SE
probin94 is an unknown quantity at this point
just did my second oil change and found the same problem in the same area. the whole back of the oil pan looked like it was leaking. looks to me like they used liquid gasket for the seal. getting it looked at soon by dealer.
probin94 is offline   Reply With Quote
Old 12-22-2012, 08:37 PM   #3 (permalink)
someguy's Avatar
Good move not changing the oil after noticing the problem. I see this was posted over a week ago. What was the problem?
someguy is offline   Reply With Quote
Old 12-22-2012, 09:58 PM   #4 (permalink)
2012 2.0T SE
i changed mine...it needed it. they try to say something ill punch them in the face haha.
Old 12-22-2012, 09:58 PM   #5 (permalink)
Seeing the lower pan leak at the goo.. the goo they use at assembly seems to be some cheap low quality stuff that dont seem to set up firmly.. Why they aint got smarts to use PERMATEX ULTRA RTV in first place is beyond me,, starting to do re-seal on the LAMBDA engines for front cover and oil pan,, 6+yr later, the goo is still sticky,, not cured... wonder why the joints leak ??
The stuff we get in tube (RTV) sporting Hyundai part number feels/smells/sets up like the previous PERMATEX ULTRA that Hyundai was slapping part number tag on PERMATEX package and sending to dealers before change to current stuff in smaller tube.
sbr711 is offline   Reply With Quote
Old 12-22-2012, 10:02 PM   #6 (permalink)
2012 2.0T SE
they told me on the phone they have a lot of these out on the roads and havent seen this problem. i told the guy thats the same thing they said when my last car blew the engine after less than 4 days.
Old 01-15-2013, 03:14 AM   #7 (permalink)
2012 Sonata
lascala92273 is an unknown quantity at this point
2012 Sonata with same issue. Seems worse after my last oil change with new oil in there. Used a high dollar Bosch filter and Castrol GTX. Changed oil and thought I had some residual dropping that may have got on top of under craddle plastic shield. Crawed under car and there was a very wet oil pan. Not very happy. Glad I am only leasing this thing for my wife. Eeven my Chevy's don't do this crap till they hit 100K+.
lascala92273 is offline   Reply With Quote
Old 01-15-2013, 07:02 AM   #8 (permalink)
2012 Sonata SE 2.4L.......... 2000 Camaro SS
Can you see the area where it is leaking just by removing the access door for the drain plug? I will be changing my oil in the next few weeks and want to check out my engine for leaks.
Dave-S is offline   Reply With Quote
Old 01-15-2013, 07:06 AM   #9 (permalink)
Are you seeing leaks at the front cover as well? If so what's involved to remove that? Also can you drop the oil pan without having to lift the engine?
Old 01-15-2013, 07:41 AM   #10 (permalink)
2011 Hyundai Sonata SE 2.0T Pearl White Hyundai Azera 2013 Pearl White
shavkatjon2000 is on a distinguished road
Send a message via AIM to shavkatjon2000 Send a message via Skype™ to shavkatjon2000
let the dealer take a look at i had the same problem they had to change the oil pan they told me when it happen to me that the seal was not that good so they replaced and put a new seal but i had to wait like 4 hours so everything cured and tested for leaks and didn't pay anything
Mods: Injen Cold Air Intake, 5% tints, Blue LED Plate Lights,
shavkatjon2000 is offline   Reply With Quote
